LCD display
deonvds
LCD display
PostPosted: Thu Sep 23, 2004 1:25 am     Reply with quote
I need to remove and connect a LCD display. The problem is however when I remove the LCD the standard CCS LCD.C code still searches for the LCD and my program hangs. How can I check on startup if the LCD display is fitted or not and then ignore the search for the LCD display.
Mark
PostPosted: Thu Sep 23, 2004 6:08 am     Reply with quote
The problem is here:
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
You could put a timeout in there and set a flag indicating the LCD is not available.
You could add a few NOP's and a counter that would allow the routine to bail out after a period of time.
You could rewrite the routine to just give a delay after each byte to ensure the LCD is not busy.
There are probably many other ways as well. The choice is up to you.
