bertronicom Guest
| How many Stream's Can I Use? |
Posted: Mon Oct 04, 2004 9:21 am |
How many diferent serial ports can be used by the way of Stream?
#use rs232(STREAM=HOST_id, baud=9600,parity=N,xmit=HOST_TX,rcv=HOST_RX,bits=8)
#use rs232(STREAM=BT_id, baud=9600,parity=N,xmit=BT_TX,rcv=BT_RX,bits=8)
I'm working with CCS last version, and I'm sucessfully work with 2 conections. |
SherpaDoug
Posted: Mon Oct 04, 2004 10:34 am |
I am using three streams on a 16C771, but I suspect the only limits are RAM and ROM space. What chip are you using? _________________ The search for better is endless. Instead simply find very good and get the job done. |
Haplo
Posted: Mon Oct 04, 2004 5:27 pm |
In theory, there are is limit to the number of streams you can use. As SherpaDoug said the limiting factor is the code space, and also availability of I/O pins (althoug you can define two different streams on the same pins).
I have used 4 without any problems. |
bertronicom Guest
| RS232 Streams |
Posted: Tue Oct 05, 2004 3:21 am |
Hello SherpaDoug, I'm using PIC18LF252 at 3.3volts.
I've configured two RS232 serial ports.
void main () {
fprintf( BT_id , "INQUIRY 5 NAME\n\r");
fprintf( HOST_id , "\n\rRx Comando: INQUIRY_NAME");
In this case de first fprintf works but not second.
void main () {
This code works.
Theoretically the first code would work żisn't so?
Hello Haplo, Are you saying you're multiplexing two pins to diferents RS232 conections?
It's working fine?
thanks everyone |
treitmey
Posted: Tue Oct 05, 2004 8:42 am |
I think I do something like this too.
#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=DEBUG)
#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=STDERR) //
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,stream=RS485) // RS485 is the default
one is is STDERR and one is DEBUG,.. both to the same pins..
in therory I can take out debug,.. and leave STDERR. |
Haplo
| Re: RS232 Streams |
Posted: Tue Oct 05, 2004 5:42 pm |
| bertronicom wrote: |
It's working fine?
Yes you can, and it works fine. Taken from one of my source files:
#use rs232(baud=4800 ,parity=N,xmit=PIN_C3,rcv=PIN_C2,enable=PIN_C1,bits=8,restart_wdt,stream=EUM1)
#use rs232(baud=1200 ,parity=N,xmit=PIN_C3,rcv=PIN_C2,enable=PIN_C1,bits=8,restart_wdt,stream=EUM2)
