rs232 using 16f628 |
Posted: Mon Oct 18, 2004 8:32 am |
hello.
how can i connect my pic16f628 with pc?
#include <16f628.h>
#fuses XT,NOWDT,NOPROTECT, NOPUT, NOBROWNOUT
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, parity=N, bits=8)
#include <stdlib.h>
puts("Hallo");
what did i do wrong? thnx.. |
Mark
Posted: Mon Oct 18, 2004 11:34 am |
Did ya use a RS232 transceiver chip? Did ya connect it via a Null modem cable (Tx(PIC)->Rx(PC) and Rx(PIC)->Tx(PC) and GND->GND)? |
Posted: Mon Oct 18, 2004 2:15 pm |
Mark wrote: | Did ya use a RS232 transceiver chip? Did ya connect it via a Null modem cable (Tx(PIC)->Rx(PC) and Rx(PIC)->Tx(PC) and GND->GND)? |
well i dont have a max232, im using a hex converter..
i have a null modem cable, but i just connect that (Tx(PIC)->Rx(PC) and GND-GND |
Posted: Mon Oct 18, 2004 3:55 pm |
Anonymous wrote: | Mark wrote: | Did ya use a RS232 transceiver chip? Did ya connect it via a Null modem cable (Tx(PIC)->Rx(PC) and Rx(PIC)->Tx(PC) and GND->GND)? |
A 'hex converter'?.
Do you mean a 'hex inverter'?. If so, this _may_ (sometimes) work, with some RS232 inputs, but is by no means guaranteed, and is well out of spec. RS232, really requires a -ve supply rail to be generated (the MAX232 does this for you). I'd suspect that your output, just does not get close enough to the RS232 requirements. Try with a MAX232...
Posted: Tue Oct 19, 2004 9:21 am |
Ttelmah wrote: | Anonymous wrote: | Mark wrote: | Did ya use a RS232 transceiver chip? Did ya connect it via a Null modem cable (Tx(PIC)->Rx(PC) and Rx(PIC)->Tx(PC) and GND->GND)? |
A 'hex converter'?.
oh sry, yes i used a hex inverter.
but theres nothing wrong with the code?
thx |
Humberto
Posted: Tue Oct 19, 2004 11:41 am |
Try this:
#include <16f628.h>
#fuses XT,NOWDT,NOPROTECT,PUT, NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
// Selected by default : parity=N, bits=8
//#include <stdlib.h> // Not needed
printf("\r\nHallo");
Best wishes
Humberto |
Posted: Tue Oct 19, 2004 2:54 pm |
thanks 2 u all,
i'll try that on thursday.
thnx |
dgjboy Guest
Connect PIC <-> PC, easy option |
Posted: Mon Oct 25, 2004 9:06 am |
Hi developers!
You can connect your PIC with a PC using next option (only for software UART and use INVERT directive):
PIC PC(RS232-9 pins)
TX ----4K7Resistor---- RX (2)
RX ----4K7Resistor---- TX (3)
And if you need a simple power supply for your circuit try it:
PC(RS232-9 pins)
RST(4) ----1K------------------------------------ 5v
GND(5) ----------Zener5v1----- ----
| ---- 100nF
--------------------------------------- Gnd
Grettings |
