spi question
ravellanag
spi question
PostPosted: Thu Sep 23, 2004 1:00 am     Reply with quote
I am using PIC16C73 to interface SPI device. bcause the device is operatiing at 3V, i am using voltage shifter 74HCT244 in between PIC and device. I am using the following code to read and send the data to device. some times i am getting correct results, some times i am not getting for the same code if i repeat more number of times. i am not getting where the mistake is. Any suggestions please?
code is as follows
#include<16C73.H>
#fuses XT,NOWDT,NOPROTECT,PUT
   static int y;
   setup_spi(spi_master|spi_l_to_h|spi_clk_div_64);
   //setup_spi(spi_master);
   delay_ms(10);
   while(1){
      spi_write(0x43);
      y=spi_read();
      spi_write(0xaa);
      y=spi_read();
Sasidhar
dvsoft
PostPosted: Thu Sep 23, 2004 1:16 am     Reply with quote
bonjour
try this
y = spi_read(0);
and read the Compiler reference Manual page 162
Bon Courrage Alain
ravellanag
PostPosted: Thu Sep 23, 2004 1:39 am     Reply with quote
Hi Bon Courrage Alain
I used y=spi_read(0), but same thing is repeating.
same code is used to do loop back without device to test SPI. same error is repeating for the above command also.
Sasidhar
dvsoft
PostPosted: Thu Sep 23, 2004 3:36 am     Reply with quote
re bonjour,
which is the version of the compiler
which is the value of Pull-Up resistors for 3.3v to 5V ?
which SPI device ?
ALain
ravellanag
PostPosted: Thu Sep 23, 2004 4:15 am     Reply with quote
compiler version is 3.028.
i am using only 74HC/HCT244, but not pull up resistor.
At this moment i did not test the program with device, i just doing a self-loopback.
Sasidhar
drh
PostPosted: Thu Sep 23, 2004 7:24 am     Reply with quote
The 74HCT244 is not a voltage shifter.
David
