simple resistor led question
Nick
PostPosted: Fri Oct 22, 2004 12:32 pm     Reply with quote
I have my pic pin turn on an 1ma LED and a SSR off the same pin, should i put the resistor before the i split the line off to the two different compents? I want to limit the current to each of the compents? My other idea is to just put the resister between the ground of the led and ground of the SSR
btw when I say SSR i mean solid state relay.
Nick
newguy
PostPosted: Fri Oct 22, 2004 12:50 pm     Reply with quote
Your SSR might not like getting anything less than 5 V (or whatever your Vdd is). Run a line from the SSR directly to the PIC. Put the LED and its resistor in parallel with the SSR. I assume this is an indicator LED so that you know when the SSR is active?
yerpa
PostPosted: Fri Oct 22, 2004 2:35 pm     Reply with quote
Better check the specs for your SSR. Using a separate resistor for the LED and another for the SSR would be the safest - to use a single resistor you first need to know the forward voltage drop and recommended current of both the SSR and the LED. Running a line directly from the PIC to the SSR will blow the input of the SSR if it is not internally curent limited.
PostPosted: Fri Oct 22, 2004 2:49 pm     Reply with quote
If the spec's read 3~30vdc, the resistor is built in.
Most SSR have built in current limit.
newguy
PostPosted: Fri Oct 22, 2004 3:16 pm     Reply with quote
Sorry, that's what I was assuming. I just put together a project with a SSR that's driven by 5V, and draws about 40 mA when being driven. I ended up driving through a 2N7000 fet, as that's more current than a PIC pin can source.
