Power Meter
Goto page Previous  1, 2
Humberto
PostPosted: Wed Nov 03, 2004 9:22 am     Reply with quote
All of the AC current sensing resistor that I have looked at have all most
zero inductive and capacitive reactance. So I don’t understand?
If using a resistor designed for AC current sensing and reading the
voltage drop at the proper point in the phase angle what the issues are?
The AC current measured with an almost pure resistor in series depends
of the nature of the load, not of the resistor itself.
If the load has an inductive reactance then you will be measuring
the inductive current of the circuit.
If the load has an capacitive reactance then you will be measuring
the capacitive current of the circuit.
To know how inductive/reactive this current is, you will need a zero
Voltage crossing detector
(in paralel with the load) and an accurate
zero Current crossing detector (in series with the load). The most away
those pulses are, the most inductive/capacitive the load is.
The angle phase relationship between voltage and current in an AC circuit
has a direct meaning in the kind of load.
An inductive reactance load will have a current delayed in relation with
the voltage applied.
A capacitive reactance load will have a voltage delayed in relation with
the current sensed.
HTH
Humberto
Page 2 of 2
