pdiusbd12
nader
pdiusbd12
PostPosted: Mon Sep 06, 2004 10:39 am     Reply with quote
i try to handle pdiusbd12 with pic . i have a little problem on it.
if any want to see my code easily meil me 7 then i will send the code.
if any one have an information that think is good for this please tell me.
thanks.
Markus
PostPosted: Mon Sep 06, 2004 1:58 pm     Reply with quote
nader, why don't you post your code on the forum?
You may also want to take a look at www.beyondlogic.org (as I suggested in your other thread) and at John Hyde's examples from his book "USB Design by Example". Here you can find sample codes for Philips' D11 and D12: http://www.intel.com/intelpress/usb/examples/download.htm
Markus
PS: What exactly are the problems you are experiencing?
nader
d12
PostPosted: Tue Sep 07, 2004 1:25 am     Reply with quote
hi,thanks for interest.
do exactly what beyond logic siad.
at power up i have one bus reset intrrupt & one suspend change intrrupt & a lot of ENDP0 out intrrupt.
but when i read last transaction status register for this endpoint(endp0out) it is not a setup packet so
i can't begin the enumeration & windows after about 17 secend show " USB Device Not Recognized".
during this time i have tree pulses of good link led.(good link led is turn on & off tree time)
i also see philips site but nothing for help.if you know someone in philips that can help me please give me his or her email.
i really need some one suggestion or help.
i need a flow chart for when the d12 power up.i don't have problem with
the protocol.
i try to send my code to forums but its alittle large.
please see my code & help me
thanks a lot.
nader
code
PostPosted: Tue Sep 07, 2004 1:32 am     Reply with quote
void usb_init(void)
set_tris_usb_data(0x00); // make it out put
set_tris_usb_control(0x07); //deafult
D12_CS_N = 1; //deactive d12cs
D12_A0 = 0;
D12_WR_N = 1;
D12_RD_N = 1;
D12_RST_N = 1; //reset d12
void D12_Cmd(unsigned int8 Command)
D12_Data = Command;
D12_A0 = 1; //edge up
D12_WR_N = 0;
D12_CS_N = 0; //active d12cs
D12_WR_N = 1;
D12_A0 = 0; //edge dowm
D12_CS_N = 1; //off
delay_cycles(5); //500ns delay for next command
void D12_Data_Write(unsigned int8 Data)
D12_DATA = Data;
D12_WR_N = 0;
D12_WR_N = 1;
D12_CS_N = 1; //off
unsigned int8 D12_Data_Read(void)
unsigned int8 data;
set_tris_usb_data(0xFF); //make it input
D12_RD_N = 0;
data = D12_DATA; //get data
D12_RD_N = 1;
set_tris_usb_data(0xFF); //make it out put
delay_cycles(5);
return(data);
void D12_Cmd_write(unsigned char command,unsigned char *buffer,unsigned char count)
unsigned char i = 0;
d12_cmd(command);
while(count)
d12_data_write(*(buffer+i));
count--;
i++;
void D12_Cmd_read(unsigned char command,unsigned char *buffer,unsigned char count)
d12_cmd(command);
while(count)
*(buffer+i) = d12_data_read();
count--;
i++;
void usb_reconnect(void)
unsigned char buff[2];
//set mode disconnect
buff[0] = D12_NOLAZYCLOCK;
buff[1] = D12_SETTOONE|D12_CLOCK_4M;
D12_Cmd_write(D12_SET_MODE,buff,2);
//delay_ms(1000);
//set dma
buff[0] = 0xc0;
D12_Cmd_write(D12_SET_DMA,buff,1);
//set mode connect
buff[0] = 0x16; //soft connect
void ErrorStallControlEndPoint(void)
unsigned char Buffer[] = { 0x01 };
