input() function problem???
Goto page Previous  1, 2
YulL
PostPosted: Tue Dec 14, 2004 2:55 am     Reply with quote
I'm wrong, here is the detail with fast_io (I gived details with standard_io).
.................... while(1)
.................... if(!input(ONOFF))
0052: BTFSC 05.4
0053: GOTO 056
.................... output_low(REGUL);
0054: BCF 05.5
.................... else
0055: GOTO 057
.................... output_high(REGUL);
0056: BSF 05.5
0057: GOTO 052
PostPosted: Tue Dec 14, 2004 5:15 am     Reply with quote
Humberto wrote:
We doesn´t know what compiler version is using YulL
This code is fine.
The code is switching banks. Setting the _TRIS_ bit to '1', to make the pin an input. Then switching to the bank to read the pin, and correctly testing it.
Yes but.. he defines:
#use fast_io(A) and then:
set_tris_a(0x10);
Why is setting the TRIS_BIT in the main if it was done before ?
.................... while (input(ONOFF));
0059: BSF 03.5
005A: BSF 05.4 // !!!! ???? Why here ?
005B: BCF 03.5
005C: BTFSC 05.4
005D: GOTO 059
I agree with rnielsen proposal -just to test- his code is very clean and generate the simplest available code.
0019:  BTFSC  05.4
001A:  GOTO   01D
001B:  BCF    05.5
001C:  GOTO   01E
001D:  BSF    05.5
001E:  GOTO   019
Humberto
[/quote]
The reason it is setting the TRIS bit, is that if 'standard_io' is selected, it will _always_ do it.
The three 'io methods' in CCS, are:
'standard_io'. With this, tris will be changed for _every_ IO instruction, even if it was set in the past.
'fixed_io'. With this, the TRIS bits can be defined in the io statement, or using 'tris', and these wll not be altered for the individual accesses, but will be left as they were for the last set statement.
'fast_io'. With this, the compiler will not touch TRIS at all, but will leave it up to you to set/reset it.
You can play with TRIS as much as you want, but unless 'fast_io', or 'fixed_io' is selected, the compiler will still set the TRIS bit for every access...
Humberto
PostPosted: Tue Dec 14, 2004 7:24 am     Reply with quote
Ttelmah wrote:
NOP. This is not the case.
If you read carefully the code posted by YulL, you will see clearly that for
port_a data direction setting he used the directive
#use fast_io(A)
and for other ports he used
#use standard_io();
The inputs and outputs regarding this discusion was focused in port_A.
Humberto Very Happy
YulL
PostPosted: Tue Dec 14, 2004 7:32 am     Reply with quote
Well the problem is that I have played with standard_io and unfortunately it is possible that I have send the code with standard_io. fast_io is a good method and it works.
I have finally found 400ns glitches in the onoff signal, that explains why the program detects a low level sometimes Confused
I have included the following code and it works now! Wink
#include "F:\...\header.h"
#org 0x0F00, 0x0FFF void loader16F874(void) {} //for the 4k 16F873/4
#define DEBOUNCE_PERIOD_IN_MS 10
#define DEBOUNCE_COUNT 8
int8 count=0, debounce=0;
#int_rtcc
void clock_isr()
switch (debounce)
case 0:
// First, wait for the button to be released.
if(input(ONOFF)) count++;
else count=0;
if(count==DEBOUNCE_COUNT) { debounce=1; count=0; }
else debounce=0;
case 1:
// Now that the button is up, wait until the user presses it.
if(!input(ONOFF)) count++;
else count=0;
if(count==DEBOUNCE_COUNT) { debounce=2; count=0; }
else debounce=1;
case 2:
output_low(REGUL);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
set_tris_a(0x10);
output_high(REGUL);
output_high(LED0);
output_low(LED1);
delay_ms(2000);
output_high(LED1);
set_timer0(0);
setup_counters( RTCC_INTERNAL, RTCC_DIV_64 | RTCC_8_BIT );
enable_interrupts(INT_RTCC);
Thanks for all your help, it is really helpful Wink
Mark
PostPosted: Tue Dec 14, 2004 12:18 pm     Reply with quote
#use fast_io(A)
#use standard_io();
Humberto Very Happy
NOPE, Ttelmah is right. I guess you didn't read or understand his earlier post
Humberto
PostPosted: Tue Dec 14, 2004 2:45 pm     Reply with quote
Mark wrote:
Mark,
I guess you didn't read or understand my earlier post.
I copied and pasted the header code posted by YulL
here is the header :
#include <16F873A.h>
#device adc=8
#use delay(clock=7372800) //7372800
#fuses HS, NOWDT, NOPROTECT, NOLVP, NOBROWNOUT, PUT
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use fast_io(A)
#use standard_io(B)
#use standard_io(C)
#define LED0 PIN_A0
#define LED1 PIN_A1
#define ONOFF PIN_A4
#define REGUL PIN_A5
#define DATADS PIN_C4
The inputs and outputs regarding this discusion was focused exclusivelly in port_a.
Can you see the directive #use fast_io(A) ???
'fast_io'. With this, the compiler will not touch TRIS at all.
Humberto
PostPosted: Tue Dec 14, 2004 3:16 pm     Reply with quote
#use fast_io(A)
#use standard_io();
Humberto Very Happy
I think the 'key' thing you are missing, is that _standard_io_, is _standard_.
_Unless_ fast_io, or fixed_io is selected, _standard_io_, is assumed. In fact there is no reason at all for the 'standard_io' statements in the code posted. The only time you need to use the standard_io statement, is where you have selected one of the other forms, and wish to 'change back' for a section of code.
Hence port_a, is using standard_io. As such the TRIS statement, will be overridden as soon as I/O is attempted to the port...
Hence my comments...
SherpaDoug
PostPosted: Tue Dec 14, 2004 3:54 pm     Reply with quote
Now I am thoroughly confused.
Ttelmah do you mean that after:
#use fast_io(A)
#use standard_io(B)
#use standard_io(C)
the compiler will STILL set the TRIS register each time for port A, despite the #use fast_io(A) statement?
And I am used to a TRIS statement looking like:
0498: MOVLW F0
0499: TRIS 5
I don't see a TRIS in this code:
0059: BSF 03.5
005A: BSF 05.4
005B: BCF 03.5
005C: BTFSC 05.4
005D: GOTO 063
It looks like the ONOFF bit itself is being set at 005A
Mark
PostPosted: Tue Dec 14, 2004 4:07 pm     Reply with quote
Humberto wrote:
Mark wrote:
Mark,
#device adc=8
#use fast_io(A)
#use standard_io(B)
#use standard_io(C)
#define LED0 PIN_A0
#define LED1 PIN_A1
Humberto
No I understood everything. YulL posted code that used fast_io. However, his lst file was from a version where he tried standard_io and thus his comment
Then you went on to say that Ttelmah's comment was incorrect. But what he said was totally correct but he was referring to the lst files details where YulL used standard_io! Razz
Humberto
PostPosted: Tue Dec 14, 2004 7:29 pm     Reply with quote
To be kind with the readers of this forum I suggest to stop with this
Babel Tower discution.
Anyway, I want to redeem the spirit of this forum. Exclamation Exclamation Exclamation
Ttelmah and Mark thanks for your patience. Very Happy
Humberto
Page 2 of 2
