PIC18F6520 "Fast" Fast interrupt
Richard
PostPosted: Wed Oct 20, 2004 7:19 am     Reply with quote
Folk,
I have been writing code using CCS 3.207 and was wondering if there was a way to reduce the interrupt latency of the external interrupt.
My interrupt routine is a trivial response to an external trigger, (clear a variable, clear timer1).
The code is short enough to actually fit in the memory at 0x0008-0x0018 although the compiler insists on locating it elsewhere and jumping there.
Is there any way I can encourage the compiler to squeze my ISR into this gap?
Org 0x0008, 0x0018 is apparently not a valid range.
On a related note, is there any method of optimizing out the majority of the completely unnecessary context saving that the compiler uses on a normal interrupt? (Other than a global interrupt handler)
Thanks for any assistance,
Richard, UK
PostPosted: Wed Oct 20, 2004 7:47 am     Reply with quote
Yes. You can fool the compiler into thinking the vectors will be elsewhere and then you have control of the original vectors
#build(interrupt=0x028)
#org 0x0020, 0x002f {}
   /* Map the high priority interrupt vector */
#org 0x0008, 0x000f
void my_hp_intr (void)
   #asm ASIS
   // ... do your stuff here
   retfie   1   //; fast return from interrupt
   #endasm
   /* Map the low priority interrupt vector */
#org 0x0018, 0x001f
void my_lp_intr (void)
   #asm
   goto   0x0200
   #endasm
#org 0x0200, 0x5fff // or wherever
void LPIntrHdlr(void) {
// etc etc etc
Richard
Faster interrupt
PostPosted: Wed Oct 20, 2004 9:11 am     Reply with quote
Thanks for your suggestion I carried out the following:
#org 0x0008, 0x0014
void Fake_ISR() {
// This is really the fast interrupt
// External interrupt
   #asm
      CLRF   0xFCF  // clear Timer1H
      CLRF   0xFCE  // clear Timer1L
      CLRF   0x39   // clear CounterH
      CLRF   0x38   // clear CounterL
      BCF    0xFF2.1   //clear interrupt flag
      RETFIE 1
   #endasm
#org default
This carried out the ISR as expected. I also need to map my Counter variable so that it doesn't move about if I change my variables ;-)
This produced the following list snipppet
org 0x0008, 0x0014
.................... void Fake_ISR() {
.................... // This is really the fast interrupt
.................... // External interrupt
....................    #asm
....................       CLRF   0xFCF  // clear CounterH
0008:  CLRF   FCF
....................       CLRF   0xFCE  // clear CounterL
000A:  CLRF   FCE
....................       CLRF   0x39   // clear CounterH
000C:  CLRF   39
....................       CLRF   0x38   // clear CounterL
000E:  CLRF   38
....................       BCF    0xFF2.1   //clear interrupt flag
0010:  BCF    FF2.1
....................       RETFIE 1
0012:  RETFIE 1
....................    #endasm
0014:  RETLW  00
.................... #org default
ie It did exactly what was wanted (except for the spare RETLW 00 from the closing brace of the void function, which never gets called).
My original mistake was to try and #ORG the CCS #int_ext ISR.
Thanks for your help!
Richard
asmallri
PostPosted: Wed Oct 20, 2004 10:49 am     Reply with quote
No problem.
Don't forget you can use your C labels in assembler
byte   CounterH;  #locate   Rx_HeadL = 0x40
byte   CounterL;  #locate   Rx_HeadL = 0x41
then your code becomes..
#org 0x0008, 0x0014
void Fake_ISR() {
   #asm
      CLRF   CounterH   // clear CounterH
      CLRF   CounterL   // clear CounterL
      RETFIE 1
   #endasm
Remember to keep you variables below 0x80 to save having to use the BSR
[/code]