D12_Cmd_write(D12_SET_ENDPOINT_STATUS + D12_ENDPOINT_EP0_IN, Buffer, 1);
D12_Cmd_write(D12_SET_ENDPOINT_STATUS + D12_ENDPOINT_EP0_OUT, Buffer, 1);
unsigned char D12ReadEndpoint(unsigned char Endpoint,unsigned char *Buffer)
unsigned char D12Header[2];
unsigned char BufferStatus = 0;
/* Select Endpoint */
D12_Cmd_read(Endpoint, &BufferStatus, 1);
/* Check if Buffer is Full */
if(BufferStatus & 0x01)
D12_Cmd_read(D12_READ_BUFFER, D12Header, 2);
if(D12Header[1]) /* Have some thing for read? */
D12_Cmd_read(D12_READ_BUFFER, Buffer, D12Header[1]);
/* Allow new packets to be accepted */
D12_Cmd_write(D12_CLEAR_BUFFER, NULL, 0);
return D12Header[1]; /* return the length of data read */
void D12WriteEndpoint(unsigned char Endpoint,unsigned char *Buffer,unsigned char Bytes)
D12Header[0] = 0x00;
D12Header[1] = Bytes;
/* Write Header */
D12_Cmd_write(D12_WRITE_BUFFER, D12Header, 2);
/* Write Packet */
if(Bytes)
D12_Cmd_write(D12_WRITE_BUFFER, Buffer, Bytes);
/* Validate Buffer */
D12_Cmd_write(D12_VALIDATE_BUFFER, NULL, 0);
void WriteBufferToEndPoint(void) //-for control endpoint send descriptor-//
if (BytesToSend == 0)
/* If BytesToSend is Zero and we get called again, assume buffer is smaller */
/* than Setup Request Size and indicate end by sending Zero Lenght packet */
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, NULL, 0);
else if (BytesToSend >= ENP0_BUFFER_SIZE)
/* Write another 8/16 Bytes to buffer and send */
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, pSendBuffer, ENP0_BUFFER_SIZE);
pSendBuffer += ENP0_BUFFER_SIZE;
BytesToSend -= ENP0_BUFFER_SIZE;
} else {
/* Buffer must have less than 8/16 bytes left */
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, pSendBuffer, BytesToSend);
BytesToSend = 0;
void loadfromcircularbuffer(void)
unsigned char Buffer[2+ENP1_BUFFER_SIZE];
unsigned char count;
// Read Buffer Full Status
D12_Cmd_read(D12_ENDPOINT_EP1_IN, Buffer, 1);
if(Buffer[0] == 0)
// Buffer Empty
if(inpointer != outpointer)
// We have bytes to send
count = 0;
do {
Buffer[count++] = circularbuffer[outpointer++];
if(outpointer >= MAX_BUFFER_SIZE) outpointer = 0;
if(outpointer == inpointer) break; // No more data
} while (count < ENP1_BUFFER_SIZE); // Maximum Buffer Size
// Now load it into EP1_In
D12WriteEndpoint(D12_ENDPOINT_EP1_IN, Buffer, count);
void GetDescriptor(PUSB_SETUP_REQUEST SetupPacket)
switch((SetupPacket->wValue & 0xFF00) >> 8)
case TYPE_DEVICE_DESCRIPTOR:
pSendBuffer = (unsigned char *)&DeviceDescriptor;
BytesToSend = DeviceDescriptor.bLength;
if (BytesToSend > SetupPacket->wLength)
BytesToSend = SetupPacket->wLength;
WriteBufferToEndPoint();
case TYPE_CONFIGURATION_DESCRIPTOR:
pSendBuffer = (unsigned char *)&ConfigurationDescriptor;
BytesToSend = sizeof(ConfigurationDescriptor);
case TYPE_STRING_DESCRIPTOR:
switch (SetupPacket->wValue & 0xFF)
case 0 : pSendBuffer = (unsigned char *)&LANGID_Descriptor;
BytesToSend = sizeof(LANGID_Descriptor);
case 1 : pSendBuffer = (unsigned char *)&Manufacturer_Descriptor;
BytesToSend = sizeof(Manufacturer_Descriptor);
default : pSendBuffer = NULL;
BytesToSend = 0;
if(BytesToSend > SetupPacket->wLength)
default:
ErrorStallControlEndPoint();
