Gizz
Joined: 15 Jun 2004 Posts: 21 Location: Nottingham UK
| Timer 2 woes... |
Posted: Sat Nov 20, 2004 8:46 am |
Hello all.
Tearing my hair out here
I have the following:
16LF877A at 10MHz, 3.35V
PCM 3.202
Trying to get Timer 2 to wiggle the E0 line at 96KHz (with a view to using this interrupt handler to poll kbhit for a software UART).
Here is my code:
#include <16F877A.H>
#fuses HS, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOLVP
#use delay(clock=10000000)
enable_interrupts(global);
// we need 96kHz, and the xtal is 10MHz.
// Timer2 gets fosc/4 = 2.5MHz
// So no further divide, and use 26th overflow
setup_timer_2(T2_DIV_BY_1, 26, 1);
enable_interrupts(int_timer2);
for(;;)
#int_timer2
void timer2_isr()
output_high(PIN_E0);
output_low(PIN_E0);
When I stick a scope on pin E0 I see pulses 1.6us wide and 25us apart. It should be 96kHz which is 11us apart or so!!!
Furthermore when I change the values for the period on the setup timer call, the E0 output period stays the same!
With
setup_timer_2 ( T2_DIV_BY_4, 0xc0, 2);
stolen from the help page I get 612us not the expected 910us.
Yes my scope is in calibration. Yes the chip *is* running at 10MHz. I run this program
for(;;)
delay_us(10);
output_low(PIN_E0);
and the E0 pin goes high for 11us, which with the setup time for the output is about right.
Any ideas? |
Mark
Posted: Sat Nov 20, 2004 8:59 am |
| Code: | setup_timer_2 ( T2_DIV_BY_4, 0xc0, 2);
10MHz / 4 = 2.5MHz is the timer2 increment rate.
Now you prescale with div by 4
2.5MHz / 4 = 625KHz
Now a post scale of 2
625KHz / 2 = 312.5KHz
and finally a period of 0xC0
312.5KHz / 0xC0 = 1.627KHz for a period of 614.62814 us
Code works just fine!
Now your orginal problem has to do with the overhead in handling ints. Simple answer, you just can't do it 11us or 27.5 instructions. Take a look at the lst file and see how many instructions the int handler consumes. |
Gizz
| Latency!Aaargh! |
Posted: Sat Nov 20, 2004 9:32 am |
Mark, thanks for that. Damn! Forgot about the dreaded interrupt setup time!
I guess the only way to poll kbhit at '10 times the bit rate' for a 9600 baud soft UART is to do it in a tight loop? |
