How to use PWM play the song (.mid) to speaker?
saroch
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Nov 10, 2004 10:33 am     Reply with quote
I use PIC16F877. I want to play the song (*.mid) to the speaker and I know that PIC has PWM module that can play this song. But how to make it?
thank in advance
saroch
Mark
PostPosted: Wed Nov 10, 2004 11:37 am     Reply with quote
I have used this method before to make one of our products play Christmas tunes.
http://www.beyondlogic.org/pic/ringtones.htm
saroch
PostPosted: Wed Nov 10, 2004 9:29 pm     Reply with quote
Hi Mark,
I tried your code (ringtone.HEX) with 16F877 but it doesn't work !!
I used Xtal = 20 MHz and connected pin33 (RB0) to C = 1 uF and to speaker then shorted it to gnd.
But when 5V was applied, I didn't hear anything from the speaker.
pls help me
thx
,saroch
Mark
PostPosted: Wed Nov 10, 2004 11:08 pm     Reply with quote
Post the code that you used.
saroch
PostPosted: Thu Nov 11, 2004 7:22 am     Reply with quote
Sorry I give a wrong information.
I used code loaded from website that you gave to me.
So I burnt PIC with ringtone.HEX from your website without changing anything.
thx
Mark
PostPosted: Thu Nov 11, 2004 7:32 am     Reply with quote
Firstly, thats not my website.
Secondly, I took that code, ported it to an 18F pic using the C18 compiler and play tunes using a piezo.
So it will work with a little work. Never tried the hex file. Keep in mind that you'll need a very small speaker.
saroch
PostPosted: Fri Nov 12, 2004 10:36 am     Reply with quote
how can i convert this code form HI_TECH PIC to CCS C ?
#include <pic.h>
#define TONE    RB0
void InitTimer(void);
void delayms(unsigned char cnt);
void PlayNote(unsigned short note, unsigned char octave, unsigned int duration);
unsigned char beep;
unsigned char preloadTMR1L;
unsigned char preloadTMR1H;
unsigned short TMR0Count;
unsigned char beat_speed;
    unsigned int pointer = 0;
    unsigned int octave = 0;
    unsigned int duration = 0;
    unsigned short note = 0;
    unsigned int defaultoctave = 0;
    unsigned int defaultduration = 0;
    /* Mission Impossible */
    const unsigned char static Melody[] = {"16d5,16d#5,16d5,16d#5,16d5,16d#5,16d5,16d5,16d#5,16e5,16f5,16f#5,16g5,8g5,4p,8g5,4p,8a#5,8p,8c6,8p,8g5,4p,8g5,4p,8f5,8p,8p,8g5,4p,4p,8a#5,8p,8c6,8p,8g5,4p,4p,8f5,8p,8f#5,8p,8a#5,8g5,1d5"};
    defaultoctave = 6;
    defaultduration = 4;
    beat_speed = 150;
    TRISB0 = 0;     /* Make TONE an output */
    beep = 0;
    InitTimer();
    PEIE = 1;
    GIE = 1;      /* Enable General Purpose Interrupts */
    do {
        octave = defaultoctave;    /* Set Default Octave */
        if ((Melody[pointer] == '3') && (Melody[pointer+1] == '2')) {
            duration = 32;
            pointer += 2;
        else if ((Melody[pointer] == '1') && (Melody[pointer+1] == '6')) {
            duration = 16;
            pointer += 2;
        else if (Melody[pointer] == '8') {
            duration = 8;
            pointer++;
        else if (Melody[pointer] == '4') {
            duration = 4;
            pointer++;
        else if (Melody[pointer] == '2') {
            duration = 2;
            pointer++;
        else if (Melody[pointer] == '1') {
            duration = 1;
            pointer++;
        } else duration = defaultduration;
