pls give me some suggestion about converting this to 16f877
Goto page Previous  1, 2
Mark
PostPosted: Mon Nov 22, 2004 12:19 pm     Reply with quote
Okay, the LCD code will probably hang since you don't have one connected. Try this, I removed the button and lcd stuff.
/*            RTTTL Ring Tone Player for Microchip Microcontrollers          */
/* This program was designed to run on the PICDEM2 Plus demo board from      */
/* Microchip.        */
/* Usage:        */
/*         S3 - Selects Melody                                               */
/*         S2 - Starts/Stops Melody                                          */
/* This code was designed for a clock speed of 20MHz                         */
/* The target device was a PIC18F452.                                        */
/* You can use the PIC16F877 by changing the setup of CCP1 to                */
/* CCP_COMPARE_INT.  You will also need to toggle the output pin in the      */
/* CCP1 interrupt routine.                                                   */
/* Many of the tunes were downloaded from "www.mrtones.com"                  */
#case
#list
#if defined(__PCH__)
  #include "18F452.h"
#else
  #include "16F877.h"
#endif
#device *=16
#define CLOCKSPEED     20000000
#define CCP_COMPARE_TOGGLE_MATCH        2
#use delay(CLOCK=CLOCKSPEED)
#fuses HS, NOWDT, NOLVP, PUT
#define TMR1_PRESCALE  8
#define NOTE_C_SHARP   (((CLOCKSPEED/4)/277.18)/TMR1_PRESCALE)            // 277.18Hz
#define NOTE_D_SHARP   (((CLOCKSPEED/4)/311.13)/TMR1_PRESCALE)            // 311.13 Hz
#define NOTE_F_SHARP   (((CLOCKSPEED/4)/369.99)/TMR1_PRESCALE)            // 369.99 Hz
#define NOTE_G_SHARP   (((CLOCKSPEED/4)/415.30)/TMR1_PRESCALE)            // 415.30 Hz
#define NOTE_A_SHARP   (((CLOCKSPEED/4)/466.16)/TMR1_PRESCALE)            // 466.16 Hz
#define NOTE_C         (((CLOCKSPEED/4)/261.63)/TMR1_PRESCALE)            // 261.63 Hz
#define NOTE_D         (((CLOCKSPEED/4)/293.66)/TMR1_PRESCALE)            // 293.66 Hz
#define NOTE_E         (((CLOCKSPEED/4)/329.63)/TMR1_PRESCALE)            // 329.63 Hz
#define NOTE_F         (((CLOCKSPEED/4)/349.23)/TMR1_PRESCALE)            // 349.23 Hz
#define NOTE_G         (((CLOCKSPEED/4)/392.00)/TMR1_PRESCALE)            // 392.00 Hz
#define NOTE_A         (((CLOCKSPEED/4)/440.00)/TMR1_PRESCALE)            // 440.00 Hz
#define NOTE_B         (((CLOCKSPEED/4)/493.88)/TMR1_PRESCALE)            // 493.88 Hz
#define NOTE_SILENCE   0
#define DURATION_32   5    // Duration = 2^x
#define DURATION_16   4    // Duration = 2^x
#define DURATION_8    3    // Duration = 2^x
#define DURATION_4    2    // Duration = 2^x
#define DURATION_2    1    // Duration = 2^x
#define DURATION_1    0    // Duration = 2^x
typedef enum
  SILENTNIGHT,
  JINGLEBELLS,
  LAST_MELODY
}MELODIES;
typedef struct
  int Head;
  int Tail;
  int Count;
} NOTESTAT;
typedef struct
  long note;
  long duration;
}NOTE_DEF;
struct
  int TRISC0:1;
  int TRISC1:1;
  int TRISC2:1;
  int TRISC3:1;
  int TRISC4:1;
  int TRISC5:1;
  int TRISC6:1;
  int TRISC7:1;
}TRISCbits;
  #locate TRISCbits = 0xF94
#else
  #locate TRISCbits = 0x87
#endif
long TMR1;
  #locate TMR1 = 0xFCE
#else
  #locate TMR1 = 0x0E
#endif
int TMR1L;
  #locate TMR1L = 0xFCE
#else
  #locate TMR1L = 0x0E
#endif
int TMR1H;
  #locate TMR1H = 0xFCF
#else
  #locate TMR1H = 0x0F
#endif
int TMR0;
  #locate TMR0 = 0xFD6
#else
  #locate TMR0 = 0x01
#endif
#define   MAX_NOTE_BUFFER_SIZE  4
#define   NOTE_ROLLOVER_MASK     0b00000011
NOTE_DEF  NoteBuffer[MAX_NOTE_BUFFER_SIZE];
NOTESTAT  Notestat = {0,0,0};
long      DurationCount=0;
int       Tempo=0;
long      Note_Ticks=0;
MELODIES  Melody_Pointer;
long      Note_Index = 0xFFFF;
