davt
Display multiplexing |
Posted: Wed Dec 15, 2004 11:15 am |
Hi all
I have a Pic base project with 7 segment led displays - 0.56" size.
At present I use transistors to switch the common cathodes to ground to turn the relevant digit on. Because the display is not on continuously ie. it is scanned can I dispense with the transistors and use the port pins to ground the cathodes without damaging the pic or reducing its lifespan?
Thanks. |
Humberto
Posted: Thu Dec 16, 2004 8:10 am |
First answer is no.
Not sure what do you try to do, considering how cheap a transistor is.
To light-on each segment of the display you need at least 7 - 10mA,
taking the worst case, wich is to display the number '8', you need
7mA x 7seg = 49mA/digit.
Microchip datasheet spec for almost all the line stated a maximum
allowable current of 25mA for driving/sinking.
Hope this help.
Humberto |
davt
Posted: Thu Dec 16, 2004 8:46 am |
Thanks Humberto for your reply.
I do realize that the max current is 25ma but if I am scanning through the 7 seg displays they will only be on for about 2ms.
I thought that the port pins might withstand a 2ms pulse rather than be continuously on.
Dave |
Humberto
Posted: Thu Dec 16, 2004 9:18 am |
Hi davt,
I´m sure that if you use a PIC output to sink such pulsed current would
work, but it´s a matter of taste + experience, I´m very conservative and
never will take the risk, just to save $0.02 in a transistor.
Best wishes,
Humberto  |
drh
Joined: 12 Jul 2004 Posts: 193 Location: Hemet, California USA
Posted: Thu Dec 16, 2004 1:09 pm |
If you don't use transistors AND you are debugging with an ICE or ICD, you could accidentally stop the code with the cathodes enabled and blow the PIC output. I would use transistors. _________________ David |
davt
Posted: Thu Dec 16, 2004 3:34 pm |
Point taken!
Thanks for all input.
Dave |