        if (Melody[pointer + 1] == '#') {
            /* Process Sharps */
            switch (Melody[pointer]) {
                case 'a' : note = 10726;
                case 'c' : note = 9019;
                case 'd' : note = 8035;
                case 'f' : note = 6757;
                case 'g' : note = 6024;
            pointer +=2;
        } else {
                case 'a' : note = 11364;
                case 'b' : note = 10123;
                case 'c' : note = 9555;
                case 'd' : note = 8513;
                case 'e' : note = 7584;
                case 'f' : note = 7158;
                case 'g' : note = 6378;
                case 'p' : note = 0;
            pointer++;
        if (Melody[pointer] == '.') {
            /* Duration 1.5x */
            duration = duration + 128;
            pointer++;
            octave = 4;
            pointer++;
        } else if (Melody[pointer] == '5') {
            octave = 5;
            pointer++;
        } else     if (Melody[pointer] == '6') {
            octave = 6;
            pointer++;
        } else     if (Melody[pointer] == '7') {
            octave = 7;
            pointer++;
            /* Duration 1.5x */
            pointer++;
        PlayNote(note, octave, duration);
     } while (Melody[pointer++] == ',');
    /* Wait until last note has played */
    while(TMR0Count) { };
    beep = 0;
    /* Loop */
    while(1) {};
    /* Process octave */
    switch (octave) {
        case 4 : /* Do noting */
        case 5 : /* %2 */
             note = note >> 1;
        case 6 : /* %4 */
             note = note >> 2;
        case 7 : /* %8 */
             note = note >> 4;
    beep = 0;
    /* Process New Note Frequency */
    if (note) {
        note = ~note;
        preloadTMR1L = (note & 0xFF);
        preloadTMR1H = ((note & 0xFF00) >> 8);
    /* Process Note Duration */
    TMR0Count = 255/(duration & 0x7F);
    /* If duration is 1.5x add .5 to duration */
    if (duration & 0x80) TMR0Count = (TMR0Count + (TMR0Count >> 1));
    if (note) beep = 1;
    /* Initialise Timer 0 */
    OPTION = 0b11010111;  /* Set TMR0 to Internal CLk, 1:256 */
    T0IF = 0;             /* Clear TMR0 Flag, ready for use */
    T0IE = 1;             /* Enable Timer Overflow Interrupt */
    /* Initialise Timer 1 */
    T1CON = 0b00000001;   /* Counter Enabled, Using Ext Pin 1:1 Prescaler */
    TMR1IF = 0;           /* Clear Flag */
    TMR1IE = 1;           /* Enable Interrupt */
void interrupt interr(void)
    if (T0IF) {
        TMR0 = beat_speed;
        if (TMR0Count) TMR0Count--;
        T0IF = 0;
    if (TMR1IF) {
        if (beep) TONE = !TONE;
        else      TONE = 0;
        TMR1H = preloadTMR1H;
        TMR1L = preloadTMR1L;
thx very much for an advice
Mark
PostPosted: Fri Nov 12, 2004 11:12 am     Reply with quote
Okay, here is something I did based on information from that site.
/*            RTTTL Ring Tone Player for Microchip Microcontrollers          */
/* This program was designed to run on the PICDEM2 Plus demo board from      */
/* Microchip.        */
/* Usage:        */
/*         S3 - Selects Melody                                               */
/*         S2 - Starts/Stops Melody                                          */
