Wake from sleep on pin change?
Goto page Previous  1, 2
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Oct 05, 2004 1:37 am     Reply with quote
You need to re-init you LCD everytime you power-up! I drive a 2x16 from a PIC pin for low power and on wake-up I just resend the init bytes, then the original text.
Will
ernest
PostPosted: Tue Oct 05, 2004 2:29 am     Reply with quote
Yes...I have done that. Each time after power-up, I'll initialize the LCD as shown below:
if(input(PIN_C5)==0) // RC5 to detect for presence of main power
OUTPUT_FLOAT(PIN_C6); // if RC5=0, disable Tx & Rx as no main power
OUTPUT_FLOAT(PIN_C7);
// PORT_B_PULLUPS(TRUE);
Just_wokeup = 1; // flag to indicate that main power has just returned
else // if RC5==1, then ALLOW LCD DISPLAY
if(Just_wokeup==1) //run this ONCE only when main power just returned
lcd_init(); //INITIALIZE LCD
kbd_init();
lcd_putc("\f Power Returned ");
lcd_putc("\n ");
printf("\f Main Power Returned");
delay_ms(1);
Just_wokeup = 0; /ensure loop is not repeated until next main power cutoff
As you can see in the program, the LCD is initialized after the power to the LCD comes back.
Please comment...
asmallri
PostPosted: Tue Oct 05, 2004 4:36 am     Reply with quote
I can think of two possible problems.
1. Hardware - are you 100% sure that every control into the LCD is powered down including for example bias? If any of control lines are active the LCD may not power down correctly - this could be a problem for two reasins but the most interesting for you at the moment is that the power on reset circuitry does not initiate a power on reset. In ths condition you are attempting to talk to a controller that has gone off in to the never-never.
2. After you reapply power to the LCD, are you waiting long enough for the LCD's power on reset process to finish?
Does your LCD have a sleep or low power mode? If so, have you checked to see what sort of current it draws in this mode? You may find there is no need to power it down.
PostPosted: Tue Oct 05, 2004 5:42 am     Reply with quote
ernest wrote:
Hi...
OK..temporarily, I'll let my PIC16LF877A run continuosly without sleeping as the currect that draws is not too high as long as I turn off all the other peripherals including the LCD. I tried to turn OFF the LCD but everytime after I turn off the power to the LCD and resupply it back later, the data that is being displayed would be JUNK!. From the Hyperterminal, I can see that the PIC is working fine and PIC can display the data correctly thru Hyperterminal as well. I have tried both ways ie. driving the LCD using external power supply and supplying the power to LCD using one of the PIC I/O pin.
So, what is wrong with the LCD?
The LCD works well when I turn ON the power together with PIC but after that, it doesn't work when I turn OFF the LCD power without turning off the PIC. I have tried setting all the I/Os to the LCD to Hi-Z as well as pull-up after the LCD is powered OFF.
What can I do to solve this problem? Confused
Thanks...
Remember that when power is applied to the PIC, it waits for it's clock to stabilise, and (if the 'power on' timer is anabled), for quite a few uSec more, before starting. This does not apply if you are waking on an external signal. Most LCD's, have quite a slow 'wake up' sequence needed. Hence try delaying for a couple of mSec before doing anything.
Seperately, there is the question of supply sequencing, and rise time. The spec for the main supply rail, has quite a fast rise time required to trigger the internal wake up sequence. If your power hardware takes longer to come on, under 'PIC' control, than on the default power-up condition, this could cause a problem. Also, look carefully at the seqencing of the rails. Some displays _require_ the main power rail to rise before the display bias is applied, otherwise the CMOS latch-up can occur.
ernest
Hmm.. LCD still refuses to startup
PostPosted: Wed Oct 06, 2004 11:08 pm     Reply with quote
I've put in 100ms delay after the power to LCd returns before initializing the LCD but it still couldn't startup properly. The LCD still gives me JUNK display even though i've tried with 50ms, 100ms, 150ms, 200ms and 250ms delay.
