RossJ
| Array arithmetic |
Posted: Wed Dec 08, 2004 2:08 am |
My C must be a little rusty (too much Java I guess), but is the following legal in C and are they the same?
| Code: | &an_array[4]
an_array + 4
where an_array is an array of int8.
If the array of int8 actually contains an int16 that I want to extract, is the following legal?
| Code: | *((int16*) &an_array[4])
*((int16*) (an_array + 4))
The reason I ask is that the CCS compiler doesn't appear to work with the second approach, but the first one is fine. Of course both compile ok The problem is that the pointer is miscalculated (the high byte was zero in the case I remember). I suppose it could be a typecast problem. Or is this a known compiler bug? I have seen a few posts about unexpected pointer arithmetic behavior.
I am using PCWH 3.214 with a PIC18F2620. |
Mark
Posted: Wed Dec 08, 2004 9:01 am |
This worked just fine for me
#device PIC16F877 *=16 ADC=8
int8 an_array[20];
// This is for an int16 located at byte 4 in the array
*((int16*) &an_array[4]) =0x1234;
*((int16*) (an_array + 4)) = 0x5678;
// This is though we declared the array as an int16 and are accessing element 4
*((int16*)an_array + 4) = 0xABCD;
RossJ
Posted: Wed Dec 08, 2004 9:10 pm |
Thanks Mark.
I have done a little further investigation using the following program...
| Code: | #device PIC18F2620
#zero_ram
int8 an_array[40];
#locate an_array = 0x420
int8 offset = 6;
int8* p;
// Test 1
p = an_array + offset + 4; *p = 0xA1; // written to 0x02A -- ERROR
p = an_array + (offset + 5); *p = 0xA2; // written to 0x02B -- ERROR
p = &an_array[offset + 6]; *p = 0xA3; // written to 0x42C -- OK
p = an_array + 6 + 7; *p = 0xA4; // written to 0x42D -- OK
// Test 2
*((int16*)an_array + offset + 4) = 0xBBB1; // written to 0x430/1 -- ERROR
*((int16*)an_array + (offset + 4)) = 0xBBB2; // written to 0x434/5 -- OK
*((int16*)an_array + 6 + 4) = 0xBBB3; // written to 0x434/5 -- OK
*((int16*)an_array + (6 + 4)) = 0xBBB4; // written to 0x434/5 -- OK
Test1:
As indicated in the comments, p is corrupted in the first 2 examples. It looks like a simple failure to correctly handle the high order byte, rather than a failure to take both offset and the constant into account (since the low order byte of p is correct). It seems that the variable (offset in this case) is triggering the fault, since your test program works fine (I tried it too).
I also ran the above program on a PIC16F877 with the same faulty results. Of course I used PIC16F877 with *=16 and the location of an_array moved to bank 2 (since 0x420 is not available).
Test2:
In addition, I did some experimenting with your third line (the one where the offset is in 16 bit words). I think I found a bug there too.
I'll shoot this off to CCS support. |
