		| Author | Message |
		| Sigma
				| 12f629 with i2c eeprom |
				|  Posted: Tue Oct 26, 2004 2:32 am |   |
				| Hi, all, I am now testing a serial eeprom 24aa32 with 12f629 with compiler version 3.178. I use pin_a5 as SDA pin, pin_a4 as SCL pin with 1k resistors pull-up. And also pin_a0 with a 1k pull up resistor to control the WP pin of the eeprom chip. However, the code is not working. Then i emulate the code using icepic emulator of 12C672 (of course with some include statement changed), it is working fine. Is it due to some i/o property problems of 12F629? But i already disable the comparator, and make them all digital i/o in the code. what went wrong? Pls advice.
 Sigma
  	  | Code: |  	  | #include   "12F629.h"
 //#include    "12C672.h"
 #fuses      INTRC,NOWDT,NOPROTECT,NOMCLR,PUT
 //#fuses     XT,NOWDT,NOPROTECT,NOMCLR,PUT
 #use delay (clock=4000000)
 #define WP            PIN_A0         //GP0: Write Protect for FRAM
 #define LED            PIN_A1         //GP1: 1: Energised, 0: dis-energised
 #define EE_SDA         PIN_A4         //GP4: I2C data line
 #define EE_SCL         PIN_A5         //GP5: I2C clock line
 char   cmd;
 #byte CMCON=0x19
 #byte ANSEL=0x9f
 * 24AA32 functions - I2C Bus
 #use    i2c(master, SDA=EE_SDA, SCL=EE_SCL)      //I2C bus
 void init_i2c(void) {                     //Init EEPROM
 output_float(EE_SCL);
 output_float(EE_SDA);
 char read_24AA32(long int addr) {               //Read 1 byte
 char data;
 i2c_start();
 i2c_write(0xa0);
 i2c_write((((0xff00)&addr)>>8));
 i2c_write(addr&(0x00ff));
 i2c_start();
 i2c_write(0xa1);
 data=i2c_read(0);
 i2c_stop();
 return(data);
 void write_24AA32(long int addr, char data)       //Write 1 byte
 output_low(WP);
 i2c_start();
 i2c_write(0xa0);
 i2c_write(data);
 i2c_stop();
 delay_ms(10);
 output_high(WP);
 * main
 main() {
 char   i;
 short   done;
 CMCON=0x07; // Comparator off.
 ANSEL=0x00; // All i/o digital.
 init_i2c();                              //Init EEPROM
 output_low(LED);
 ext_int_edge(h_to_l);
 disable_interrupts(GLOBAL);
 setup_counters(RTCC_INTERNAL, WDT_1152MS);  // The RTCC prescaler is set to 1
 // because we are setting the
 // WDT prescaler
 done=FALSE;
 delay_ms(2000);
 while (1) {
 if(!done){
 done=TRUE;
 for(i=0;i<254;i++){
 write_24AA32(100,i);
 cmd=read_24AA32(100);
 if(cmd==i) {
 output_high(LED);
 delay_ms(50);
 output_low(LED);
 delay_ms(50);
 else if(cmd!=i){
 output_low(LED);
 i++;
 } //while (1)
		| Sigma
				|  Posted: Tue Oct 26, 2004 3:23 am |   |
				| It seems like pin_a4 is not functioning in my case. I make the pin_a4 to control one led to blink. But the led is always on. Yet for other pins, the led blinks. I also test the i2c on pin_a0 as scl and pin_a1 as sda, it is working. Anyone know why pin_a4 not functioning as a digital i/o? It seems to me it still in the analog mode. Sigma
		| Will Reeve
				|  Posted: Tue Oct 26, 2004 3:41 am |   |
				| On a lot of PICs A4 is an open drain output. |  |
		| Sigma
				|  Posted: Tue Oct 26, 2004 3:49 am |   |
				| Solved. Inside the #fuse statement, modify intrc to intrc_io. Then led can be blinked. and i2c also working. Thanks. Sigma
 | You cannot post new topics in this forum You cannot reply to topics in this forum