Is there something wrong with my program/LCD?
Why can it work when I power up the LCD together with MCU?
if(input(PIN_C5)==0) //RC5 to check for main power (1=yes,0=no)
output_float(PIN_B0); //set all I/O to LCD to float
output_float(PIN_B1);
output_float(PIN_B2);
output_float(PIN_B4);
output_float(PIN_B5);
output_float(PIN_B6);
output_float(PIN_B7);
OUTPUT_FLOAT(PIN_C6); //set Tx & Rx to float
Just_wokeup = 1; //flag to indicate power to LCD just returned
else // if RC5==1 ie main power back, then ALLOW LCD DISPLAY
delay_ms(150);
if(input(PIN_C5)==1) // check 2nd time to ensure main power is back
if(Just_wokeup==1)
delay_ms(150); //tried with 50,100,200, 250 ms to let LCD time to power up properly
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
Mark
PostPosted: Wed Oct 06, 2004 11:49 pm     Reply with quote
Putting the device to sleep does not start the program over. Post you entire program.
ernest
PostPosted: Thu Oct 07, 2004 1:44 am     Reply with quote
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#define RTC_SCLK PIN_A1 //PIN_B1
#define RTC_RST PIN_A2 //PIN_B2
#define RTC_IO PIN_A3 //PIN_B3
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
int day_off, hour_off, min_off, sec_off, sec_old;
int inc_flag; // flag to represent FLOW ( 0 = FLOW OFF, 1 = FLOW ON)
int sec_last[11]; // create 10 elements array for storing previous SEC. data
int min_last[11]; // create 10 elements array for storing previous SEC. data
int hour_last[11]; // create 10 elements array for storing previous SEC. data
int day_last[11]; // create 10 elements array for storing previous SEC. data
int mth_last[11]; // create 10 elements array for storing previous SEC. data
int year_last[11]; // create 10 elements array for storing previous SEC. data
int i, previously_OFF, timer_sec, timer_min, timer_hour, timer_day; //
int Just_wokeup;
///////////////////////////////////////// BELOW FUNCTIONS FOR SLEEP !!!
// global flag to send processor into sleep mode
//short sleep_mode;
// external interrupt when button pushed and released
//#INT_EXT
//void ext_isr()
// static short button_pressed=FALSE;
// if(!button_pressed) // if button action and was not pressed
// button_pressed=TRUE; // the button is now down
// sleep_mode=TRUE; // activate sleep
// printf("The processor is now sleeping.\r\n");
// ext_int_edge(L_TO_H); // change so interrupts on release
// else // if button action and was pressed
// button_pressed=FALSE; // the button is now up
// sleep_mode=FALSE; // reset sleep flag
// ext_int_edge(H_TO_L); // change so interrupts on press
// if(!input(PIN_B3)) // keep button action sychronized wth button flag
// delay_ms(100); // debounce button
// } //end of ext_isr
//////////////////////////////////////// ABOVE FUNCTIONS FOR SLEEP !!!