/* This code was designed for a clock speed of 20MHz                         */
/* The target device was a PIC18F452.                                        */
/* You can use the PIC16F877 by changing the setup of CCP1 to                */
/* CCP_COMPARE_INT.  You will also need to toggle the output pin in the      */
/* CCP1 interrupt routine.                                                   */
/* Many of the tunes were downloaded from "www.mrtones.com"                  */
#case
#list
#include "18F452.h"
//#include "18F6720.h"
#device *=16
#define CLOCKSPEED     20000000
#define CCP_COMPARE_TOGGLE_MATCH        2
#use delay(CLOCK=CLOCKSPEED)
#fuses HS, NOWDT, NOLVP, PUT
// Include this file after our #use delay
#include "lcd.c"
#define TMR1_PRESCALE  8
#define NOTE_C_SHARP   (((CLOCKSPEED/4)/277.18)/TMR1_PRESCALE)            // 277.18Hz
#define NOTE_D_SHARP   (((CLOCKSPEED/4)/311.13)/TMR1_PRESCALE)            // 311.13 Hz
#define NOTE_F_SHARP   (((CLOCKSPEED/4)/369.99)/TMR1_PRESCALE)            // 369.99 Hz
#define NOTE_G_SHARP   (((CLOCKSPEED/4)/415.30)/TMR1_PRESCALE)            // 415.30 Hz
#define NOTE_A_SHARP   (((CLOCKSPEED/4)/466.16)/TMR1_PRESCALE)            // 466.16 Hz
#define NOTE_C         (((CLOCKSPEED/4)/261.63)/TMR1_PRESCALE)            // 261.63 Hz
#define NOTE_D         (((CLOCKSPEED/4)/293.66)/TMR1_PRESCALE)            // 293.66 Hz
#define NOTE_E         (((CLOCKSPEED/4)/329.63)/TMR1_PRESCALE)            // 329.63 Hz
#define NOTE_F         (((CLOCKSPEED/4)/349.23)/TMR1_PRESCALE)            // 349.23 Hz
#define NOTE_G         (((CLOCKSPEED/4)/392.00)/TMR1_PRESCALE)            // 392.00 Hz
#define NOTE_A         (((CLOCKSPEED/4)/440.00)/TMR1_PRESCALE)            // 440.00 Hz
#define NOTE_B         (((CLOCKSPEED/4)/493.88)/TMR1_PRESCALE)            // 493.88 Hz
#define NOTE_SILENCE   0
#define DURATION_32   5    // Duration = 2^x
#define DURATION_16   4    // Duration = 2^x
#define DURATION_8    3    // Duration = 2^x
#define DURATION_4    2    // Duration = 2^x
#define DURATION_2    1    // Duration = 2^x
#define DURATION_1    0    // Duration = 2^x
typedef enum
  JOLLYOLDSTNICK,
  MOMMYKISSSANTA,
  LETITSNOW,
  AWAYINAMANGER,
  OCHRISTMASTREE,
  MERRYCHRISTMAS,
  SANTACOMING,
  OCOMEALLYEFAITHFUL,
  DECKTHEHALLS,
  SLEIGH,
  RUDOLPH,
  TWELVEDAYSOFCHRISTMAS,
  FROSTYTHESNOWMAN,
  SILENTNIGHT,
  JINGLEBELLS,
  LAST_MELODY
}MELODIES;
typedef struct
  int Head;
  int Tail;
  int Count;
} NOTESTAT;
typedef struct
  long note;
  long duration;
}NOTE_DEF;
struct
  int TRISC0:1;
  int TRISC1:1;
  int TRISC2:1;
  int TRISC3:1;
  int TRISC4:1;
  int TRISC5:1;
  int TRISC6:1;
  int TRISC7:1;
}TRISCbits;
#locate TRISCbits = 0xF94
long TMR1;
#locate TMR1 = 0xFCE
int TMR1L;
#locate TMR1L = 0xFCE
int TMR1H;
#locate TMR1H = 0xFCF
int TMR0;
#locate TMR0 = 0xFD6
#define   MAX_NOTE_BUFFER_SIZE  4
#define   NOTE_ROLLOVER_MASK     0b00000011
NOTE_DEF  NoteBuffer[MAX_NOTE_BUFFER_SIZE];
NOTESTAT  Notestat = {0,0,0};
long      DurationCount=0;
int       Tempo=0;
long      Note_Ticks=0;
MELODIES  Melody_Pointer;
long      Note_Index = 0xFFFF;
BOOLEAN   PlayMelodyFlag = TRUE;
int       Read_Button_Count = 0;
const struct
  char tune[107];
  int  defaultoctave;
  int  defaultduration;
  int  tempo;
}JollyOldStNick ={
                   {"a,a,a,a,g,g,2g,f,f,f,f,1a,d,d,d,d,c,c,2f,g,f,g,a,1g,a,a,a,a,g,g,2g,f,f,f,f,1a,d,d,d,d,c,c,2f,g,f,g,a,1f,1p"},
