how to measure a 6600hz signal?
Goto page Previous  1, 2, 3  Next
young
PostPosted: Thu Dec 02, 2004 10:19 am     Reply with quote
Thank you:
I did google out as you adviced. I tried before, I typed in X0-543 which should be XO-543, and failed. Right now I find
Pin 1 N.C.
7 Ground
8 output
14 3.3VDC
I connected 14 to +5 volt, it seems output 20Mhz at Pin 8 also.
The problem is which pin on the controller should I connect with Pin8.
should I just connnect with OSC1 or OSC2? or should I connect Pin8 with both of OSC1 & OSC2?
Mark
PostPosted: Thu Dec 02, 2004 10:22 am     Reply with quote
OSC1 is also clockin, that is where it goes. You know the datasheet says that it is a 3.3volt part, right?
young
PostPosted: Thu Dec 02, 2004 10:25 am     Reply with quote
Your right. I was just wondering if it would work at 5V.
PostPosted: Thu Dec 02, 2004 10:48 am     Reply with quote
Come on now, 2 minutes! Aren't you being conservation Very Happy More like 20 seconds Wink But seriously really easy to find.
Yes, it was under 2 minutes, but I didn't want to show off. Cool
That's why I am selective about some posts. People do have to do some of the work!
I do agree. Some people really are too lazy. Wink
rwyoung
PostPosted: Thu Dec 02, 2004 2:32 pm     Reply with quote
If the data sheet says it is a 3.3V part then it is a 3.3V part. Trying to run it at 5V will likely kill the part.
Look carefully at the data sheet and find the section that gives ABSOLUTE MAXIMUM/MINIMUM values. I'd bet the maximum Vdd allowed is between +3.6V and +3.8V.
Honestly, for all the time you spend posting you could just stop and do a little thinking on your own. Remember, Google is your friend and so are the datasheets!
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
young
PostPosted: Mon Dec 06, 2004 10:30 am     Reply with quote
I am facing another problem. I could read and printf data (including the frequency data) correctly through RS232, However, When I put the remote data transfering function, I sometimes get frequency signal doubled what it should be, for example, I have frequency ranges from 710-780, I sometimes get printf data as 1410-1560. I fell that in my #int_CCP1, the start_tie was not updated sometime? I do not know why this happened? and how could I avoid the problem?
#if defined(__PCM__)
#include <16F76.h>
#include <stdio.h>
#include <stdlib.h>
#fuses HS,WDT,NOPROTECT
//#device ADC=10
#use rs232(baud=2400, parity=N, xmit=PIN_C6, rcv=PIN_C7)
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE   65536
int8 temperature,tilt;
int8 frequency,i, length;
int32 j=0, humidity,danum=0;
char status, status1[10];
int millisecs=0;
char datachar[20];
//for frequency
int16 overflow_count;
unsigned int32 start_time, end_time;
int32 pulse_ticks;
void remoteprintf(char *c)
   char synch;
   char junk;
   length=strlen(datachar);
   junk = 126;
   synch = 'A';
   for (i=0; i<length;i++)
      putc(junk);
      putc(synch);
      putc(datachar[i]);
      delay_ms(5);
   putc(junk);
   putc(synch);
   putc(0);
#int_TIMER1
TIMER1_isr()
   ++overflow_count; //increment whenever an overflow occurs;
#int_CCP1
CCP1_isr()
   end_time=CCP_1; //read captured timer ticks
   pulse_ticks=(0x10000*overflow_count)-start_time+end_time;
   start_time=end_time;
   overflow_count=0;   //clear overflow counts
   setup_port_a(AN0_AN1_AN3);
   setup_adc( ADC_CLOCK_INTERNAL );
 //  set_tris_a(0xFF);
   //time clock pulse 64*1/4000000=64*0.25microsecond=16microsecond
//   setup_counters(RTCC_INTERNAL,RTCC_DIV_64);
   setup_CCP1(CCP_CAPTURE_RE);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
//   enable_interrupts(INT_TIMER0);
   enable_interrupts(INT_TIMER1);   //unmask timer1 overflow interrupt
   enable_interrupts(INT_CCP1);
 //  enable_interrupts(INT_RDA);
   enable_interrupts(global);
 //  init_ext_eeprom();
   set_adc_channel( 0 );
   delay_us(50);
   temperature = Read_ADC();
   //Without remote part (the following two lines, everything works just fine, with it I got the problem
   sprintf(datachar,"%u %lu t",temperature, pulse_ticks);
   remoteprintf(datachar);
  //printf("%u %lu\r\n",temperature, pulse_ticks);
 //20ms delay is a must for good data transferring
   delay_ms(50);
PostPosted: Mon Dec 06, 2004 12:34 pm     Reply with quote
some of my output are like these
\0A137 1448 \0D
\0A137 137 724 \0D
\0A137 724 \0D
\0A137 724 \0D
\0A137 724 \0D
\0A137 724 \0D
0A137 724 \0D
\0A137 724 \0D
\0A137 724 \0D
\0A1137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A137 726 \0D
\0A1136 1445 \0D
\0A136 1445 \0D
\0A136 1445 \0D
I am confused my the output by BLACK, and Do not know how to correct the problem?