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
} while ((first<'0') || (first>'9'));
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
} while ((second<'0') || (second>'9'));
lcd_putc(second);
return((first<<4)|(second-'0'));
void set_clock(){
byte day,mth,year,dow,hour,min;
lcd_putc("\fYear 20: "); // Year 2000 -- 2099 //
year=get_bcd();
lcd_putc("\fMonth: ");
mth=get_bcd();
lcd_putc("\fDay: ");
day=get_bcd();
lcd_putc("\fWeekday 1-7: ");
dow=get_bcd();
lcd_putc("\fHour: ");
hour=get_bcd();
lcd_putc("\fMin: ");
min=get_bcd();
rtc_set_datetime(day,mth,year,dow,hour,min);
//////////// CONTROL SETUP MENU ////////////////////////////////
void set_control(){
int sec_buf, min_buf, hour_buf, day_buf;
lcd_putc("\fToff Day: ");
timer_day=get_bcd();
printf("\n\r Day_DEC:%D, Day_HEX:%X, Day_CHAR:%C",timer_day,timer_day,timer_day);
lcd_putc("\fToff Hour: ");
timer_hour=get_bcd();
printf("\n\r Hour_DEC:%D, Hour_HEX:%X, Hour_CHAR:%C",timer_hour,timer_hour,timer_hour);
lcd_putc("\fToff Min: ");
timer_min=get_bcd();
printf("\n\r Min_DEC:%D, Min_HEX:%X, Min_CHAR:%C",timer_min,timer_min,timer_min);
lcd_putc("\fToff Sec: ");
timer_sec=get_bcd();
printf("\n\r Sec_DEC:%D, Sec_HEX:%X, Sec_CHAR:%C",timer_sec,timer_sec,timer_sec);
delay_ms(250);
////////////// HEX to DECIMAL CONVERSION ///////////////////
sec_buf = timer_sec%16; // give the remainder from division of timer_sec
timer_sec = 10*(timer_sec/16) + sec_buf;
min_buf = timer_min%16; // give the remainder from division of timer_sec
timer_min = 10*(timer_min/16) + min_buf;
hour_buf = timer_hour%16; // give the remainder from division of timer_sec
timer_hour = 10*(timer_hour/16) + hour_buf;
day_buf = timer_day%16; // give the remainder from division of timer_sec
timer_day = 10*(timer_day/16) + day_buf;
//////// END ==> HEX to DECIMAL CONVERSION /////////////
/////////////// SETUP MENU ///////////////////////////////
void setup_menu()
char cmd, cmd1, cmd2;
lcd_putc("\f1:System 2:Timer");
lcd_putc("\n3:CTRL 4:Back ");
do {
cmd=kbd_getc();
} while ((cmd!='1')&&(cmd!='2')&&(cmd!='3')&&(cmd!='4'));
// SYSTEM RESET MENU //
if(cmd=='1')
lcd_putc("\fRESET SYSTEM ? ");
lcd_putc("\n *:YES #:NO ");
do
{ cmd1=kbd_getc(); }
while ((cmd1!='*')&&(cmd1!='#'));
if(cmd1=='*') // RESET CLOCK & TIMER if '*'
set_clock();
} // END OF SYSTEM RESET MENU //
// TIMER MENU //
if(cmd=='2')
lcd_putc("\f1:Clear TIMER ");
lcd_putc("\n2:Display Record");
do
while ((cmd1!='1')&&(cmd1!='2')&&(cmd1!='#'));
if(cmd1=='1') // CLEAR TIMER VALUE
sec_off = 0; // Stores the TOTAL ACCUMULATED duration or how long it has been OFF //
min_off = 0;
hour_off = 0;
day_off = 0;
if(cmd1=='2') // RESET CLOCK & TIMER if '*'
for (i=1;i<11;i++)
printf(lcd_putc,"\fRec%02X: %02X/%02X/%02X",i,day_last[i],mth_last[i],year_last[i]);
printf(lcd_putc,"\n %02X:%02X:%02X",hour_last[i],min_last[i],sec_last[i]);
delay_ms(2000);
} // END OF TIMER MENU //
// CONTROL MENU //
if(cmd=='3')
lcd_putc("\fSET AUTO OFF ? ");
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
} // END OF SETUP MENU FUNCTION //
char cmd;
byte day,mth,year,dow,hour,min,sec;
Just_wokeup = 0;
day_off = 0;
hour_off = 0; // Timer initialize to 00:00:00
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
sec_last[i] = 0; // LAST OFF TIME initialize to 00:00:00//
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0;
timer_sec=0; //
timer_min=0; //// Initial value for AUTO TIMER OFF TIME
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
// To switch ON back light of LCD --> PIN PORTA,5 //
output_high(PIN_A5);
lcd_putc("\fFLOW MONITORING");
lcd_putc("\n *:Set #:Run ");
do {
cmd=kbd_getc();