BOOLEAN   PlayMelodyFlag = TRUE;
const struct
  char tune1[128];
  char tune2[65];
  int  defaultoctave;
  int  defaultduration;
  int  tempo;
}SilentNight = {
                 {"f#.,8g#,f#,d#.,p.,f#.,8g#,f#,d#.,p.,2c#6,c#6,a#.,p.,2b,b,f#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,"},{"d#.,p.,2c#6,c#6,e.6,8c#6,a#,2b.,2d#6,p.,b,f#,d#,f#.,8e,c#,b.4,1p"},
                 5,
                 DURATION_4,
                 140
const struct
  char tune1[128];
  char tune2[75];
  int  defaultoctave;
  int  tempo;
}JingleBells = {
                 {"8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8e.,8d.,8d.,8e.,d.,g.,8e.,8e.,e.,8e.,8e.,e.,8e.,"},{"8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8g.,8g.,8f.,8d.,c.,1p"},
                 5,
                 DURATION_4,
                 180
/* Function Prototypes */
void InitTimer(void);
int PlayMelody();
void PlayNote(long note, int octave, int duration);
char get_char_from_tune(long index);
int get_tempo(void);
int get_defaultoctave(void);
int get_defaultduration(void);
void Melody_Task(void);
// Start of Code
  DESCRIPTION:  This function handles checking for button presses
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  TRISCbits.TRISC2 = 0;
  InitTimer();
  Melody_Pointer = JINGLEBELLS;
    Melody_Task();
  DESCRIPTION:  This function handles the playing of a melody
  RETURN:       True if the melody is still active or False if its complete
  ALGORITHM:    none
  NOTES:        none
int PlayMelody(void)
  int octave = 0;
  int duration = 0;
  long note = 0;
  // Check for a valid Melody
  if (Melody_Pointer >= LAST_MELODY)
    // Reset the Melody to the start
    Melody_Pointer = 0;
  // Load notes while we have enough room
  while (Notestat.Count < MAX_NOTE_BUFFER_SIZE)
    // Is this the first note?
    if (Note_Index == 0xFFFF)
      Tempo = get_tempo();
      Note_Index = 0;
    // Set Default duration
    duration = get_defaultduration();
    // Set Default Octave
    octave = get_defaultoctave();
    // Play a bit of slience between notes
    if (get_char_from_tune(Note_Index) == ',')
      PlayNote(0, 4, DURATION_32);
      Note_Index++;
      return(TRUE);
    // We are checking the duration
    else if ((get_char_from_tune(Note_Index) == '3') && (get_char_from_tune(Note_Index+1) == '2'))
      duration = DURATION_32;
      Note_Index += 2;
    else if ((get_char_from_tune(Note_Index) == '1') && (get_char_from_tune(Note_Index+1) == '6'))
      duration = DURATION_16;
      Note_Index += 2;
    else if (get_char_from_tune(Note_Index) == '8')
      duration = DURATION_8;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '4')
      duration = DURATION_4;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '2')
      duration = DURATION_2;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '1')
      duration = DURATION_1;
      Note_Index++;
    // Now we get the note
    switch (get_char_from_tune(Note_Index++))
      case 'c':
        if (get_char_from_tune(Note_Index) == '#')
          note = NOTE_C_SHARP;
          Note_Index++;
          note = NOTE_C;
      case 'd':
          note = NOTE_D_SHARP;
          Note_Index++;
          note = NOTE_D;
      case 'e':
        note = NOTE_E;
      case 'f':
          note = NOTE_F_SHARP;
          Note_Index++;
          note = NOTE_F;
      case 'g':
          note = NOTE_G_SHARP;
          Note_Index++;
          note = NOTE_G;
      case 'a':
          note = NOTE_A_SHARP;
          Note_Index++;
          note = NOTE_A;
      case 'b':
        note = NOTE_B;
      case 'p': // slience
        note = NOTE_SILENCE;
    // See if this note is 1.5x the duration
    if (get_char_from_tune(Note_Index) == '.')