PostPosted: Mon Dec 06, 2004 12:58 pm     Reply with quote
any clues, please?
drh
PostPosted: Mon Dec 06, 2004 3:08 pm     Reply with quote
Try putting a delay after the sprintf() call.
David
PostPosted: Mon Dec 06, 2004 3:31 pm     Reply with quote
Thank you:
I tried as you suggested, It did not improve the performance of the printf output.
PostPosted: Mon Dec 06, 2004 3:35 pm     Reply with quote
Expercially I do not understand why the output frequency value doubled what it sould be?
rwyoung
PostPosted: Mon Dec 06, 2004 3:47 pm     Reply with quote
1) Check the assembly listing for your CCP1 interrupt. You may need to add a casting operation before you multiply "overflow_count" to make it an unsigned 32-bit integer.
2) Turn off the timer or in some otherway "freeze" the value of "pulse_ticks" just before you sprintf it into the string. Are you sure that an interrupt is not occuring in the middle of the sprintf call? Reenable the interrupt after you are done sprintf-ing the variable into the string.
Rob Young
PostPosted: Tue Dec 07, 2004 8:14 am     Reply with quote
rwyoung:
Than you very much, I think you did have some very good point.
I trired to modified my program, like this:
   int32 humidity;
   delay_us(50);
   humidity=pulse_ticks;
   setup_CCP1(CCP_OFF);
   setup_timer_1(T1_DISABLED);
   DISABLE_INTERRUPTS(global);
   sprintf(datachar,"%u %lu t",temperature, humidity);
   overflow_count=0;
   pulse_ticks=0;
   delay_ms(20);
However I got more variable changes, I got the following results:
\0A124 494 \0D
\0A124 494 \0D
\0A124 494 \0D
\0A124 494 \0D
\0A124 742 \0D
\0A124 742 \0D
\0A124 742 \0D
\0A124 742 \0D
\0A125 792 \0D
\0A125 792 \0D
\0A125 792 \0D
\0A125 578 \0D
\0A124 578 \0D
\0A124 578 \0D
\0A124 578 \0D
\0A124 1377 \0D
\0A124 1377 \0D
Which I think I should follow to freeze timer1 and CCP1 during data transferring, but I failed to do that, would you please check it for me to find a solution!
Thanks again
PostPosted: Tue Dec 07, 2004 12:31 pm     Reply with quote
I am getting much better result than before, however, why the frequency is not stable, I mean relatively not stable for example, when the frequency is just a few Hz changes, there should be not reading various or very little, however, I am have a large various change, for example
a range
\0A132 738\0D
\0A132 735\0D
\0A133 738\0D
\0A133 741\0D
\0A133 735\0D
\0A133 733\0D
while the frequency is just around 6793-6795?
It looks like that I am still not getting the right result.
why this happens?
rwyoung
PostPosted: Tue Dec 07, 2004 2:15 pm     Reply with quote
Have you tried "playing computer" at your desk? Take the assembly listing and a clean sheet of paper. Start plugging in reasonable numbers for your timer values and see if you can reproduce the error. It really sounds like there is a math error present. Either a roll-over/round-off issue or a bug in the way CCS is translating one or more of your functions.
Rob Young
Page 2 of 3
