Generating slow PWMs
Charlie
PostPosted: Thu Mar 27, 2003 7:34 pm     Reply with quote
Programming a PIC16C773 with an 8MHz Xtal:
I can create frequencies using the built-in PWM from 100KHz to 500Hz with no problem. Problem comes when I need frequecies below this. I need to produce frequecies down to 1Hz. Specifically, I need 1, 10, 50 and 100Hz.
I could enable Timer2 to interrupt every 2ms, count interrupts and toggle the output pin manually. But this seems messy. Any ideas on a cleaner solution? Thanks!
Charlie
___________________________
Original Post ID: 13164
Kenny
Re: Generating slow PWMs
PostPosted: Thu Mar 27, 2003 8:52 pm     Reply with quote
:=Programming a PIC16C773 with an 8MHz Xtal:
:=I can create frequencies using the built-in PWM from 100KHz to 500Hz with no problem. Problem comes when I need frequecies below this. I need to produce frequecies down to 1Hz. Specifically, I need 1, 10, 50 and 100Hz.
:=I could enable Timer2 to interrupt every 2ms, count interrupts and toggle the output pin manually. But this seems messy. Any ideas on a cleaner solution? Thanks!
:=Charlie
Mr. Hamlett covered it very well in a recent post:
<a href="http://www.pic-c.com/forum/general/posts/12884.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/12884.html</a>
Regards
Kenny
Original Post ID: 13167