void Process_EP0_OUT_Interrupt(void)
unsigned char Buffer[2];
USB_SETUP_REQUEST SetupPacket;
/* Check if packet received is Setup or Data - Also clears IRQ */
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP0_OUT, (unsigned char *)&SetupPacket, 1);
// for debug
enp0++;
lcd_command(0x8B);
printf(lcd_write,"P0:%x",enp0);
IF(SetupPacket.bmRequestType & D12_LAST_TRAN_SETUP)
// for debug
lcd_command(0x8B);
printf(lcd_write,"welcome");
/* This is a setup Packet - Read Packet */
D12ReadEndpoint(D12_ENDPOINT_EP0_OUT, (char *)&SetupPacket);
/* Acknowlegde Setup Packet to EP0_OUT & Clear Buffer*/
D12_Cmd_write(D12_ACK_SETUP, NULL, 0);
/* Acknowlegde Setup Packet to EP0_IN */
D12_Cmd_write(D12_ENDPOINT_EP0_IN, NULL, 0);
/* Parse bmRequestType */
switch (SetupPacket.bmRequestType & 0x7F) {
case STANDARD_DEVICE_REQUEST:
switch (SetupPacket.bRequest)
case GET_STATUS:
/* Get Status Request to Device should return */
/* Remote Wakeup and Self Powered Status */
Buffer[0] = 0x01;
Buffer[1] = 0x00;
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, Buffer, 2);
case CLEAR_FEATURE:
case SET_FEATURE:
/* We don't support DEVICE_REMOTE_WAKEUP or TEST_MODE */
case SET_ADDRESS:
DeviceAddress = SetupPacket.wValue | 0x80;
CtlTransferInProgress = PROGRESS_ADDRESS;
case GET_DESCRIPTOR:
GetDescriptor(&SetupPacket);
case GET_CONFIGURATION:
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, &DeviceConfigured, 1);
case SET_CONFIGURATION:
DeviceConfigured = SetupPacket.wValue & 0xFF;
if(DeviceConfigured)
LCD.RC0 = 1; /* turn on configure Led */
LCD.RC0 = 1; /* Device Not Configured */
case SET_DESCRIPTOR:
default:
/* Unsupported - Request Error - Stall */
case STANDARD_INTERFACE_REQUEST:
case GET_STATUS:
/* Get Status Request to Interface should return */
/* Zero, Zero (Reserved for future use) */
Buffer[0] = 0x00;
Buffer[1] = 0x00;
case SET_INTERFACE:
/* Device Only supports default setting, Stall may be */
/* returned in the status stage of the request */
if(SetupPacket.wIndex == 0 && SetupPacket.wValue == 0)
/* Interface Zero, Alternative Setting = 0 */
case GET_INTERFACE:
if(SetupPacket.wIndex == 0)
{ /* Interface Zero */
Buffer[0] = 0; /* Alternative Setting */
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, Buffer, 1);
} /* else fall through as RequestError */
//case CLEAR_FEATURE:
//case SET_FEATURE:
/* Interface has no defined features. Return RequestError */
default:
case STANDARD_ENDPOINT_REQUEST:
case CLEAR_FEATURE:
case SET_FEATURE:
/* Halt(Stall) feature required to be implemented on all Interrupt and */
/* Bulk Endpoints. It is not required nor recommended on the Default Pipe */
if(SetupPacket.wValue == ENDPOINT_HALT)
if(SetupPacket.bRequest == CLEAR_FEATURE)
Buffer[0] = 0x00;
Buffer[0] = 0x01;
switch (SetupPacket.wIndex & 0xFF)
case 0x01 : D12_Cmd_write(D12_SET_ENDPOINT_STATUS + \
D12_ENDPOINT_EP1_OUT, Buffer, 1);
case 0x81 : D12_Cmd_write(D12_SET_ENDPOINT_STATUS + \
case 0x02 : D12_Cmd_write(D12_SET_ENDPOINT_STATUS + \
D12_ENDPOINT_EP2_OUT, Buffer, 1);
case 0x82 : D12_Cmd_write(D12_SET_ENDPOINT_STATUS + \
D12_ENDPOINT_EP2_IN, Buffer, 1);
default : /* Invalid Endpoint - RequestError */
