Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Ad conversion on PIC18
Christer TENNSTEDT
PostPosted: Thu Mar 27, 2003 8:15 am     Reply with quote
On my PIC 16 it worked fine with the AD conversion. Using the same code on PIC18 the reading on RA2 affects the value on RA0.
Has anyone experienced the same?
I use the latest compiler.
/Christer
___________________________
Original Post ID: 13133
EECEWOLF
Re: Ad conversion on PIC18
PostPosted: Thu Mar 27, 2003 9:35 am     Reply with quote
Which PIC16? The PIC18 has a 10-bit A/D. Is it setup to be left justified or right justified?
:=On my PIC 16 it worked fine with the AD conversion. Using the same code on PIC18 the reading on RA2 affects the value on RA0.
:=Has anyone experienced the same?
:=I use the latest compiler.
:=/Christer
Original Post ID: 13139
Neutone
PostPosted: Thu Mar 27, 2003 9:43 am     Reply with quote
:=Which PIC16? The PIC18 has a 10-bit A/D. Is it setup to be left justified or right justified?
:=:=On my PIC 16 it worked fine with the AD conversion. Using the same code on PIC18 the reading on RA2 affects the value on RA0.
:=:=Has anyone experienced the same?
:=:=I use the latest compiler.
:=:=/Christer
Did you pause after switching channels?
Original Post ID: 13140
