I have one program that will not run on it's own unless I keep the DEBUG and ICD=TRUE statements alive when compiling. I have other programs where I take those two statements out (change DEBUG to NODEBUG) and they work great solo. This an 18F252 chip program.
Haplo
Posted: Fri Nov 12, 2004 7:27 pm
What software and hardware are you using for programming your target?
Posted: Sat Nov 13, 2004 1:16 pm
What clock setup are you running? Are you using 4xPLL?
ljbeng
Posted: Mon Nov 15, 2004 8:19 am
I have compiled it on many version but my latest is 3.212 It doesn't matter if I use the CCS ICD or QuickWriter, the chip will not start up unless I keep both lines in there. I have tried to narrow it down to one line or the other but it takes both. I am using a 20MHz crystal and an 18F252.
Haplo
Posted: Mon Nov 15, 2004 4:08 pm
Watchdog! On some chips having DEVICE ICD=TRUE automatically disables the watchdog. Maybe that is your problem?
