I need help with code which reads characters from rs232?
Masa
PostPosted: Fri Dec 17, 2004 5:05 am     Reply with quote
Hi, sorry my bad english Smile
I try to do program which send string to computer e.g( "$52"). When computer get string, it send back some information e.g( -12.4C). My problem is that I can't read that data and put it right format. I have tested interface and that is okay. Only problem is code.
Psuedo code:
char result[10];
int i=0;
printf("$52"): // send string to computer
while( !kbhit() ); // waits computer
while( kbhit){ //try to write data to 'result'
result[i]=getch();
i++;
What goes wrong?
asmallri
PostPosted: Fri Dec 17, 2004 5:46 am     Reply with quote
the pseudo code looks ok. You have not decribed the problem enough to be able to determine the possible problem. Can you post an example of your program the demonstrates the problem including the fuse statements, #use statements and which processor you are using.
Regards, Andrew
Masa
Reply
PostPosted: Fri Dec 17, 2004 7:15 am     Reply with quote
Yes,
prosessor is pic16f877
clock=12MHz
I test different baudrates, 1200,2400,9600 but problem not solved. I just wondering is this loop too slow to read characters:
result[i]=getch();
i++;
printf(result)
because, when I test code with terminal program, first I can see $52, that is okay and terminal wait until I send packet. My test packet was 1234. But now I can read only 12 on terminal.
asmallri
PostPosted: Fri Dec 17, 2004 7:28 am     Reply with quote
you have not posted enough code to see where the problem is. For example, I cannot tell if you are using the harware UART or the Software UART function.
Instead of the loop being too slow, it could be too fast. For example, if the #use RS232 statement is enabling the hardware UART then the program could service getch() so fast that after reading in the second character kbhit() returns false because the third character is still being serialised into the UART. When this happens you will drop out of the while loop. Another problem is that you code does not write a 0 at the end of the string in result. The printf statement could end up printing garbage.
Regards, Andrew
Re: Reply
PostPosted: Fri Dec 17, 2004 9:17 am     Reply with quote
Masa wrote:
Yes,
clock=12MHz
result[i]=getch();
i++;
printf(result)
As this code stands, this is a reasonable response...
The code will arrive at the 'while' line, and unless a character has already arrived, will drop through, and print what has been received. You need to either identify the 'end' of the incoming character string, with a 'marker', 'count', or implement a 'timeout', so that the routine only proceeds if characters do not arrive for some time.
Assuming this is not the 'real' code, and only another piece of psuedo code, the other thing that could apply, is that you are 'falling off the end' of the code. If (for instance), you generate:
printf("Test");
at the end of 'main', using the hardware UART, you will see:
'Te' displayed on the PC. The reason in this case, is that unless you wait for the charcters to be actually _sent_, when the processor gets to the end of main, it is put to sleep, and any characters waiting in the hardware UART, are not sent.
Post the actual code, rather than 'snippets', or 'psuedo code' sections, and somebody will probably be able to tell you what is happening.
Masa
code
PostPosted: Fri Dec 17, 2004 12:05 pm     Reply with quote
I wrote new code, because old one was so long.
from headerfile:
#include <16F877A.h>
#device adc=8
#use delay(clock=12000000)
#fuses HS,NOWDT
real code:
#include "D:\\test_rcv.h"
#use rs232(baud=1200, xmit=PIN_c6, rcv=PIN_c7)
char result[10];
int i=0;
setup_adc_ports(ANALOG_RA3_RA2_REF);
setup_adc(ADC_CLOCK_DIV_32);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
//setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
SET_TRIS_D(0);
set_tris_b(0b11111101);
set_tris_c(0b10000000);
disable_interrupts(global);
while(1){
printf("$52");
while( !kbhit() ); // wait until computers send 1. character
while( kbhit() ){
result[i]=getc();
i++;
printf(result);
Terminal:
:$52
TX-->example<nul>
:exa$52exa$52
TX-->example<nul>
After that the prosessor do nothing, and terminal neither. I try to use get_string() from input.c, but that wasn't fix problem. Should I use interrupts?
Humberto
PostPosted: Fri Dec 17, 2004 1:02 pm     Reply with quote
Masa wrote:
Yes, for example enable_interrupts(INT_RDA) if you are using the UART.
The way you determine if you are going to use the UART or not is implicit in the directive
where if you select rcv=PIN_C7, the UART is enabled and the hardware
handle the incoming chars flagging INT_RDA interrupts.
If you select another rcv PIN different that PIN_C7 (in this processor) the UART is not
active
and you must code a software handler to receive a char without interrupts.
Anyway I suggest to search in this forum all the info related RS232 and you will find
tons of code and examples to learn from.
Best wishes,
Humberto
C#R# []
RS232
PostPosted: Sat Dec 18, 2004 5:24 pm     Reply with quote
Hi.. at short time ago, I wrote a code with RS232 and work very weel.. but at begining I had some problems...well...the problem is the watchdog.
The new getc() ( thatīs I named getcW() ) stoped the problem..
int getcW ()
while ( !(*PIR1 & 0b00100000)) restart_wdt() ;
return (*RCREG);
// WATCH DOG... YOU ARE SO BAD...HEHEHE !!!!
humm...thatīs good for me ..and I would like to be good for you too....
donīt forget :
#define PIR1 0x0C
#define RCREG 0x1A // for PIC16F871 !!!
Mark
PostPosted: Sat Dec 18, 2004 6:55 pm     Reply with quote
while( kbhit() ){
result[i]=getc();
i++;
printf(result);
Your going to fall out of this loop after you receive the first character. The PIC is pretty fast and it takes some time to receive the next char. Also, you need to tell the printf what kind of data you are printing.
