Prashant Patel
| same code but different pulse width |
Posted: Mon Sep 27, 2004 2:32 am |
Hi...
I have used 16F877 in our projectusing 20MHz Oscillator.
And now we have only one interrupt on Timer1.
I have set the Timer1 to overflow every 0.2mSec. If I run
this code saperately, it is giving correct pulse width and
Duty Cycle. But if I use it in our project which has long
code. It is giving different pulse width. And all the pulses
are not of the same pulse width or Duty Cycle. The code inside
the interrupt is simple.
If I put the cursor at the first line of ISR and "Run To Cursor", everytime
it is giving different time and instruction cycle.
I don't know why this is happen. But think it is due to long
code. As my RAM and ROM are about to fill and I have long
code in side the main(),while loop.
Can this be reason for incorrect Pulse Width..??
I can't understand, why interrupt is not happen at proper time
when it is having long code. while the same code is giving
correct pulse width in one simple program.
If Timer is incremented every instruction cycle, why is it not
same for same oscillator and circuit.
Thanks...Any help appriciated...
Regards
Prashant |
| Re: same code but different pulse width |
Posted: Mon Sep 27, 2004 3:42 am |
| Prashant Patel wrote: | Hi...
Regards
Prashant |
Look at anything that is used inside both the ISR, and the main code. Because the processor does not have a 'stack' to hold variables (as opposed to the 'call' stack), if a routine is used inside the ISR, and is also used inside the main routine, then interrupts have to be disabled to the routine outside the ISR. This will then delay the point when you arrive inside the ISR, and give erratic timings. Some 'simple' things can trigger this (for instance a 'switch' statement that does not have a 'default'), since for this, a 'table' based jump is used, and the interrupts will be disabled for any similar jumps in the main code. Similarly certain array accesses will trigger this too. Obviously, if you manually disable interrupts at any point, the same behaviour will also result. Some code will also result in interrupts being disabled (look at program EEPROM write cycles).
Prashant Patel
| Possible reason which can stop ISR to be executed |
Posted: Mon Sep 27, 2004 3:10 pm |
Hi...
I have very simple code inside ISR to generate the
pulses of certain duty cycle. And I have only one
ISR.
Along with this, I am sending my code which is generating
correct pulse width and duty cycle. But if I use the same
code with all other code inside the main loop. Then it
is generating some pulses with double the width. Which
seems like missing at some points to execute the ISR.
Is there anything that can prevent the call of ISR..??
So that I can know that these code can prevent the ISR
to be executed. So need to change of do something else
to that code to stop to prevent ISR to be executed. Because
ISR must be executed when ever Timer1 is overflowed.
Code Details:
int16 PULSE_TIME= 65436; // To generate the pulses of some mSec.
signed int8 count;
signed int8 DCOnDuty=30;
#INT_TIMER1
void timer1_isr() {
count++;
if(count<=DCOnDuty)
output_high(PIN_D0);
output_low(PIN_D0);
set_timer1(PULSE_TIME); //Set the timer to overflow every xx mSec
if(count>=100)
count=0;
}//timer1_isr
Thanks...
Regards
Prashant |
J_Purbrick
Posted: Mon Sep 27, 2004 4:12 pm |
I'm not sure I'd have thought of what Ttelmah said, but it sounds very plausible. The compiler will suppress interrupts under some conditions and as I recall, there is no warning (I would call that a serious bug, in the microcontroller world).
Simply the length of your main() routine or the functions that it calls can't be having any effect. It's something else. |