} while ((cmd!='*')&&(cmd!='#'));
if(cmd=='*')
set_clock();
// To switch OFF backlight of LCD --> PIN PORTA,5 //
output_low(PIN_A5);
output_low(PIN_E2); // Initial settings ==> PORTE,2 == 0
//########################################## Below is for SLEEP MODE
// long counter;
// sleep_mode=FALSE; // init sleep flag
// ext_int_edge(H_TO_L); // init interrupt triggering for button press
// enable_interrupts(INT_EXT);// turn on interrupts
// enable_interrupts(GLOBAL);
// printf("\n\n");
// counter=0; // reset the counter
//################ Above is for SLEEP MODE
/////////////////////////////////// MAIN ROUTINE ////////////////////////////
while (TRUE) {
cmd=kbd_getc();
if(cmd=='*') // SET REAL TIME CLOCK
// To switch ON backlight of LCD --> PIN PORTA,5 //
setup_menu(); // GOTO SETUP MENU
output_low(PIN_A5);
lcd_putc('\f');
rtc_get_date( day, mth, year, dow);
rtc_get_time( hour, min, sec );
if(input(PIN_E0) == 1) //## SPECIAL DESIGN ## || if WATER FLOW ie RE0=1 ==> increase timer ### PORTE,0 == FLOW SWITCH
if (sec != sec_old) // ONLY increment sec if SEC != SEC_OLD, if same means no need 2 increase timer
sec_off = sec_off + 1; //(sec - sec_old);
if (sec_off == 60) // if sec_off == 60 ie 60sec,then clr & increment min_off
sec_off = 0;
min_off = min_off + 1;
if (min_off == 60) // if min_off == 60 ie 60 min,then clr & increment hour_off
min_off = 0;
hour_off = hour_off + 1;
if (hour_off == 24) // if hour_off == 24 ie 24 hours,then clr & increment day_off
hour_off = 0;
day_off = day_off + 1;
previously_OFF = 1; // previously_OFF flag to indicate previously & currently NO WATER
output_high(PIN_E2); // Specially chg to ON RELAY (240Vac) when timer RUN
else // if no water is detected !!! (NO FLOW)
if(previously_OFF == 1) // if HIGH (1), means PREVIOUSLY/BEFORE THAT 'NO WATER FLOW'
///////////////////// TO SAVE 10 PREVIOUS DOWN TIME ////////////////////////////////
sec_last[1] = sec; // 1st
min_last[1] = min; // 1st
hour_last[1] = hour; // 1st
day_last[1] = day; // 1st
mth_last[1] = mth; // 1st
year_last[1] = year; // 1st
previously_OFF = 0; // chg to LOW, to mean that WATER IS FLOWING even for (n-1) cycle
// if PORTE,0 == LOW, PORTE,2 == LOW TO SWITCH OFF SOXHLET
output_low(PIN_E2); // Specially chg to OFF RELAY (240Vac) when timer OFF
////////////////// END OF CHECKING WATER FLOW AT PIN_RE0 ///////////////
cmd=kbd_getc();
output_low(PIN_A5);
Just_wokeup = 1;
else // if RC5==1, then ALLOW DISPLAY
delay_ms(150);
if(Just_wokeup==1)
delay_ms(150);// delay100ms to let LCD power up properly
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
// FOR DISPLAY ON LCD
printf(lcd_putc,"%2X/%2X/%2X %2X%2X%2X",day,mth,year,hour,min,sec);
printf(lcd_putc,"\nt=%02d:%02d:%02d %03dDy",hour_off,min_off,sec_off, day_off);
// FOR DISPLAY USING RS-232
printf("\f Current Date & Time : %2X/%2X/%2X %2X:%2X:%2X",day,mth,year,hour,min,sec);
printf("\n\r Last Stopped Time : %2D/%2D/%2D %2D:%2D:%2D",day_last,mth_last,year_last,hour_last,min_last,sec_last);
printf("\n\r Total Down Time : %02d:%02d:%02d %03d Day",hour_off,min_off,sec_off, day_off);
printf("\n\r Selected ON/OFF time: %02D:%02D:%02D %03D Day",timer_hour,timer_min,timer_sec,timer_day);
// printf("\n\r Selected ON/OFF time: %02D:%02D:%02D %03D Day",timer_day,timer_hour,timer_min,timer_sec);
// printf("\n\r tday:%X, thour:%X, tmin:%X, tsec:%X",timer_day,timer_hour,timer_min,timer_sec);
// } // END of if(input(PIN_C5)==1)
delay_ms(250);
} // end of ELSE on top
cmd=kbd_getc();
output_low(PIN_A5);
cmd=kbd_getc();
output_low(PIN_A5);
sec_old = sec; //copy value of sec to sec_old REGISTER; if later in the loop SEC=SEC_OLD,dont increment sec_off
