how to measure a 6600hz signal?
Goto page 1, 2, 3  Next
young
PostPosted: Wed Dec 01, 2004 6:02 pm     Reply with quote
I used the following program to measure a signal range from 6300-6800hz. however, my output is always like this, with some occasional change even when I changed the frequency? axccording to timer1 ticks, it should be around 579-597
what is the problem?
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 282\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
\0A131 163\0D
#if defined(__PCM__)
#include <16F76.h>
#include <stdio.h>
#fuses XT,WDT,NOPROTECT
#use rs232(baud=2400, parity=N, xmit=PIN_C6, rcv=PIN_C7)
//for frequency
int overflow_count;
unsigned int32 start_time, end_time;
int32 pulse_ticks;
#int_TIMER1
TIMER1_isr()
   ++overflow_count; //increment whenever an overflow occurs;
#int_CCP1
CCP1_isr()
   end_time=get_timer1(); //read captured timer ticks
   pulse_ticks=(0x10000*overflow_count)-start_time+end_time;
   start_time=end_time;
   overflow_count=0;   //clear overflow counts
   setup_port_a(AN0_AN1_AN3);
   setup_adc( ADC_CLOCK_INTERNAL );
   setup_ccp1(CCP_CAPTURE_RE);
   enable_interrupts(INT_CCP1);
   enable_interrupts(global);
   set_adc_channel( 0 );
   delay_us(50);
   temperature = Read_ADC();
   printf("%u %lu\r\n",temperature, pulse_ticks);
   delay_ms(150);
Mark
PostPosted: Wed Dec 01, 2004 6:59 pm     Reply with quote
If you are using the capture module, why not use the CCPR1 value instead of the timer1 value? That is what its purpose is for. It also negates the interrupt latency. I suspect you real problem is the fact that overflow_count is 8 bits.
young
PostPosted: Wed Dec 01, 2004 7:35 pm     Reply with quote
thank you mark:
You are right, I changed get_timer1() into CCP_1 and it seems it is make some changes when the frequency. Do you think I should use a high frequency crystal to increase the resolution?
young
PostPosted: Wed Dec 01, 2004 7:42 pm     Reply with quote
In my hand, I have a 20mhz crystal, I am thinking to try it, but since this is a four pin crystal, I do not know how to connecte it. I search the web, I could not find the datasheet. could you help me with this also?
and also do you think, the timer1 interrupt would affect stable rs232 communication?
Thanks a lot.
PostPosted: Wed Dec 01, 2004 7:48 pm     Reply with quote
What are all the markings on the "crystal" Is it a flat square package with a pin under each corner
young
PostPosted: Thu Dec 02, 2004 7:33 am     Reply with quote
yes, it is a flat square crystal with four pins, on the surface of the crystal, it is XO-543BE
20.000M
Dale 0428H
SherpaDoug
PostPosted: Thu Dec 02, 2004 8:36 am     Reply with quote
This doesn't look like a resolution or crystal frequency problem to me. You should be able to read consistently +/- 1 count. Since you output is always less than 0x10000 does this mean overflow_count is always zero? Try:
   pulse_ticks=0x80000+(0x10000*overflow_count)-start_time+end_time;
and see if you get the same result offset by 0x80000. Maybe zero-start_time is causing grief.
Mark
PostPosted: Thu Dec 02, 2004 8:57 am     Reply with quote
Not sure how you figured this.
(4000000/4)/6300 = 158
(4000000/4)/6800 = 147
Try this
#include <16F76.h>
#include <stdio.h>
#fuses XT,NOWDT,NOPROTECT
//for frequency
unsigned int16 lastvalue, pulse_ticks;
int1 GotValue = 0;
#int_CCP1
CCP1_isr()
  GotValue = 1;
  pulse_ticks = CCPR1 - lastvalue;
  lastvalue = CCPR1;
  lastvalue = 0;
    if (GotValue)
      GotValue = 0;
      printf("Pulse Width - %lu\r\n", pulse_ticks);
young
PostPosted: Thu Dec 02, 2004 9:26 am     Reply with quote
What I am thinking is like this:
for a 4mHz crystal, Timer 1 ticks frequency will be 1mhz which is 1/4 of the crystal frequency. so the timer 1 will ticks /1m=1 micro second per ticks.
for a signal as 6600hz, it will be 1/6600hz=151 micro second, so the frequency read will be around 151, what my current output from the terminal is around 142-151. I think this is right.
However, if I have a crystal frequency higher than 4mhz, for example, 40MHz, the timer1 ticks 0.1 micro second per tick. so the frequency will get reading as 10 times higher than 151, it will be 1510, so what ever frequency, the reading will be 10 times higher. so for a range of frequency of 6300-6800khz frequency at 4mhz it will be get reading of (147-158), at 40mhz it will get reading at (1470-1580);
This is why I am think the crystal frequency is critical.
Please correct if I am wrong.
young
PostPosted: Thu Dec 02, 2004 9:30 am     Reply with quote
Mark:
you are right, I corrected in my last post, do you agree that if I have a high speed crystal, I could get higher resolution when the signal frequency various.
Mark
PostPosted: Thu Dec 02, 2004 9:41 am     Reply with quote
You are correct but I don't think there are any 16's capable of 40MHz.
young
PostPosted: Thu Dec 02, 2004 9:43 am     Reply with quote
Thank you mark:
What you mean 16's, I am ordering a 20mhz crystal angway, and currently, I have a Dale 20Mhz crystal, I do not know how to wire it to the microchip.
Mark
PostPosted: Thu Dec 02, 2004 9:57 am     Reply with quote
PIC10,PIC12, PIC16, PIC18...
16's mean PIC16F family. You example used 40MHz and you are using a PIC16 which isn't capable of 40MHz.
PostPosted: Thu Dec 02, 2004 9:58 am     Reply with quote
What you mean 16's,
He meant the PIC16 series of processors. There are currently no PIC16 processors running above 20MHz (as far as I know).
Two minutes of Google gave me:
http://www.vishay.com/docs/35038/xo543.pdf
It took me longer to write this message than than it would have taken you to try google yourself....
Mark
PostPosted: Thu Dec 02, 2004 10:05 am     Reply with quote
Come on now, 2 minutes! Aren't you being conservation Very Happy More like 20 seconds Wink But seriously really easy to find. That's why I am selective about some posts. People do have to do some of the work!
Page 1 of 3
