ccmcca Guest
| bad CHARACTER |
Posted: Thu Nov 04, 2004 3:53 pm |
Why apear extrange character at the end of the line???
Please help me...
#include <16F877.h>
#device *=16
#include <HDM64GS12.c>
#include <graphics.c>
int i;
CHAR const my_string[]="hola amigos";
CHAR const my_string2[]="aca estoy";
CHAR const my_string3[]="todo lison";
CHAR const my_string4[]="entrar aqui";
char buffer[];
glcd_init(ON);
for (i=0;i<=20;i++)
buffer[i]=my_string[i];
glcd_text57(5, 1,buffer, 1, ON);
for (i=0;i<=20;i++)
buffer[i]=my_string2[i];
glcd_text57(5, 9,buffer, 1, ON);
for (i=0;i<=20;i++)
buffer[i]=my_string3[i];
glcd_text57(5, 17,buffer, 1, ON);
for (i=0;i<=20;i++)
buffer[i]=my_string4[i];
glcd_text57(5, 25,buffer, 1, ON);
#ifdef FAST_GLCD
glcd_update();
#else
delay_ms(100); // Reduces flicker by allowing pixels to be on
// much longer than off
Mark
Posted: Thu Nov 04, 2004 4:15 pm |
You didn't declare the size of buffer[].
I guess the "glcd_text57()" function checks for a NULL. We don't know what the parameters are. |
Humberto
Posted: Fri Nov 05, 2004 10:33 am |
Thatīs because the display is showing you all the variables in the
boundaries of your stored string.
To display the string[]="hola amigos" you use
for (i=0;i<=20;i++)
where the string "pointer" has a range i<= 20
while your message is only 10 characters long.
Try putting a null at the end of your string and
break the for cycle when detected.
HTH
Humberto |
Mark
Posted: Fri Nov 05, 2004 10:38 am |
| Quote: | | CHAR const my_string[]="hola amigos"; |
This should put a NULL on the end of the string.
| Quote: | Thatīs because the display is showing you all the variables in the
He is indeed copying more than needed but hopefully the printing routine checks for the NULL as it should. Doesn't really matter if he copies more data so long as he is not overwriting other vars. |
Humberto
Posted: Fri Nov 05, 2004 11:45 am |
Mark,
I know that but he didnīt post the function definition for
so we didnīt know for sure if he is looking for a NULL as end of char string recognition.
Humberto |
Mark
Posted: Fri Nov 05, 2004 12:34 pm |
Didn't I already say that?
| Quote: | | I guess the "glcd_text57()" function checks for a NULL. We don't know what the parameters are. |
Regardless, a NULL is in there from the declaration so there is no need to
| Quote: | | Try putting a null at the end of your string |
| Quote: | break the for cycle when detected.
All this will do is save a little time doing the copying. It still does not address the problem at hand. Now if you said to use a counter in there and break on NULL and pass the length to the function, then I'd agree with you. I am pretty sure that the function checks for a NULL. If not, that is where the problem is. However, not declaring the size of buffer[] is a definite problem since he is copying data into it. Any variables adjacent to it will overwrite the data and cause him problems not to mention the copying into buffer[] will most likely overwrite other variables as well. |
Humberto
Posted: Fri Nov 05, 2004 12:56 pm |
Mark,
I know what the problem is and how to solve it. FYI it is not my inquiry,
it is a thread posted by ccmcca and I just put the spot on the subject
I think the problem is and I hope this were solved by ccmcca.
| Quote: |
Yes, I mean that. Sorry if the post wasn't clear enough.
| Quote: |
Iīm not pretty sure for that.
Anyway I would like to listen to our common friend ccmcca
Humberto |
Mark
Posted: Fri Nov 05, 2004 1:06 pm |
Actually this is CCS driver file
| Code: | /////////////////////////////////////////////////////////////////////////
// Purpose: Write text on a graphic LCD
// Inputs: (x,y) - The upper left coordinate of the first letter
// textptr - A pointer to an array of text to display
// size - The size of the text: 1 = 5x7, 2 = 10x14, ...
// color - ON or OFF
#ifdef LARGE_LCD
void glcd_text57(int16 x, int16 y, char* textptr, int8 size, int1 color)
#else
void glcd_text57(int8 x, int8 y, char* textptr, int8 size, int1 color)
#endif
int8 j, k, l, m; // Loop counters
int8 pixelData[5]; // Stores character data
for(; *textptr != '\0'; ++textptr, ++x)// Loop through the passed string
if(*textptr < 'S') // Checks if the letter is in the first font array
memcpy(pixelData, FONT[*textptr - ' '], 5);
else if(*textptr <= '~') // Check if the letter is in the second font array
memcpy(pixelData, FONT2[*textptr - 'S'], 5);
memcpy(pixelData, FONT[0], 5); // Default to space
// Handles newline and carriage returns
switch(*textptr)
case '\n':
y += 7*size + 1;
continue;
case '\r':
x = 0;
continue;
if(x+5*size >= GLCD_WIDTH) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
for(j=0; j<5; ++j, x+=size) // Loop through character byte data
for(k=0; k < 7; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l < size; ++l) // These two loops change the
{ // character's size
for(m=0; m < size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
#endif