D12WriteEndpoint(D12_ENDPOINT_EP0_IN, NULL, 0); /* zero packet */
/* No other Features for Endpoint - Request Error */
case GET_STATUS:
/* Get Status Request to Endpoint should return */
/* Halt Status in D0 for Interrupt and Bulk */
case 0x01 : D12_Cmd_read(D12_READ_ENDPOINT_STATUS + \
case 0x81 : D12_Cmd_read(D12_READ_ENDPOINT_STATUS + \
case 0x02 : D12_Cmd_read(D12_READ_ENDPOINT_STATUS + \
case 0x82 : D12_Cmd_read(D12_READ_ENDPOINT_STATUS + \
if(Buffer[0] & 0x80)
Buffer[0] = 0x01;
Buffer[0] = 0x00;
Buffer[1] = 0x00;
default:
/* Unsupported - Request Error for Endpoint- Stall */
case VENDOR_DEVICE_REQUEST:
case VENDOR_ENDPOINT_REQUEST:
case VENDOR_GET_ANALOG_VALUE:
set_adc_channel((SetupPacket.wIndex & 0x07));
delay_us(10);
ADGO = 1;
while(ADGO);
Buffer[0] = ADRESL;
Buffer[1] = ADRESH;
case VENDOR_SET_RB_HIGH_NIBBLE:
lcd_command(0xD4);
printf(lcd_write,"vender:%u",(SetupPacket.wIndex >> 4) );
/* zero length packet */
default:
default:
///* This is a Data Packet */
#include "E:\ccs\pd12 cypress\TEST.h"
#include "USB_d12_defines.c"
#include "USB_variables.c"
#include "USB_18f452_defines.c"
#include "lcd_18F452.c"
//--------------------public variable-----------------------------//
unsigned int8 c = 0,b = 0,s = 0;
unsigned int8 enp0 = 0,enp1 = 0;
unsigned char circularbuffer[MAX_BUFFER_SIZE];
unsigned char inpointer;
unsigned char outpointer;
unsigned char * pSendBuffer;
unsigned char BytesToSend;
unsigned char CtlTransferInProgress;
unsigned char DeviceAddress;
unsigned char DeviceConfigured;
//---------------------define the usb descriptors-----------------//
USB_DEVICE_DESCRIPTOR DeviceDescriptor = {
sizeof(USB_DEVICE_DESCRIPTOR), /* bLength */
TYPE_DEVICE_DESCRIPTOR, /* bDescriptorType */
0x0110, /* bcdUSB USB Version 1.1 */
0, /* bDeviceClass */
0, /* bDeviceSubclass */
0, /* bDeviceProtocol */
ENP0_BUFFER_SIZE, /* bMaxPacketSize 8/16 Bytes */
0x04B4, /* USB Thermometer Example */
0x0002,
0x0000, /* bcdDevice */
1, /* iManufacturer String Index */
0, /* iProduct String Index */
0, /* iSerialNumber String Index */
1 /* bNumberConfigurations */
USB_CONFIG_DATA ConfigurationDescriptor = {
{ /* configuration descriptor */
sizeof(USB_CONFIGURATION_DESCRIPTOR),/* bLength */
TYPE_CONFIGURATION_DESCRIPTOR, /* bDescriptorType */
sizeof(USB_CONFIG_DATA), /* wTotalLength */
1, /* bNumInterfaces */
1, /* bConfigurationValue */
0, /* iConfiguration String Index */
0x80, /* bmAttributes Bus Powered,
No Remote Wakeup */
0x32 /* bMaxPower, 100mA */
{ /* interface descriptor */
sizeof(USB_INTERFACE_DESCRIPTOR), /* bLength */
TYPE_INTERFACE_DESCRIPTOR, /* bDescriptorType */
0, /* bInterface Number */
0, /* bAlternateSetting */
2, /* bNumEndpoints */
0xFF, /* bInterfaceClass (Vendor specific) */
0xFF, /* bInterfaceSubClass */
0xFF, /* bInterfaceProtocol */
0 /* iInterface String Index */
{ /* endpoint descriptor */
sizeof(USB_ENDPOINT_DESCRIPTOR), /* bLength */
TYPE_ENDPOINT_DESCRIPTOR, /* bDescriptorType */
0x01, /* bEndpoint Address EP1 OUT */
0x02, /* bmAttributes - Interrupt */
0x0008, /* wMaxPacketSize */
0x00 /* bInterval */
0x81, /* bEndpoint Address EP1 IN */
/* LANGID String Descriptor Zero */
USB_LANGID_DESCRIPTOR LANGID_Descriptor = {
