lgeorge123
| rs232 soft uart |
Posted: Tue Dec 28, 2004 9:14 am |
here I have my program using 16f877 to receive data from pc,once i
write down a ASCII B,a ASCII U is return, I tries many times but unsuccessfully.
in the main loop,one point is be minded that no while(1) should be used.
#include <16f877.H>
#fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT
#use delay(clock=12000000)
#use rs232(baud=9600, xmit=PIN_A5, rcv=PIN_A4,FORCE_SW,errors)
#byte porta = 5
#byte portb = 6
#byte portc = 7
#byte portd = 8
#byte porte = 9
char byte_read;
#int_rda
serial_isr(){
byte_read=getc();}
enable_interrupts(global);
enable_interrupts(int_rda);
setup_adc(no_analogs);
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x00);
set_tris_d(0x00);
set_tris_e(0x00);
porta=0;
portb=0;
portc=0;
portd=0;
porte=0;
if (byte_read=='B')
putc('U');
byte_read=0;
SherpaDoug
Posted: Tue Dec 28, 2004 9:35 am |
I don't think the software UART can use interrupts. Try stripping out the interupt stuff and just write a program the blinks a LED when it receives any serial character. Then make it blink when it receives a 'B'. Then write one that sends 'U'. Then one that sends 'U' when it receives 'B'.
For interrupts you need to use the hardware UART. _________________ The search for better is endless. Instead simply find very good and get the job done. |
rwyoung
Posted: Tue Dec 28, 2004 10:38 am |
It is possible to make a soft UART using interrupts if you use the interrupt on change/edge of RB0. But only for receiving. The "start" bit transition triggers the interrupt. Never tried it myself but I do remember reading about it here.
You can find more information using the forum's "search" feature. _________________ Rob Young
Posted: Tue Dec 28, 2004 10:39 am |
| Quote: | | I don't think the software UART can use interrupts. | Affirmative, no support for interrupts by the software UART.
| Quote: | | It is possible to make a soft UART using interrupts if you use the interrupt on change/edge of RB0. | This is an option, but there are a lot of gotcha's with this one. It might be way too difficult for what lgeorge123 tries to achieve. For example if an half-duplex protocol is used the software UART is still a good option.
I'm a bit worried about the set_tris_a(0x00) command, this sets all pins on port A as outputs. This might work out OK, but as soon as you would add the '#use fast_io' directive things would definately go wrong. Please configure the I/O pins according to your connected hardware, e.g. set_tris_a(0x10).
Rewrite your program according to the recommendations of Sherpadoug |
lgeorge123
| soft rs232 |
Posted: Tue Dec 28, 2004 11:20 am |
actually I have a function,inside it a getchar() function is working,so it is
waiting user to input the data via visual basic program.could somebody give me any suggestion????????
#include <16f877.H>
#use rs232(baud=9600, xmit=PIN_A5, rcv=PIN_A4,force_sw,errors)
#byte porta = 5
#byte portb = 6
#byte portc = 7
#byte portd = 8
#byte porte = 9
int erase();
int program_chip();
char data_read;
int pass,pass1;
//portb=data,portc=a0-a7,portd=a8-a15,porte=a16-a18
{ setup_adc(no_analogs);
set_tris_a(0b0010000);
set_tris_b(0);
set_tris_c(0);
set_tris_d(0);
set_tris_e(0);
porta=0;
portb=0;
portc=0;
portd=0;
porte=0;
pass=0;
pass1=0;
pass= erase();
while(1){
if ((pass==1)||(pass1==1))
{ porta=0x06;
pass1=program_chip();
if (pass1==1)
porta=0x05; //pass
porta=0x07; //fail
porta=0x07;}
}//main
int program_chip()
{ char byte_read,byte_read1;
long index1,index2,index3;
index1=0;
index2=0;
index3=0;
pass1=0;
byte_read=0;
for(index1=0;index1<=0xff;index1++)
for(index2=0;index2<=0xff;index2++)
for(index3=0;index3<=0x07;index3++)
porta=0x01;
portc=index1;
portd=index2;
porte=index3;
byte_read=getchar(); //this is the place to waiting for data
if(byte_read!='!'){
set_tris_b(0x00);
portb=byte_read;
putc('M');
delay_us(100);
porta=0x02;