                   5,
                   DURATION_4,
                   160
const struct
  char tune[263];
  int  defaultoctave;
  int  tempo;
}MommyKissSanta ={
                   {"2c.,d,e,g,a,8c6,2b.,g,1e,a,g,e,c,a,g,e,8c.,1b.,f,e,d,d.,8c#.,2d.,8a.,16b.,8a.,g.,f#.,8a.,2g.,e,d,e,f#,g,a,g#,a,a#,b,a,f,8e,2d.,g,2c.,d,e,g,a,8c6,1b,g,1e,a,g,2e,16c,a,g,e,8c.,1a,16g#,8a.,16b,c6,8c.6,c6,8d.6,1b,f#,8a.,16a,g,f,8e,2d,8e.,2f,g,a,8c.6,a,2c6,2d6,1c6,1p"},
                   5,
                   DURATION_4,
                   160
const struct
  char tune[218];
  int  defaultoctave;
  int  tempo;
}LetItSnow ={
              {"8c,8c,8c6,8c6,a#,a,g,f,2c,8c,16c,g.,8f,g.,8f,e,2c,d,8d6,8d6,c6,a#,a,2g.,8e.6,16d6,c6,8c.6,16a#,a,8a#.,16a,2f.,c,8c6,8c6,a#,a,g,f,2c,8c.,16c,g.,8f,g.,8f,e,2c,d,8d6,8d6,c6,a#,a,2g.,8e.6,16d6,c6,8c.6,16a#,a,8a.,16g,2f,1p"},
              5,
              DURATION_4,
              125
const struct
  char tune[175];
  int  defaultoctave;
  int  tempo;
}AwayInAManger ={
                  {"d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,d.,8e,d,d,a,f#,e,d,g,2b,d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,c.6,8b,a,b,a,g,a,e,f#,2g,d6,d.6,8c6,b,b.,8a,g,g,f#,e,2d,d,d.,8e,d,d,a,f#,e,d,g,2b,1p"},
                  5,
                  DURATION_4,
                  112
const struct
  char tune[243];
  int  defaultoctave;
  int  tempo;
}OChristmasTree = {
                    {"4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,4f.,4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,2f,16p,c.6,c.6,a.,2d6,16p,c.6,c.6,a#.,2a#,16p,a#.,a#.,g.,2c6,16p,a#.,a#.,a.,4a.,4c.,4f,f,4f.,4g.,4a,a,2a,16p,a.,g.,a.,4a#.,4e.,4g.,2f,1p"},
                    5,
                    DURATION_8,
                    160
const struct
  char tune[159];
  int  defaultoctave;
  int  tempo;
}MerryChristmas = {
                    {"4c,4f,f,g,f,e,4d,4a#4,4d,4g,g,a,g,f,4e,4c,4e,4a,a,a#,a,g,4f,4d,c,c,4d,4g,4e,4f.,p,4c,4f,4f,4f,4e.,p,4e,4f,4e,4d,4c.,p,4c,4a,g,g,f,f,4c6,4c,c,c,4d,4g,4e,4f.,1p"},
                    5,
                    DURATION_8,
                    140
const struct
  char tune[110];
  int  defaultoctave;
  int  tempo;
}SantaComing = {
                 {"4g,8e.,f.,4g,4g.,p,g.,8a.,b.,4c6,4c.6,8p,8e.,f.,4g,4g.,p,g.,8a.,g.,4f,4f.,8p,4e,4g,4c,4e,4d,4f.,8p,4b4,4c.,1p"},
                 5,
                 DURATION_16,
                 160
const struct
  char tune[226];
  int  defaultoctave;
  int  tempo;
}OComeAllYeFaithful = {
                        {"c.,4c.,g.5,c.,4d.,4g.5,e.,d.,e.,f.,e.,d.,c.,4c.,b.5,a.5,b.5,c.,d.,e.,4b.5,4a5,16g.5,4g.5,4p.,4g.,f.,e.,4f.,4e.,d.,e.,c.,d.,4b5,16a.5,g.5,c.,c.,b.5,c.,d.,4c.,g.5,e.,e.,d.,e.,f.,4e.,d.,e.,f.,e.,d.,c.,4b.5,c.,f.,e.,4d,16c.,4c,1p"},
                        6,
                        DURATION_8,
                        112
const struct
  char tune[156];
  int  defaultoctave;
  int  tempo;
}DeckTheHalls = {
                  {"c6.,8a#,a,g,f,g,a,f,8g,8a,8a#,8g,a.,8g,f,e,2f,16p,c6.,8a#,a,g,f,g,a,f,8g,8a,8a#,8g,a.,8g,f,e,2f,16p,g.,8a,a#,g,a.,8a#,c6,g,8a,8b,c6,8d6,8e6,f6,e6,d6,2c6,1p"},
                  5,
                  DURATION_4,
                  160
  /* Sleigh */
const struct
  char tune[202];
  int  defaultoctave;
  int  tempo;
