Andreas Guest
| AGAIN : Const Array |
Posted: Sat Sep 04, 2004 4:56 am |
Hi to all users of CCS C18 !
I am running in the same problem as a lot of other users had allready and after reading 95% of all of this forum I couldnt get a solution.
I need to have a string array with Messages in the flash stored, so if
there is a power shortage no information will get lost.
Here You will find my code, extracted of my large project.
I hope somebody can help me to find my misstake , if there is one.
unfortunatly I have seen today, that there was a bug with large const array fixed in the last version, but as I bought this compiler 34 days ago, I cant get the update without paying again 50% of the new price !!!!!!!
S thank You veray much in advance for every answer which might bring me to a solution.
The problems are commented in the listing.
Best regards
Andreas (Austria)
#include <stdio.h>
char Pin_Def[36][35];
byte const table[5]={1,2,3,4,5};
const char Pin_defF[36][35] = {"Eingang 0 Aktiv , Level ","Eingang 1 Aktiv , Level ",
"Eingang 2 Aktiv , Level ","Eingang 3 Aktiv , Level ","Eingang 4 Aktiv , Level ","Eingang 5 Aktiv , Level ",
"Eingang 6 Aktiv , Level ","Eingang 7 Aktiv , Level ","Eingang 8 Aktiv , Level ","Eingang 9 Aktiv , Level ",
"Eingang 10 Aktiv , Level ","Eingang 11 Aktiv , Level ","Eingang 12 Aktiv , Level ","Eingang 13 Aktiv , Level ",
"Eingang 14 Aktiv , Level ","Eingang 15 Aktiv , Level ","Eingang 16 Aktiv , Level ","Eingang 17 Aktiv , Level ",
"Eingang 18 Aktiv , Level ","Eingang 19 Aktiv , Level ","Eingang 20 Aktiv , Level ","Eingang 21 Aktiv , Level ",
"Eingang 22 Aktiv , Level ","Eingang 23 Aktiv , Level ","Eingang 24 Aktiv , Level ","Eingang 25 Aktiv , Level ",
"Eingang 26 Aktiv , Level ","Eingang 27 Aktiv , Level ","Eingang 28 Aktiv , Level ","Eingang 29 Aktiv , Level ",
"Eingang 30 Aktiv , Level ","Eingang 31 Aktiv , Level ","Eingang 32 Aktiv , Level "};
const char cmd[35][10] = {"test1","test2","test3","test4","test5","test6","test7","test8","test9",
"test10","test11","test12","test13","test14","test15","test16","test17","test18","test19","test20",
"test21","test22","test23","test24","test25","test26","test27","test28","test29","test30","test31",
"test32","test33","test34","test35"};
char temp[16];
typedef struct {
char line[20];
}dLine;
const dLine DisplayMsg[] =
{"xEingang 0,Level "},
{"xEingang 1,Level "},
{"xEingang 2,Level "},
{"xEingang 3,Level "},
{"xEingang 4,Level "},
BYTE ic;
BYTE i;
Byte c;
Char Level;
Byte index;
Byte Disp;
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,0xFF,8);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_4);
setup_ccp2(CCP_PWM);
setup_vref(FALSE);
set_timer3(0xFA20);
for (i=0;i<35;++i) // Writing to RAM Array works Fine !
sprintf(Pin_def[i],"Eingang Nr:%2u Level : ", i);
for (ic=0;ic<35;++ic) // Reading from RAM Array works Fine 1
fprintf(com1,Pin_def[ic]);
fprintf(com1," \n\r");
fprintf(com1," \n\r\n\r");
for (ic=0;ic<35;++ic) // Reading from Flash Array doesnt work !! WHY !!!!
strcpy(Disp," ");
strcpy(Disp,Pin_defF[ic]);
fprintf(com1,Disp);
fprintf(com1," %C \n\r",ic);
delay_ms(15);
for (i = 0;i<3;i ++){ // Also Reading from const array with this routine doenst work! WHY !!
for (ic=0;ic<18;ic ++)
index = DisplayMsg[i].line[ic];
if (!index) break;
fprintf(com1,index);
for (i=0;i < 35;i++) // This is working, but only until it gets to print test26, after that it is
{ // printing only "1" in the next line "2" up to "9" !!!!
strcpy(temp,cmd[i]);
fprintf(com1,temp);
} //while(1)
} //main |
bdavis
Joined: 31 May 2004 Posts: 86 Location: Colorado Springs, CO
Posted: Sat Sep 04, 2004 9:08 am |
I would call CCS and ask them nicely if you can get the previous version that was not beta - I would think they would give you a one day download privledge to do that if you're version doesn't work and it has only been a few days since your download privledges have expired. Then of course hope the non-beta version does work.  |
Andreas Guest
Posted: Sat Sep 04, 2004 10:19 am |
Thank You bdavis for Your answer, of course I will ask them.
It is just borring to find out, that all the 8 days work would have been done
just by using an older version.
So what is the policy ? Making new bugs to get the customer buying new versions ?????
best regards
Andreas |
bdavis
Posted: Sat Sep 04, 2004 11:04 am |
| I think (?) that they post Beta's to get more testing from others - good for them and good for us. If they would only post known issues as they are found in the current Beta (or all Beta's since last official release). I usually download and save all versions of the compiler, and especially the last official non-Beta release in case I find a bug much further down the road. I think the people that work at CCS are nice, and would think that they could help since it has only been a few days and the official release is several versions older than the current Beta you downloaded. |
