Yull Guest
| Only 8 characters on my 2x16 LCD!! |
Posted: Fri Sep 24, 2004 7:52 am |
Hello, I've programmed my 2x16 hitachi powered LCD using LCD.c and I can't display "123456789ABCDEF" on the first line, I have just "12345678"!!!
Here is my code :
lcd_init();
delay_ms( 20 );
lcd_gotoxy(1,1);
delay_ms( 20 );
lcd_putc("\f123456789ABCDEF\n123456789ABCDEF");
Thanks by advance for your help
P.S.: I'm using a PIC16F873 |
RICHARD Guest
Posted: Fri Sep 24, 2004 3:00 pm |
Dear Friend,
I am afriad you will have to submit the complete program list, including all the header configuration information!!!!
have you called the lcd.c --file??
is the lcd connected up correctly via port D??
Hope this helps |
Richard Guest
Posted: Fri Sep 24, 2004 3:05 pm |
Dear friend,
I am afraid that you can not have a "\n" operator,
if you want to operate on the next line you will have to have:
lcd gotoxy(x,y) //first line
lcd_putc("zzz")
lcd gotoxy(x,y) // second line
lcd_putc("zzz")
The \f, \n operator only works in the printf command!!
Regards, |
jds-pic
Posted: Fri Sep 24, 2004 3:11 pm |
| Richard wrote: |
lcd_putc("zzz")
lcd_putc("zzz")
Regards, |
or simply enable auto-wraparound in the LCD controller.
jds-pic |
Yull Guest
Posted: Fri Sep 24, 2004 3:24 pm |
Thanks for the replies, I will be trying those on Monday (week end now).
For information my LCD is put on PortB because the 16F873 don't have D port.  |
Mark
Posted: Fri Sep 24, 2004 4:43 pm |
Dear All,
I tested his code and it worked just fine. |
Posted: Fri Sep 24, 2004 4:49 pm |
| Quote: | | I am afraid that you can not have a "\n" operator, |
The lcd_putc() function does support '\n'. See the code
from the CCS driver file, LCD.C, below:
| Code: | void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
Yull Guest
Posted: Mon Sep 27, 2004 1:20 am |
Thanks a lot again for your help.
As requested, I put the entire source here :
#include "C:\Documents and Settings\xxx\Mes documents\PCW TEST\TEST.h"
#include <stdio.h>
#include <lcd.c>
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
set_tris_a (0);
lcd_init();
delay_ms( 20 );
lcd_putc("\f");
lcd_gotoxy(1,0);
delay_ms( 20 );
printf(lcd_putc,"\f123456789ABCDEF\n123456789ABCDEF");
//lcd_putc("\f123456789ABCDEF\n123456789ABCDEF");
delay_ms( 3000 );
lcd_putc("\f");
output_low(LED0);
output_low(LED1);
delay_ms( 1000 );
output_low(LED0);
output_high(LED1);
delay_ms( 1000 );
output_high(LED0);
output_low(LED1);
delay_ms( 1000 );
output_high(LED0);
output_high(LED1);
delay_ms( 1000 );
and my "test.h" :
#include <16F873.h>
#device adc=8
#use delay(clock=11059200)
#fuses HS, NOWDT, NOPROTECT, NOLVP, BROWNOUT, PUT
#define LED0 PIN_A0
#define LED1 PIN_A1
Thanks for help  |
Posted: Mon Sep 27, 2004 1:43 am |
The 2nd parameter value of 0 is not allowed by the CCS driver.
The lowest allowable value for each parameter is 1.
Here is the statement by CCS, from the LCD.C driver file:
| Quote: |
lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)
You should change your code to this:
Yull Guest
Posted: Mon Sep 27, 2004 1:47 am |
You're right, but the problem still remains...  |
Yull Guest
Posted: Mon Sep 27, 2004 5:42 am |
Not sure, but my LCD seems to be dead  |
Mark
Posted: Mon Sep 27, 2004 6:18 am |
| Did you make this board? If not, whose board is it? |
Posted: Mon Sep 27, 2004 7:15 am |
Yes it's my board, i'm waiting for a new LCD to test my code  |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Tue Sep 28, 2004 2:59 pm |
| Not sure if it will help but the 1 x 16 line display I have just used is a bit of a pain! The first 8 characters are located at 0x00 to 0x07 in the LCD memory and the next 8 were located at 0x40 to 0x47 (usually where line 2 is stored!). Might be worth checking with the LCD manufacturer where the LCD text memory is located. |
YulL Guest
Posted: Wed Sep 29, 2004 4:12 am |
I've got my 2x16 LCD and I confirm that the last one was dead!!!
Grrrrrr  |
