nader
| samsung infrared decoder |
Posted: Fri Sep 24, 2004 8:47 am |
is any body know how to decode samsung infrared controller with some ic decoder like IS1U60.
i want the algoritm of it & command code & the carrier freq.(33k or 40k) |
Mark
Posted: Fri Sep 24, 2004 10:53 am |
| Are you trying to read codes from an IR remote? |
Posted: Fri Sep 24, 2004 11:35 am |
yes.& i don't have the protocol of it.  |
Humberto
Posted: Fri Sep 24, 2004 2:32 pm |
| Quote: |
The IS1U60 it isn't a decoder, it is an Infra Red Detector that has a built in
ampliffier with a maximum gain in 38 Khz. The detector is used as the front
end device to recover the shape of the IR pulses generated remotelly.
Regarding how to decode the IR stream coming from a remote control,
google "RC5" and you will get hundreds of references how to do it.
Once you know the signature of each commands, then all you need is to
work in a program to decode them.
best wishes,
Humberto |
Mark
