Prashant Patel
| 10Bit DAC TC1321 |
Posted: Tue Dec 14, 2004 6:20 pm |
Hi..
we are using 16F877 and DAC TC1321.
I have written following simple program to generate saw tooth waveform.
4.7K pullups are connected to both SDA and SCL line.
Reference volgate at pin Vref is 3.0V ( using 2.2k and 3.2k).
The pulses produced at SCL and SDA line are fine.
I have change three DAC TC1321 to make sure it is working.
What can be problem?
Onething to make sure is for sending 8bit data would it be fine to write
i2c_write(data);
line only once or need to write it twice?
| Quote: |
#include <16F877.h>
#ifndef DAC_SDA
#define DAC_SDA PIN_C4
#define DAC_SCL PIN_C3
#use i2c(MASTER, SDA=DAC_SDA, SCL=DAC_SCL,FAST)
void write_DAC(int data)
i2c_start();
i2c_write(0x90); // 7 bit SMBus address for TC1321 and 8th bit is Read/Write(bar i.e negative)
i2c_write(0);
i2c_write(data);
i2c_stop();
int i;
while (TRUE) {
write_DAC(i);
i=i+1;
if(i==255)
i=0;
}//while (TRUE)
Thanx in advanced...
Regards
Prashant |
Charlie U
Joined: 09 Sep 2003 Posts: 183 Location: Somewhere under water in the Great Lakes
Posted: Tue Dec 14, 2004 10:36 pm |
Check the data sheet for the DAC closely. The maximum clock rate is 100kHz, which in I2C land is SLOW, not FAST. Try changing the parameter in your #use i2c() to SLOW.
Let us know if this helps. |
Prashant Patel
Posted: Wed Dec 15, 2004 1:43 pm |
Hi..
Thanks for reply.
I checked the datasheet for DAC TC1321. Max clock frequency
is 100KHz.
I have tried the following way to make clock input to DAC slow
but it does not work?
Please tell me if it is not proper or you know some other way.
The interesting thing is clock input and SDA output are fine.
Then shouldn't it produce the sawtooth waveform?
| Quote: |
#use i2c(MASTER, SDA=DAC_SDA, SCL=DAC_SCL,SLOW)
I have also tried to remove SLOW keyword but no effect. |
rwyoung
Posted: Wed Dec 15, 2004 3:47 pm |
Have you confirmed that Vdd of the DAC is connected?
Have you confirmed that Vref of the DAC is connected?
Have you confirmed that SDA and SCL are connected at the DAC and not accidentally swapped?
Are you monitoring pin 5 (VOUT) or pin 7 (DAC-OUT)? I suggest you monitor pin 5 as DAC-OUT is unbuffered and can't drive much load.
I add this function:
| Code: | void
init_ext_i2c (void)
output_float (SCL_PIN);
output_float (SDA_PIN);
before I start using the I2C bus. I typically use #use fast_io() and setup the pin directions myself rather than allow the extra instructions inserted by #use standard_io() (the default if you don't specify "fast" or "fixed").
Your function "void write_DAC(int data)" seems reasonable.
Finally, although this shouldn't be stopping your DAC from working, your code:
while(TRUE) {
write_DAC(i);
i=i+1;
if (i==255)
i=0;
is a bit too much for sending 0 to 255 over and over. All you need is
while(TRUE) {
write_DAC(i++);
assuming "i" is an 8 bit. "i" will just roll over from 0xFF back to 0 all by itself! Isn't that clever!
I generally use "int8" instead of "int" when I mean something to be 8-bit signed but not intended as a character. Eventhough "char" is the same thing, I think it improves the readability of the code because you know a bit more about what the variable is intended to do. Anyway, just personal preference.
Another thing I like to add is #CASE near the beginning to force case sensitivity. Again, personal preference. _________________ Rob Young