}Sleigh = {
            {"8b,8b,8b,8b,8c#6,b,g#,8e,8f#,8g#,f#,e,8c#,2b4,4p,b4,c#,e,g#,8b,8c#6,b,g#,f#,e,8f,f#,g#,f#,e,8c#,2e,8p,8b,8b,8b,8c#6,b,g#,8e,8f#,8g#,f#,e,8c#,2b4,4p,b4,c#,e,g#,8b,8c#6,b,g#,f#,e,8f#,f#,g#,f#,e,8c#,8e,1p"},
            5,
            DURATION_16,
            112
  /* Rudolph */
const struct
  char tune[208];
  int  defaultoctave;
  int  tempo;
}Rudolph = {
             {"d,e,16d,b.5,g.,e.,4d.,p.,d,16e,d,16e,d.,g.,4f#.,4p.,c,d.,16c,a.5,f#.,e.,4d.,p.,d,16e,d,16e,d.,e.,4b.5,4p.,d,e.,16d,b.5,g.,e.,d.,p.,d,16e,d,16e,d.,g.,f#.,4p.,c,d.,16c,a.5,f#.,e.,4d.,p.,d,16e,d,16e,d.,a.,g.,1p"},
             6,
             DURATION_8,
             112
const struct
  char tune[175];
  int  defaultoctave;
  int  tempo;
}TwelveDaysOfChristmas = {
                           {"c.,c.,8c,f.,f.,8f.,e.,f.,g.,a.,a#.,g.,4a,p,a#.,8c.6,d.6,a#.,a.,f.,8g.,4f.,8p,c.,c.,c.,f.,f.,f.,8f.,e.,f.,g.,a.,a#.,g.,4a.,8c.6,g.,a.,8a#.,a.,a#.,8c.6,d.6,a#.,a.,f.,8g.,4f.,1p"},
                           5,
                           DURATION_16,
                           112
const struct
  char tune[176];
  int  defaultoctave;
  int  tempo;
}FrostyTheSnowman = {
                      {"g.,8p,e.,8f,g,c.6,8p,8b,8c6,d6,c6,b,a,2g,p,8b,8c6,d6,c6,b,a,8g,c6,e.,8g,8a,g,f,e,d,g.,2p,g.,8p,e.,8f,g,c.6,8p,8b,8c6,d6,c6,b,a,2g,p,8b,8c6,d6,c6,b,a,g,c6,e,8g,8a,g,f,e,d,c.,1p"},
                      5,
                      DURATION_4,
                      180
const struct
  char tune[192];
  int  defaultoctave;
  int  tempo;
}SilentNight = {
                 {"f#.,8g#,f#,d#.,p.,f#.,8g#,f#,d#.,p.,2c#6,c#6,a#.,p.,2b,b,f#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2g#,g#,b.,8a#,g#,f#.,8g#,f#,d#.,p.,2c#6,c#6,e.6,8c#6,a#,2b.,2d#6,p.,b,f#,d#,f#.,8e,c#,b.4,1p"},
                 5,
                 DURATION_4,
                 140
const struct
  char tune[202];
  int  defaultoctave;
  int  tempo;
}JingleBells = {
                 {"8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8e.,8d.,8d.,8e.,d.,g.,8e.,8e.,e.,8e.,8e.,e.,8e.,8g.,c,16d.,2e,p,8f.,8f.,f,16f.,8f.,8e.,8e.,16e.,16e.,8g.,8g.,8f.,8d.,c.,1p"},
                 5,
                 DURATION_4,
                 180
/* Function Prototypes */
int PlayMelody();
void PlayNote(long note, int octave, int duration);
char get_char_from_tune(long index);
int get_tempo(void);
int get_defaultoctave(void);
int get_defaultduration(void);
void display_melody_name(void);
void Melody_Task(void);
void Button_Task(void);
void Check_Button_Press(void);
// Start of Code
  DESCRIPTION:  This function handles checking for button presses
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  TRISCbits.TRISC2 = 0;
  InitTimer();
  lcd_init();
  Melody_Pointer = JINGLEBELLS;
  display_melody_name();
    Button_Task();
    Melody_Task();
  DESCRIPTION:  This function handles the playing of a melody
  RETURN:       True if the melody is still active or False if its complete
  ALGORITHM:    none
  NOTES:        none
int PlayMelody(void)
  int octave = 0;
  int duration = 0;
  long note = 0;
  // Check for a valid Melody
  if (Melody_Pointer >= LAST_MELODY)
    // Reset the Melody to the start
    Melody_Pointer = 0;
  // Load notes while we have enough room
  while (Notestat.Count < MAX_NOTE_BUFFER_SIZE)
    // Is this the first note?
