Problem with structure
YulL
PostPosted: Fri Nov 05, 2004 7:55 am     Reply with quote
I'm using two variables : CVM_CRC and PIC_CRC... CVM_Header, PIC_Header... etc... But now I prefer to use structures in order to make my code more readable!
Here is what I have already done for that :
struct BusMail
{ int8 longueur[2];
int8 prim[2];
int8 param[32];
int8 header;
int8 CRC;
int8 SuId;
int8 TxSeq;
int8 RxSeq;
int1 IC;
int1 PF;
} PIC, CVM;
void send_control(int8 PIC.SuId, int8 PIC.RxSeq, int8 PIC.PF);
void API_FP_INVOKE_ACCESS_RIGHTS(int8 PIC.TxSeq, int8 PIC.RxSeq);
void CVM_EEPROM_WRITE_REQ_BASE(int8 PIC.TxSeq, int8 PIC.RxSeq);
But when I compile I have the error message : "Expecting a , or )"
I can't find where I'm wrong... Evil or Very Mad
Thanks by advance for your support. Razz
asmallri
PostPosted: Fri Nov 05, 2004 8:26 am     Reply with quote
I assume you are showing the functional protypes. In which case they should be..
void send_control(int8 SuId, int8 RxSeq, int8 PF);
void API_FP_INVOKE_ACCESS_RIGHTS(int8 TxSeq, int8 RxSeq);
void CVM_EEPROM_WRITE_REQ_BASE(int8 TxSeq, int8 RxSeq);
Then when you call one it would look like..
send_control(PIC.SuId, PIC.RxSeq, PIC.PF);
Regards, Andrew
YulL
PostPosted: Mon Nov 08, 2004 3:40 am     Reply with quote
Thanks for your advice it works fine now!!
Wink