      // Use the MSB to signify 1.5x
      duration |= 0x80;
      Note_Index++;
    // Get the octave
    switch (get_char_from_tune(Note_Index))
      case '4':
        octave = 4;
        Note_Index++;
      case '5':
        octave = 5;
        Note_Index++;
      case '6':
        octave = 6;
        Note_Index++;
      case '7':
        octave = 7;
        Note_Index++;
      default:
    // Sometimes the duration multiplier comes after the octave
      /* Duration 1.5x */
      duration |= 0x80;
      Note_Index++;
    // Play the note (we actually just load it in a buffer
    PlayNote(note, octave, duration);
    // Is this the end?
    if (get_char_from_tune(Note_Index) == 0)
      return(FALSE);
  return(TRUE);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  long duration_count;
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  // Process Note Duration
  duration_count = 256;
  duration_count >>= (duration & 0x7F);
  // If duration is 1.5x add .5 to duration
  if (duration & 0x80)
    duration_count += (duration_count >> 1);
  // Add the note to our buffer
  NoteBuffer[Notestat.Tail].note = note;
  NoteBuffer[Notestat.Tail].duration = duration_count;
  Notestat.Tail++;
  Notestat.Tail &= NOTE_ROLLOVER_MASK;
  Notestat.Count++;
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  setup_timer_0(RTCC_DIV_256 | RTCC_8_BIT);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
  enable_interrupts(INT_CCP1);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  switch (Melody_Pointer)
    case SILENTNIGHT:
      if (index<127)
        return (SilentNight.tune1[index]);
        return (SilentNight.tune2[index-127]);
    case JINGLEBELLS:
      if (index<127)
        return (JingleBells.tune1[index]);
        return (JingleBells.tune2[index-127]);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
int get_tempo(void)
    case SILENTNIGHT:
      return (SilentNight.tempo);
    case JINGLEBELLS:
      return (JingleBells.tempo);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case SILENTNIGHT:
      return (SilentNight.defaultoctave);
    case JINGLEBELLS:
      return (JingleBells.defaultoctave);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
    case SILENTNIGHT:
      return (SilentNight.defaultduration);
    case JINGLEBELLS:
      return (JingleBells.defaultduration);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (PlayMelodyFlag)
    if (PlayMelody()==0)
      Melody_Pointer++;
// ISR routines
#int_ccp1
  DESCRIPTION:  This function controls the PWM of the piezo speaker
  RETURN:       none
  ALGORITHM:    none
  NOTES:  If you do not wish to use C2 as the output, then you will need
          to toggle your output here.  Make sure that you change the CCP
          setup not to toggle the C2 output if this is the case
void ccp1_isr (void)
  CCP_1 += Note_Ticks;
#if defined(__PCM__)
  output_toggle(PIN_C2);
#endif
  DESCRIPTION:  This function is used to control the duration of the note
  RETURN:       none
  ALGORITHM:    none
  NOTES:  I store the notes in a buffer so that the main loop has other
          time to do stuff with out have to sit at wait for a note to
          complete.
#int_timer0
void timer0_isr (void)
  // Preload a value for TMR0 so that we can control how long it takes to
  // trigger an interrupt
  TMR0 = Tempo;
  // Is a note playing?
  if (DurationCount)
    DurationCount--;
    if (!DurationCount)
      setup_ccp1(CCP_OFF);
  // Note is finished playing, do we have anymore in our buffer?
  else if (Notestat.Count)
    DurationCount = NoteBuffer[Notestat.Head].duration;
    Note_Ticks = NoteBuffer[Notestat.Head].note;
    Notestat.Count--;
    Notestat.Head++;
    Notestat.Head &= NOTE_ROLLOVER_MASK;
    CCP_1 = TMR1 + Note_Ticks;
    if (Note_Ticks)
      /* Setup the CCP module to toggle the output pin c2 */
      setup_ccp1(CCP_COMPARE_TOGGLE_MATCH);
#else
      setup_ccp1(CCP_COMPARE_INT);
#endif
    // Nope, we are all through so disable the PWM
Page 2 of 2