    if (Note_Index == 0xFFFF)
      Tempo = get_tempo();
      Note_Index = 0;
    // Set Default duration
    duration = get_defaultduration();
    // Set Default Octave
    octave = get_defaultoctave();
    // Play a bit of slience between notes
    if (get_char_from_tune(Note_Index) == ',')
      PlayNote(0, 4, DURATION_32);
      Note_Index++;
      return(TRUE);
    // We are checking the duration
    else if ((get_char_from_tune(Note_Index) == '3') && (get_char_from_tune(Note_Index+1) == '2'))
      duration = DURATION_32;
      Note_Index += 2;
    else if ((get_char_from_tune(Note_Index) == '1') && (get_char_from_tune(Note_Index+1) == '6'))
      duration = DURATION_16;
      Note_Index += 2;
    else if (get_char_from_tune(Note_Index) == '8')
      duration = DURATION_8;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '4')
      duration = DURATION_4;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '2')
      duration = DURATION_2;
      Note_Index++;
    else if (get_char_from_tune(Note_Index) == '1')
      duration = DURATION_1;
      Note_Index++;
    // Now we get the note
    switch (get_char_from_tune(Note_Index++))
      case 'c':
        if (get_char_from_tune(Note_Index) == '#')
          note = NOTE_C_SHARP;
          Note_Index++;
          note = NOTE_C;
      case 'd':
          note = NOTE_D_SHARP;
          Note_Index++;
          note = NOTE_D;
      case 'e':
        note = NOTE_E;
      case 'f':
          note = NOTE_F_SHARP;
          Note_Index++;
          note = NOTE_F;
      case 'g':
          note = NOTE_G_SHARP;
          Note_Index++;
          note = NOTE_G;
      case 'a':
          note = NOTE_A_SHARP;
          Note_Index++;
          note = NOTE_A;
      case 'b':
        note = NOTE_B;
      case 'p': // slience
        note = NOTE_SILENCE;
    // See if this note is 1.5x the duration
    if (get_char_from_tune(Note_Index) == '.')
      // Use the MSB to signify 1.5x
      duration |= 0x80;
      Note_Index++;
    // Get the octave
    switch (get_char_from_tune(Note_Index))
      case '4':
        octave = 4;
        Note_Index++;
      case '5':
        octave = 5;
        Note_Index++;
      case '6':
        octave = 6;
        Note_Index++;
      case '7':
        octave = 7;
        Note_Index++;
      default:
    // Sometimes the duration multiplier comes after the octave
      /* Duration 1.5x */
      duration |= 0x80;
      Note_Index++;
    // Play the note (we actually just load it in a buffer
    // Is this the end?
