Is it possible for a PIC 16F628 port to get damaged ??
arunb
PostPosted: Tue Dec 21, 2004 8:05 pm     Reply with quote
Can a PIC port configured as an output get damaged, if I connect it to +5V source ( without a resistance).
thanks
arun
asmallri
PostPosted: Tue Dec 21, 2004 11:43 pm     Reply with quote
It depends. Provided that the voltage on the PIN is less than or equal to VDD and that the rise time is les than or equal to the rise time on VDD (to avoid latchup).
Regards, Andrew
neil
PostPosted: Wed Dec 22, 2004 6:02 am     Reply with quote
If it is an output, outputting a 0 and you put 5V on it, you are shorting out the lower totem pole fet inside the PIC. (that's if it's not one of the open drain pins, in which case it will be dead anyway) This will almost certainly blow the transistor.
I have done this before, and all the other I/Os seem to survive. You may even find that the upper FET survives, leaving half an IO??
