Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Help with strcpy
Burt Poppenga
Help with strcpy
PostPosted: Wed Mar 26, 2003 9:34 pm     Reply with quote
I must be having a brain malfunction. I can't see why the following sample program does not work (PCH 3.148):
#include <18F452.h>
#fuses XT,NOWDT,PUT,NOLVP,NOPROTECT
#device *=16
#device ADC=10
#use delay(clock=4000000, RESTART_WDT) // 4 MHz clock
#use rs232(baud=19200, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors)
#include <string.h>
void rom_fmtstr_to_ram(char *destStr)
printf("rom_fmtstr_to_ram start: \%s\n\r", destStr);
strcpy(destStr, "Carp");
printf("rom_fmtstr_to_ram end: \%s\n\r", destStr);
// The test.
main()
char bString[10];
// Put something into the string
strcpy(bString, "Hello");
// Re-write the string
rom_fmtstr_to_ram(bString);
// Display the results (should be different)
printf("Main Done: \%s\n\r", bString);
// Don't fall off into the deep SLEEP
___________________________
Original Post ID: 13115
Ron
Re: Help with strcpy
PostPosted: Thu Mar 27, 2003 6:13 am     Reply with quote
Code looks ok to me.
What exactly is not working?
:=Hello,
:=I must be having a brain malfunction. I can't see why the following sample program does not work (PCH 3.148):
:=#include <18F452.h>
:=#fuses XT,NOWDT,PUT,NOLVP,NOPROTECT
:=#device *=16
:=#device ADC=10
:=#use delay(clock=4000000, RESTART_WDT) // 4 MHz clock
:=#use rs232(baud=19200, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors)
:=#include <string.h>
:=void rom_fmtstr_to_ram(char *destStr)
:= printf("rom_fmtstr_to_ram start: \%s\n\r", destStr);
:= strcpy(destStr, "Carp");
:= printf("rom_fmtstr_to_ram end: \%s\n\r", destStr);
:=// The test.
:=main()
:= char bString[10];
:= // Put something into the string
:= strcpy(bString, "Hello");
:= // Re-write the string
:= rom_fmtstr_to_ram(bString);
:= // Display the results (should be different)
:= printf("Main Done: \%s\n\r", bString);
:= // Don't fall off into the deep SLEEP
:= while(1);
Original Post ID: 13132
Burt Poppenga
PostPosted: Thu Mar 27, 2003 8:42 am     Reply with quote
The output of the routine is:
rom_fmtstr_to_ram start: Hello
Main Done: Hello
I expected something more like:
rom_fmtstr_to_ram end: Carp
Main Done: Carp
Original Post ID: 13134
PostPosted: Thu Mar 27, 2003 12:59 pm     Reply with quote
I don't have PCH, but PCM 3.149 with a 16F877 shows the same
behavior. I think it's a bug in strcpy(). It doesn't seem
to be able handle a passed array pointer. It uses ram
locations for temporary counters, that are part of the
destination array. If you change the code so that the
array is in the local routine, then strcpy works OK.
char tempStr[10];
strcpy(tempStr, "Carp");
printf("rom_fmtstr_to_ram end: \%s\n\r", tempStr);
Original Post ID: 13155