    if (get_char_from_tune(Note_Index) == 0)
      return(FALSE);
    return(TRUE);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  long duration_count;
  // Process octave
  switch (octave)
    case 4 :
    case 5 :
      note = note >> 1;
    case 6 :
      note = note >> 2;
    case 7 :
      note = note >> 4;
  // Process Note Duration
  duration_count = 256;
  duration_count >>= (duration & 0x7F);
  // If duration is 1.5x add .5 to duration
    duration_count += (duration_count >> 1);
  // Add the note to our buffer
  NoteBuffer[Notestat.Tail].note = note;
  NoteBuffer[Notestat.Tail].duration = duration_count;
  Notestat.Tail++;
  Notestat.Tail &= NOTE_ROLLOVER_MASK;
  Notestat.Count++;
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  setup_timer_0(RTCC_DIV_256 | RTCC_8_BIT);
  setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
  setup_timer_2(T2_DIV_BY_4, 250, 5);
  enable_interrupts(INT_CCP1);
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  switch (Melody_Pointer)
    case JOLLYOLDSTNICK:
      return (JollyOldStNick.tune[index]);
    case MOMMYKISSSANTA:
      return (MommyKissSanta.tune[index]);
    case LETITSNOW:
      return (LetItSnow.tune[index]);
    case AWAYINAMANGER:
      return (AwayInAManger.tune[index]);
    case OCHRISTMASTREE:
      return (OChristmasTree.tune[index]);
    case MERRYCHRISTMAS:
      return (MerryChristmas.tune[index]);
    case SANTACOMING:
      return (SantaComing.tune[index]);
    case OCOMEALLYEFAITHFUL:
      return (OComeAllYeFaithful.tune[index]);
    case DECKTHEHALLS:
      return (DeckTheHalls.tune[index]);
    case SLEIGH:
      return (Sleigh.tune[index]);
    case RUDOLPH:
      return (Rudolph.tune[index]);
    case TWELVEDAYSOFCHRISTMAS:
      return (TwelveDaysOfChristmas.tune[index]);
    case FROSTYTHESNOWMAN:
      return (FrostyTheSnowman.tune[index]);
    case SILENTNIGHT:
      return (SilentNight.tune[index]);
    case JINGLEBELLS:
      return (JingleBells.tune[index]);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
int get_tempo(void)
      return (JollyOldStNick.tempo);
      return (MommyKissSanta.tempo);
    case LETITSNOW:
      return (LetItSnow.tempo);
    case AWAYINAMANGER:
      return (AwayInAManger.tempo);
      return (OChristmasTree.tempo);
      return (MerryChristmas.tempo);
    case SANTACOMING:
      return (SantaComing.tempo);
      return (OComeAllYeFaithful.tempo);
    case DECKTHEHALLS:
      return (DeckTheHalls.tempo);
    case SLEIGH:
      return (Sleigh.tempo);
    case RUDOLPH:
      return (Rudolph.tempo);
      return (TwelveDaysOfChristmas.tempo);
      return (FrostyTheSnowman.tempo);
    case SILENTNIGHT:
      return (SilentNight.tempo);
    case JINGLEBELLS:
      return (JingleBells.tempo);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
      return (JollyOldStNick.defaultoctave);
      return (MommyKissSanta.defaultoctave);
    case LETITSNOW:
      return (LetItSnow.defaultoctave);
    case AWAYINAMANGER:
      return (AwayInAManger.defaultoctave);
      return (OChristmasTree.defaultoctave);
      return (MerryChristmas.defaultoctave);
    case SANTACOMING:
      return (SantaComing.defaultoctave);
      return (OComeAllYeFaithful.defaultoctave);
    case DECKTHEHALLS:
      return (DeckTheHalls.defaultoctave);
    case SLEIGH:
      return (Sleigh.defaultoctave);
    case RUDOLPH:
      return (Rudolph.defaultoctave);
      return (TwelveDaysOfChristmas.defaultoctave);
      return (FrostyTheSnowman.defaultoctave);
    case SILENTNIGHT:
      return (SilentNight.defaultoctave);
    case JINGLEBELLS:
      return (JingleBells.defaultoctave);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
      return (JollyOldStNick.defaultduration);
      return (MommyKissSanta.defaultduration);
    case LETITSNOW:
      return (LetItSnow.defaultduration);
    case AWAYINAMANGER:
      return (AwayInAManger.defaultduration);
      return (OChristmasTree.defaultduration);
      return (MerryChristmas.defaultduration);
    case SANTACOMING:
      return (SantaComing.defaultduration);
      return (OComeAllYeFaithful.defaultduration);
    case DECKTHEHALLS:
      return (DeckTheHalls.defaultduration);
    case SLEIGH:
      return (Sleigh.defaultduration);
    case RUDOLPH:
      return (Rudolph.defaultduration);
