2 wire SPI
Markus
2 wire SPI
PostPosted: Thu Sep 09, 2004 6:51 am     Reply with quote
Dear experts,
I'm using a 16LF877A to interface a GLCD with a built-in controller. Unfortunately the display uses some weird sort of SPI hardware. The MOSI and MISO lines are tied together. I connected this line to the PIC's SDO pin. Result: I'm able to write data but I can't generate the clock and read the data from the display 'by hand' (although I set the TRIS register correctly depending on read/write).
So, what are your suggestions? Get rid of the MSSP and communicate with the LCD via normal digital pins (software SPI)?
Markus
rnielsen
PostPosted: Thu Sep 09, 2004 8:39 am     Reply with quote
Do you have a manufacturer/model# or specifications for the display? It might help to see what it's communication specifications are before replying with any advice.
Ronald
valemike
PostPosted: Fri Sep 10, 2004 4:54 am     Reply with quote
I've done two-wired signaling for a vacuum fluorescent display, and it was a nonstandard scheme. I pretty much just had to designate my two pins as digital i/o and bitbang away.
I havent done much SPI in my life, but i don't think a 2-wired spi exists. Perhaps you are really seeing an "I2C" diagram, but the lcd manufacturer doesn't want to call it "i2c" because it is trademarked?
2 wire SPI - does /CS count?
PostPosted: Fri Sep 10, 2004 8:40 pm     Reply with quote
The Dallas DS1302 Timekeeping Chip is a 3-wire "SPI": /CS (chip select), CLK (clock), and I/O (data input/output). The I/O line is bidirectional. In the data sheet they call it "synchronous serial communication," not SPI.
I believe the term "SPI" is trademarked.
Gotta bang those bits by hand I think. Its more fun this way anyway.....
Mike
Markus
PostPosted: Tue Sep 14, 2004 7:32 am     Reply with quote
First of all, I made it work by using a mixture of bitbang and the built-in MSSP module.
Nope, unfortunately not, since it is an OEM Display. All I know is the pin-out and the controller, Philips PCF8833. There is a SDIN and a SDOUT pin on the controller, but on the connector there's only one SDATA pin (SDIN + SDOUT).
It seems like it does exist. In this case it is called "a 3-line bidirectional interface". It's not I2C since there are no start/stop bits and no acks/nacks.
Mike
After hours of headaches I can say: You're right, Mike! Wink But before it was totally new to me...
BTW: I don't agree with your last sentence! Smile
Thank you, guys!
Markus