sizeof(USB_LANGID_DESCRIPTOR), /* bLength */
TYPE_STRING_DESCRIPTOR, /* bDescriptorType */
0x0409 /* LANGID US English */
/* ManufacturerString 1 */
USB_MANUFACTURER_DESCRIPTOR Manufacturer_Descriptor = {
sizeof(USB_MANUFACTURER_DESCRIPTOR),/* bLenght */
"B0e0y0o0n0d0 0L0o0g0i0c" /* ManufacturerString in UNICODE */
#include "USB_d12_functions.c"
void Usb_int_isr(void)
unsigned char IRQ[2],temp[2];
unsigned char Buffer[ENP1_BUFFER_SIZE];
unsigned char bytes;
/* Read Interrupt Register to determine source of interrupt */
D12_Cmd_read(D12_READ_INTERRUPT_REGISTER,Irq,2);
lcd_command(0x80);
/* Find the source of intrrupt */
IF(Irq != 0)
/* busreset */
if(IRQ[0] & D12_INT_BUSRESET)
{ // for debug
b++;
lcd_command(0x80);
printf(lcd_write,"B:%3u",b);
D12_SUSPEND = 1;
temp[0] = 0x80;
D12_Cmd_write(D12_SET_ADDRESS_ENABLE,temp,1);
temp[0] = 1;
D12_Cmd_write(D12_SET_ENDPOINT_ENABLE,temp,1);
/* suspend change */
if(IRQ[0] & D12_INT_SUSPENDCHANGE)
{ // for debug
s++;
lcd_command(0x86);
printf(lcd_write,"S:%3u",s);
/* endpoint 0 out */
if(IRQ[0] & D12_INT_ENDP0OUT)
Process_EP0_OUT_Interrupt();
/* endpoint 0 in */
if(IRQ[0] & D12_INT_ENDP0IN)
{ // for debug
enp1++;
lcd_command(0xC0);
printf(lcd_write,"P1:%3u",enp1);
if(CtlTransferInProgress == PROGRESS_ADDRESS)
D12_Cmd_write(D12_SET_ADDRESS_ENABLE,&DeviceAddress,1);
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP0_IN, Buffer, 1);
CtlTransferInProgress = PROGRESS_IDLE;
/* endpoint 1 out */
if(IRQ[0] & D12_INT_ENDP1OUT)
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP1_OUT, Buffer, 1);
bytes = D12ReadEndpoint(D12_ENDPOINT_EP1_OUT, Buffer);
for(count = 0; count < bytes; count++)
circularbuffer[inpointer++] = Buffer[count];
if(inpointer >= MAX_BUFFER_SIZE)
inpointer = 0;
loadfromcircularbuffer(); //Kick Start
/* endpoint 1 in */
if(IRQ[0] & D12_INT_ENDP1IN)
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP1_IN, Buffer, 1);
/* endpoint 2 out */
if(IRQ[0] & D12_INT_ENDP2OUT)
{ /* clear the intrrupt flag */
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP2_OUT, Buffer, 1);
Buffer[0] = 0x01; /* Stall Endpoint */
D12_Cmd_write(D12_SET_ENDPOINT_STATUS + D12_ENDPOINT_EP2_OUT, Buffer, 1);
/* endpoint 2 in */
if(IRQ[0] & D12_INT_ENDP2IN)
D12_Cmd_read(D12_READ_LAST_TRANSACTION + D12_ENDPOINT_EP2_IN, Buffer, 1);
D12_Cmd_write(D12_SET_ENDPOINT_STATUS + D12_ENDPOINT_EP2_IN, Buffer, 1);
c++; /* number of unknown intrrupt*/
lcd_command(0xD4);
printf(lcd_write,"unknown int:%3u",c);
{ unsigned char b[2];
inpointer = 0;
outpointer = 0;
lcd_init();
usb_init();
LCD.RC0 = 0; //turn off configure led//
setup_adc_ports(AN0_AN1_AN2_AN3_AN4);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
disable_interrupts(GLOBAL);
delay_ms(2);
usb_reconnect();
while(1) //main loop
if(!D12_INT_N)
Usb_int_isr();
Markus
Re: d12
PostPosted: Tue Sep 07, 2004 3:50 am     Reply with quote
Hi nader.
I don't have enough time to get through your entire code, sorry. I developed a 16F876A firmware for the D11 several months ago. But I never used the D12.
But here is a LogFile that I once found very useful to locate my bugs: http://www.devasys.com/PD11x/hidmouse.txt It should work for your D12 as well.
Markus