if(((int)timer_day==day_off)&&((int)timer_hour==hour_off)&&((int)timer_min==min_off)&&((int)timer_sec==sec_off))
output_low(PIN_E2);
lcd_putc("\f Timer Complete ");
lcd_putc("\n1:End 2:Resume");
do {
cmd=kbd_getc();
} while ((cmd!='1')&&(cmd!='2'));
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
lcd_putc("\fEnd of Operation");
lcd_putc("\n#:Restart timer ");
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
// if(INPUT(PIN_B3)==0) // if sleep flag set
// Just_wokeup = 1; // to make sure LCD & KBD will be INITIALIZED later
// sleep(); // make processor sleep if SLEEP_MODE is TRUE !!!
// if(Just_wokeup == 1)
// lcd_init();
// kbd_init();
// printf(lcd_putc,"%2X/%2X/%2X %2X%2X%2X",day,mth,year,hour,min,sec);
// printf(lcd_putc,"\nt=%02d:%02d:%02d %03dDy",hour_off,min_off,sec_off, day_off);
// Just_wokeup = 0; // Make sure INITIALIZATION is done ONCE ONLY..
} // Do not delete ==> Closing Brace for WHILE Loop
} // DO NOT DELETE ==> CLOSING BRACE for MAIN
So sorry that it's quite crude...The initial sleep function for the MCU doesn't work.So as temporary solution,I need to let the PIC to run continuosly while shutting off all the other peripherals when main power is not available.
ernest
PostPosted: Thu Oct 07, 2004 1:47 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
int sec_last[11], min_last[11], hour_last[11], day_last[11],mth_last[11], year_last[11]; // create 10 elements array for storing previous
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void set_control(){
delay_ms(250);
void setup_menu()
do {
cmd=kbd_getc();
if(cmd=='1')
do
set_clock();
// TIMER MENU //
if(cmd=='2')
do
min_off = 0;
hour_off = 0;
day_off = 0;
for (i=1;i<11;i++)
delay_ms(2000);
// CONTROL MENU //
if(cmd=='3')
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
char cmd;
Just_wokeup = 0;
day_off = 0;
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0;
timer_sec=0; //
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
output_low(PIN_A5);
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
output_low(PIN_A5);
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
output_low(PIN_A5);
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
output_low(PIN_A5);
cmd=kbd_getc();
output_low(PIN_A5);
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
// lcd_init();
// kbd_init();
ernest
PostPosted: Thu Oct 07, 2004 1:49 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void setup_menu()
do {
cmd=kbd_getc();
if(cmd=='1')
do
set_clock();
// CONTROL MENU //
if(cmd=='3')
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
char cmd;
Just_wokeup = 0;
day_off = 0;
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
{ sec_last[i] = 0; // LAST OFF TIME initialize to 00:00:00//
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0; }
timer_sec=0; //
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
output_low(PIN_A5);
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
output_low(PIN_A5);
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
output_low(PIN_A5);
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
output_low(PIN_A5);
cmd=kbd_getc();
output_low(PIN_A5);
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
// lcd_init();
// kbd_init();
ernest
PostPosted: Thu Oct 07, 2004 1:50 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void setup_menu()
do {
cmd=kbd_getc();
if(cmd=='1')
do
set_clock();
// CONTROL MENU //
if(cmd=='3')
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
char cmd;
Just_wokeup = 0;
day_off = 0;
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0; }
timer_sec=0; //
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
