Can't receive data from my computer with RS232
Goto page Previous  1, 2
asmallri
PostPosted: Wed Sep 29, 2004 9:40 am     Reply with quote
Have you tried adding #use fast_io(C) ?
asmallri
PostPosted: Wed Sep 29, 2004 9:45 am     Reply with quote
Here is something you can try. Add code to toggle the RX pin every second. If it is really an input then nothing will happen. If on the other hand it is an output (which would explain the 2 volt reading) you will see the output alternate between 2 volts and 5 volts.
YulL
PostPosted: Wed Sep 29, 2004 9:50 am     Reply with quote
I've invastigated and thought that the problem don't come from the PIC but from the MAX232CPE device... When I cut the connection between RC7 and MAX232 the RC7 return to 0V : normal... But the R2out of the MAX232 is always at +2V... Is the device dead??
Thanks a lot for your support Cool
asmallri
PostPosted: Wed Sep 29, 2004 9:55 am     Reply with quote
If noting else is connected to the pin then yes - your max232 is the culprit.
What about the other line receiver on pin 12? Is it in use? What is the output voltage on that pin?
YulL
PostPosted: Wed Sep 29, 2004 9:57 am     Reply with quote
Pin 12 and Pin 9 are always +2V Crying or Very sad Crying or Very sad
YulL
PostPosted: Wed Sep 29, 2004 10:24 am     Reply with quote
IT WORKS!!!!!!!!!!! Very Happy
The problem was the alimentation of the MAX232 : wrong wiring Evil or Very Mad
I'm so silly...
Rolling Eyes
Page 2 of 2
