Kinda "pointer to function" question!
Markus
PostPosted: Tue Sep 14, 2004 7:50 am     Reply with quote
Heyhey!
This code works:
#device *=16
byte Read(myData index) {
    return *index;
void main() {
    typedef byte *myData;
    typedef byte (*readFunc)(myData index);
    readFunc  do_Read;
    do_Read = Read;
But this one doesn't:
#device *=16
    return *index;
void main() {
    typedef int16 (*readFunc)(myData index);
    readFunc  do_Read;
    do_Read = Read;     // (*)
It returns with:
CCS 3.184 wrote:
*** Error 118 "...\test.c" Line (*): Invalid type conversion
What am I missing?
Markus
Mark
PostPosted: Tue Sep 14, 2004 10:27 am     Reply with quote
The function is declared with a return value of a byte and not int16
Markus
PostPosted: Tue Sep 14, 2004 11:35 am     Reply with quote
Mark, you're right. I made this mistake while writing my first post. It _is_ defined as int16 in the project, but that doesn't work (see above)...
Markus
Mark
PostPosted: Tue Sep 14, 2004 11:50 am     Reply with quote
Not sure what you are trying to do but this works just fine:
#if defined(__PCM__)
#include <16f877.h>
#device *=16
#elif defined(__PCH__)
#include <18f452.h>
#device *=16
#endif
int16 Read(myData index)
  return *index;
  readFunc  do_Read;
  mydata test;
  byte input = 123;
  int16 result;
  test = &input;
  do_Read = Read;
  result = (*do_Read)(test);
Tom-H-PIC
pointers to function ?
PostPosted: Tue Sep 14, 2004 1:20 pm     Reply with quote
Ok the question do pointers work with function or not?
Maybe I have not totally thought this through but what is the point of the pointer to a function thing?
If a person writes a function and uses it in code the compiler uses a goto in the list file to jump to the function. To me this would be the same as a pointer to the function.
Or are we saying that we would be able to use pointers to a function like a pointer to fprintf and only have one fprintf in the total code.
Thanks guys it will help if you can help clear up my thinking on this.
Mark
PostPosted: Tue Sep 14, 2004 1:30 pm     Reply with quote
With a pointer to a function, you can dynamically assign a function call to a variable and then call it. It is great for doing menus and command parsers. You only need one handler and typically get the function addresses from a constant look up table. Here is another use. Let say you have a device that has 2 ports. Lets say you want to be able to select which port the data goes out at runtime. Well you just create 2 functions. One for each port. Now all your output uses the function pointer. Simply set the pointer equal to the function that you want to use (maybe something like
if (debug)
  pFunc = DebugOutput;
  pFunc = NormalOutput;
) does it make sense yet?
More reading: http://www.ccsinfo.com/forum/viewtopic.php?t=20416
Trampas
PostPosted: Tue Sep 14, 2004 7:03 pm     Reply with quote
Another example of using pointer to function is in state machines. Do you guys remeber Melly and Moore (spelling?) state machines? Well you can set up a table of states and what function to call when you are in that state and/or what function to call when you change states.
Trampas
Bilk
pointers to functions
PostPosted: Thu Sep 16, 2004 1:21 pm     Reply with quote
Beware: I have found that pointers to functions work -- but there seems to be a problem if an interrupt occurs exactly when the pointer to function call is being pushed.
The ISR_() destroys the stack push and the program continues neatly. The desired (*ptr_funct)() is then never called.
Workaround, disable interrupts immediately prior to making (*ptr_funct)(); call and renable as first item in called functions.
Compiler version 3.208 - PIC18f452