output_low(PIN_A5);
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
output_low(PIN_A5);
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
output_low(PIN_A5);
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
output_low(PIN_A5);
cmd=kbd_getc();
output_low(PIN_A5);
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
ernest
PostPosted: Thu Oct 07, 2004 1:52 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void setup_menu()
do {
cmd=kbd_getc();
if(cmd=='1')
do
set_clock();
// CONTROL MENU //
if(cmd=='3')
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
char cmd;
Just_wokeup = 0;
day_off = 0;
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0; }
timer_sec=0; //
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
output_low(PIN_A5);
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
output_low(PIN_A5);
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
output_low(PIN_A5);
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
output_low(PIN_A5);
cmd=kbd_getc();
output_low(PIN_A5);
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
ernest
PostPosted: Thu Oct 07, 2004 1:56 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void setup_menu()
do {
cmd=kbd_getc();
if(cmd=='1')
do
set_clock();
// CONTROL MENU //
if(cmd=='3')
do
set_control();
if(cmd1=='#')
timer_sec=0;
timer_min=0;
timer_hour=0;
timer_day=0;
char cmd;
Just_wokeup = 0;
day_off = 0;
min_off = 0;
sec_off = 0;
sec_old = 0;
i = 0;
for (i=1;i<11;i++)
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0; }
timer_sec=0; //
timer_hour=0; ////
timer_day=14; //
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
output_low(PIN_A5);
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
output_low(PIN_A5);
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
output_high(PIN_A5); // ON backlight
output_low(PIN_A5); // off backlight
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
output_high(PIN_A5);// ON backlight
output_low(PIN_A5); // OFF backlight
cmd=kbd_getc();
output_low(PIN_A5); // Off backlight
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
ernest
PostPosted: Thu Oct 07, 2004 2:01 am     Reply with quote
#include <ds1302.c>
#include <lcd.c>
#include <kbd.c>
//short sleep_mode;
//#INT_EXT
//void ext_isr()
byte get_bcd() {
char first,second;
do {
first=kbd_getc();
lcd_putc(first);
first-='0';
do {
second=kbd_getc();
lcd_putc(second);
void set_clock(){
year=get_bcd();
mth=get_bcd();
day=get_bcd();
dow=get_bcd();
hour=get_bcd();
min=get_bcd();
void setup_menu()
do { //truncated to save space
char cmd;
Just_wokeup = 0;
day_off = 0; hour_off=0; min_off=0; sec_off=0; sec_old=0; i = 0;
for (i=1;i<11;i++)
min_last[i] = 0;
hour_last[i] = 0;
day_last[i] = 0;
mth_last[i] = 0;
year_last[i] = 0; }
rtc_init();
lcd_init();
kbd_init();
do {
cmd=kbd_getc();
if(cmd=='*')
set_clock();
// long counter;
// printf("\n\n");
while (TRUE) {
cmd=kbd_getc();
lcd_putc('\f');
sec_off = 0;
min_off = 0;
hour_off = 0;
cmd=kbd_getc();
Just_wokeup = 1;
delay_ms(150);
if(Just_wokeup==1)
lcd_init();
kbd_init();
lcd_putc("\n ");
delay_ms(150);
Just_wokeup = 0;
delay_ms(250);
cmd=kbd_getc();
cmd=kbd_getc();
output_low(PIN_E2);
do {
cmd=kbd_getc();
if(cmd=='1')
day_off = 0;
hour_off = 0;
min_off = 0;
sec_off = 0;
do {
cmd=kbd_getc();
} while (cmd!='#');
///For SLEEP MODE
erhan
PostPosted: Sat Jan 01, 2005 4:05 pm     Reply with quote
maybe for this topic it's late but helps other ones!
yes, max232 draws much current (in very low power circuits) if you want to sleep()!
when designing batery supplied circuits its better to use ds275 for rs232. It gets its power from rs232 line.
Page 2 of 2
