ICDWarn0035: Debug mode must be disabled. Disable debug mo
franckcl
PostPosted: Tue Sep 14, 2004 8:07 am     Reply with quote
MPLAB 6.60, CCS 2.07, PIC 16F876
When I run MPLAB in programmer mode, and when I program the PIC I have this error message :
"ICDWarn0035: Debug mode must be disabled. Disable debug mode or cancel?"
Is there a solution in the fuses?? to remove this message.
Thank you
Franck
Mark
PostPosted: Tue Sep 14, 2004 10:25 am     Reply with quote
Do you have ICD=True in your code? If so, comment it out.
franckcl
PostPosted: Wed Sep 15, 2004 12:44 am     Reply with quote
here is my program :
#device PIC16F876
void Main()
And when I try to program the pic, I have always this error message.
Franck
Haplo
PostPosted: Wed Sep 15, 2004 1:31 am     Reply with quote
For the starters, ALWAYS include the corect header file for your PIC and make sure you have proper #fuses settings in your code. Something like:
#include <16F876.h>
#fuses XT, NOWDT, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
franckcl
PostPosted: Wed Sep 15, 2004 1:53 am     Reply with quote
It's works !!! I don't know why but it's works !!!
I have copy my project in an other one with a different name and now, I don't have this error message.
Strange..........
thank you for your help
Franck
Mark
PostPosted: Wed Sep 15, 2004 5:52 am     Reply with quote
NODEBUG
Haplo
PostPosted: Wed Sep 15, 2004 4:59 pm     Reply with quote
As I said, always include the corect header file for your PIC and make sure you have proper #fuses settings in your code. Fuses like XT (oscillator type), NOLVP (No voltage programming) and NODEBUG are important (based on your circuit you may need to choose other values for them though).
And never let your code reach the end of main(). Always use a while(1); or something similar to prevent this.