      return (TwelveDaysOfChristmas.defaultduration);
      return (FrostyTheSnowman.defaultduration);
    case SILENTNIGHT:
      return (SilentNight.defaultduration);
    case JINGLEBELLS:
      return (JingleBells.defaultduration);
    default:
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (PlayMelodyFlag)
    if (!PlayMelody())
      Melody_Pointer++;
  DESCRIPTION:  This function displays the title of the melody on the LCD
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  // Clear the screen and make sure that we are at the top
  lcd_putc("\f");
  lcd_gotoxy(0,1);
  // Use our global Melody_Pointer to determine the title of the current tune
      lcd_putc("Jolly Old\nSt Nick");
      lcd_putc("Mommy Kissing\nSanta Claus");
    case LETITSNOW:
      lcd_putc("Let It Snow");
    case AWAYINAMANGER:
      lcd_putc("Away In A Manger");
      lcd_putc("O Christmas Tree");
      lcd_putc("We Wish You A\nMerry Christmas");
    case SANTACOMING:
      lcd_putc("Santa Claus Is\nComing To Town");
      lcd_putc("O Come All\nYe Faithful");
    case DECKTHEHALLS:
      lcd_putc("Deck The Halls");
    case SLEIGH:
      lcd_putc("Sleigh Ride");
    case RUDOLPH:
      lcd_putc("Rudolph");
      lcd_putc("Twelve Days\nOf Christmas");
      lcd_putc("Frosty The\nSnowman");
    case SILENTNIGHT:
      lcd_putc("Silent Night");
    case JINGLEBELLS:
      lcd_putc("JingleBells");
     default:
  DESCRIPTION:  Button Tasks
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  if (!Read_Button_Count)
    Read_Button_Count = 30;
    Check_Button_Press();
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
  static int debounce_count = 4;
  static int stable = 0xFF;
  static int last = 0xFF;
  int trans_low;
  int current = 0xFF;
  BOOLEAN change = FALSE;
  // Read the current state of the buttons
  if (!input(PIN_A4))
    bit_clear(current,2);
  if (!input(PIN_B0))
    bit_clear(current,3);
  // See if they have changed
  if (current != last)
    last = current;
    change = TRUE;
  // If they have changed then reset our counter
  if (change)
    debounce_count = 4;
  // Each time they are stable, then decrement our count
  else if (debounce_count)
    debounce_count--;
  // They have been stable long enough so act on them
  else if (current != stable)
    // Get the high transitions
    trans_low = ((stable ^ current) & stable);
    if (bit_test(trans_low,2))
      PlayMelodyFlag = ! PlayMelodyFlag;
    if (bit_test(trans_low,3))
      Melody_Pointer++;
        Melody_Pointer = 0;
    stable = current;
// ISR routines
#int_ccp1
  DESCRIPTION:  This function controls the PWM of the piezo speaker
  RETURN:       none
  ALGORITHM:    none
  NOTES:  If you do not wish to use C2 as the output, then you will need
          to toggle your output here.  Make sure that you change the CCP
          setup not to toggle the C2 output if this is the case
void ccp1_isr (void)
  CCP_1 += Note_Ticks;
  DESCRIPTION:  This function is used to control the duration of the note
  RETURN:       none
  ALGORITHM:    none
  NOTES:  I store the notes in a buffer so that the main loop has other
          time to do stuff with out have to sit at wait for a note to
          complete.
#int_timer0
void timer0_isr (void)
  // Preload a value for TMR0 so that we can control how long it takes to
  // trigger an interrupt
  TMR0 = Tempo;
  // Is a note playing?
  if (DurationCount)
    DurationCount--;
    if (!DurationCount)
      setup_ccp1(CCP_OFF);
  // Note is finished playing, do we have anymore in our buffer?
  else if (Notestat.Count)
    DurationCount = NoteBuffer[Notestat.Head].duration;
    Note_Ticks = NoteBuffer[Notestat.Head].note;
    Notestat.Count--;
    Notestat.Head++;
    Notestat.Head &= NOTE_ROLLOVER_MASK;
    CCP_1 = TMR1 + Note_Ticks;
    if (Note_Ticks)
      /* Setup the CCP module to toggle the output pin c2 */
      setup_ccp1(CCP_COMPARE_TOGGLE_MATCH);
    // Nope, we are all through so disable the PWM
#int_timer2
  DESCRIPTION:  This function is our system tick set at 1ms
  RETURN:       none
  ALGORITHM:    none
  NOTES:        none
void timer2_isr (void)
  if (Read_Button_Count)
    Read_Button_Count--;
saroch
PostPosted: Sun Nov 14, 2004 10:45 am     Reply with quote
THANK YOU VERY VERY VERY MUCH Very Happy
