why does my count roll over at 255 every time
buckeyes1997
PostPosted: Thu Nov 25, 2004 8:14 am     Reply with quote
i was trying to increment an int in a loop with a delay and the loop says when i<10000 count, but it only ever gets to 255 and then flips back to zero. how can i get a continuous count on my 16f84 via software loops?? next ill be trying to do it with timer0 so any info about that would also be appreciated.
thanks
matt
dyeatman
Int is 8 bits
PostPosted: Thu Nov 25, 2004 8:42 am     Reply with quote
THe default int here is 8 bits. You have to specify int16.
Sherpa Doug
Re: Int is 8 bits
PostPosted: Thu Nov 25, 2004 9:01 am     Reply with quote
Note that this follows the original K&R definition of a C integer, that it should be the natural data width of the processor. It is only ANSI C where they arbitrarily forced it to be 16 bits.
buckeyes1997
hmm
PostPosted: Fri Nov 26, 2004 1:58 pm     Reply with quote
well i did try using int32 and it didnt make a difference....after 255 she rolls over. is there something better about int16 that int32 doesnt do?
i just tried a loop like
loop:
for(i=0; i<2000; i++)
printf(lcd_putc, "value=%u", i)
goto loop
how would i setup the system to count up to a really large number without rolling over??
thanks
Haplo
PostPosted: Fri Nov 26, 2004 3:16 pm     Reply with quote
Your problem is the printf statement:
printf(lcd_putc, "value=%u", i);
Change it to:
printf(lcd_putc, "value=%lu", i)
