C help please
guest
C help please
PostPosted: Sat Sep 18, 2004 5:58 pm     Reply with quote
Hello... could someone explain to me how to point to a variable within a struct?
ie
typedef struct
int x;
int y;
} my_struct
my_struct mem;
int *ptr;
(how would I piont this pointer to x or y?
ptr = &(mem.x) ??????????
thanks for any help with C
Here is where to find your information
PostPosted: Sat Sep 18, 2004 6:52 pm     Reply with quote
This is not a C Beginner training forum. However, you can find good information on struct by simply using Google. Here is a good link I found on the first try:
http://www.iota-six.co.uk/c/h2_introduction_to_struct.asp
This site also has excellent info on pointers and the entire C language here:
http://www.iota-six.co.uk/c/default.asp
Also search this user group for the word struct and you will find lots of examples.
The book C Programming Language by Kernighan, Ritchie is an excellent reference and you should get it as soon as possible.
Amazon.com has a used copy for $19 here:
http://www.amazon.com/exec/obidos/search-handle-form/002-9403352-2272044
PostPosted: Sat Sep 18, 2004 7:33 pm     Reply with quote
Thanks for the reply - I've used pointers many times over etc... however I'm having trouble making a pointer to a member of a struct. I've read many references and I can't seem to figure this one out.
Since I'm a CCS customer, I thought I'd post my question here in case anybody could provide help.
Thanks.
bdavis
PostPosted: Sun Sep 19, 2004 8:59 am     Reply with quote
I would suggest buying the K&R book for an ANSI 'C' reference, and another book for learning 'C'. You may also want to consider using a different compiler for learning C because the CCS does not have as good of error or warning messages as a large C compiler would. You could get the Borland , or Watcom C for free I think, or a used copy of Visual C++.
Here is your answer....
PostPosted: Sun Sep 19, 2004 10:11 am     Reply with quote
I searched this user group with the specifiers "struct AND pointer" and found the answer to to your question.
Please see this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=19428
valemike
PostPosted: Sun Sep 19, 2004 12:04 pm     Reply with quote
example:
struct mike_s
int x;
int y;
struct mike_s michael; // michael
struct mike_s *michael_ptr; // uninitialized pointer to mike_s
michael_ptr = michael; // this initialized the pointer to point to something meaningful
//now you can do stuff to the structure...
michael_ptr->x = 20;
Similiarly, you can do the following:
michael.x = 20;
So, if you work directly on the struct, you use a ".", but if you use a pointer to the structure, then you use a "->"
guest
PostPosted: Mon Sep 20, 2004 4:23 pm     Reply with quote
Again, thanks for replies.
Maybe I should explain more of what I'm trying since received answers aren't what I'm looking for ->
typedef struct{
int x;
int y;
int *ptr;
}mystruct
mystruct xyz;
xyz.x = 2;
xyz.y = 5;
/* now I'd like to point ptr at either x or y; */
xyz.ptr = &(xyz.x);
Is this not valid in CCS? My GCC compiler does not complain and printing out results shows that this is fine, but my CCS gives me a warning (I can't recall what that warning exactly says, since I am not at home at work at the moment).
Mark
PostPosted: Mon Sep 20, 2004 5:37 pm     Reply with quote
This works just fine. No complaints except for the endless while(1)
#include<16F876.h>
//#include<16F648A.h>
#fuses HS,NOPROTECT,WDT,PUT,NOLVP
typedef struct
  int x;
  int y;
  int *ptr;
}mystruct;
mystruct xyz;
  xyz.x = 2;
  xyz.y = 5;
  xyz.ptr = &(xyz.x);
