Measuring a Pulse with 1us resolution
Acetoel
PostPosted: Sat Mar 22, 2003 2:46 pm     Reply with quote
I new to measure a very short pulse (from 80uSec to 1000uSec). The measurement has to start with a High-To-Low trasnsition, here the program must measure the Low state and stops to measure when a Low-To-High Transition occurs.
Is this possible with this resolution? I can implenet something similar with Pic*Basic*Pro, but would like to do it with C.
Ezequiel
___________________________
Original Post ID: 12961
Shane Rowell
Re: Measuring a Pulse with 1us resolution
PostPosted: Sun Mar 23, 2003 1:31 am     Reply with quote
I am not sure what device you are using, but here is what is possible.
If you have a device with CCP1 and CCP2 you can tie the two pins together and set one for falling edge and the other for rising edge. Knowing the polarity of your signal you can then determine the pulse width. You should be able to achieve .2uS resolution.
Shane
:=Hello,
:= I new to measure a very short pulse (from 80uSec to 1000uSec). The measurement has to start with a High-To-Low trasnsition, here the program must measure the Low state and stops to measure when a Low-To-High Transition occurs.
:= Is this possible with this resolution? I can implenet something similar with Pic*Basic*Pro, but would like to do it with C.
:=Thanks
:=Ezequiel
Original Post ID: 12967
Acetoel
PostPosted: Sun Mar 23, 2003 5:21 am     Reply with quote
I'm using a 16F76 at 16MHz. Do you have a piece of code?
Eze
:=I am not sure what device you are using, but here is what is possible.
:=If you have a device with CCP1 and CCP2 you can tie the two pins together and set one for falling edge and the other for rising edge. Knowing the polarity of your signal you can then determine the pulse width. You should be able to achieve .2uS resolution.
:=Shane
:=:=Hello,
:=:= I new to measure a very short pulse (from 80uSec to 1000uSec). The measurement has to start with a High-To-Low trasnsition, here the program must measure the Low state and stops to measure when a Low-To-High Transition occurs.
:=:= Is this possible with this resolution? I can implenet something similar with Pic*Basic*Pro, but would like to do it with C.
:=:=Thanks
:=:=Ezequiel
Original Post ID: 12970
Humberto
PostPosted: Sun Mar 23, 2003 2:52 pm     Reply with quote
:=Hi,
:= I'm using a 16F76 at 16MHz. Do you have a piece of code?
:=Thanks
Hi:
Try starting with this
#include <16F876.H>
#device *=16
#fuses XT,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
#use delay(clock=4000000) //using 4Mhz crystal you'll get 1 us increment
#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ENABLE=PIN_C5, ERRORS)
#zero_ram
long int counter;
int end_counter_ready, enable_counter;
printf("\r\nRunning...");
enable_interrupts(INT_EXT);
ext_int_edge(H_to_L);
if(end_counter_ready)
printf("\r\nCounter \%lu ", counter);
end_counter_ready = FALSE;
delay_ms(200);
while(enable_counter)
counter++;
enable_counter = FALSE;
#int_EXT
edge_detect_isr()
if(!enable_counter)
enable_counter = TRUE;
ext_int_edge(L_to_H);
counter = 0;
end_counter_ready = TRUE;
disable_interrupts(INT_EXT);
Hope this help
Humberto
Original Post ID: 12979
Humberto
Acetoel
PostPosted: Sun Mar 23, 2003 6:57 pm     Reply with quote
Hi Humberto,
The High to Low Transition, in which pins has to occur. I think in the CCP1 pin, but I cannot see a reference to CCP1 in your code.
Ezequiel
:=:=Hi,
:=:= I'm using a 16F76 at 16MHz. Do you have a piece of code?
:=:=Thanks
:=Hi:
:=Try starting with this
:=#include <16F876.H>
:=#device *=16
:=#fuses XT,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
:=#use delay(clock=4000000) //using 4Mhz crystal you'll get 1 us increment
:=#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ENABLE=PIN_C5, ERRORS)
:=#zero_ram
:=long int counter;
:=int end_counter_ready, enable_counter;
:=void main()
:= printf("\r\nRunning...");
:= enable_interrupts(INT_EXT);
:= ext_int_edge(H_to_L);
:= enable_interrupts(GLOBAL);
:= while(TRUE)
:= if(end_counter_ready)
:= printf("\r\nCounter \%lu ", counter);
:= end_counter_ready = FALSE;
:= delay_ms(200);
:= while(enable_counter)
:= counter++;
:= enable_counter = FALSE;
:=#int_EXT
:=edge_detect_isr()
:= if(!enable_counter)
:= enable_counter = TRUE;
:= ext_int_edge(L_to_H);
:= counter = 0;
:= else
:= end_counter_ready = TRUE;
:= disable_interrupts(INT_EXT);
:=Hope this help
:=Humberto
Original Post ID: 12987
Humberto
PostPosted: Sun Mar 23, 2003 7:36 pm     Reply with quote
:=Hi Humberto,
:= The High to Low Transition, in which pins has to occur. I think in the CCP1 pin, but I cannot see a reference to CCP1 in your code.
:=Thanks
:=Ezequiel
Ezequiel:
Nop, I donīt use CCP1, instead I use external -edge selected- interrupt. I assume that to implement that you must use PIN_B0
to activate the interrupt hardware in 16F87x.This works fine.
Humberto
:=:=:=Hi,
:=:=:= I'm using a 16F76 at 16MHz. Do you have a piece of code?
:=:=:=Thanks
:=:=Hi:
:=:=Try starting with this
:=:=#include <16F876.H>
:=:=#device *=16
:=:=#fuses XT,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
:=:=#use delay(clock=4000000) //using 4Mhz crystal you'll get 1 us increment
:=:=#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ENABLE=PIN_C5, ERRORS)
:=:=#zero_ram
:=:=long int counter;
:=:=int end_counter_ready, enable_counter;
:=:=void main()
:=:= printf("\r\nRunning...");
:=:= enable_interrupts(INT_EXT);
:=:= ext_int_edge(H_to_L);
:=:= enable_interrupts(GLOBAL);
:=:= while(TRUE)
:=:= if(end_counter_ready)
:=:= printf("\r\nCounter \%lu ", counter);
:=:= end_counter_ready = FALSE;
:=:= delay_ms(200);
:=:= while(enable_counter)
:=:= counter++;
:=:= enable_counter = FALSE;
:=:=#int_EXT
:=:=edge_detect_isr()
:=:= if(!enable_counter)
:=:= enable_counter = TRUE;
:=:= ext_int_edge(L_to_H);
:=:= counter = 0;
:=:= else
:=:= end_counter_ready = TRUE;
:=:= disable_interrupts(INT_EXT);
:=:=Hope this help
:=:=Humberto
Original Post ID: 12988
Humberto
Humberto
PostPosted: Sun Mar 23, 2003 8:14 pm     Reply with quote
:=:=Hi Humberto,
:=:= The High to Low Transition, in which pins has to occur. I think in the CCP1 pin, but I cannot see a reference to CCP1 in your code.
:=:=Thanks
:=:=Ezequiel
:=Ezequiel:
#include <16F873.H>
#device *=16
#zero_ram
long int counter;
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
delay_ms(500); // choose your update time interval
do
}while(enable_counter);
#int_EXT
edge_detect_isr()
if(!enable_counter) // first falling edge
set_timer1(0);
counter = 0;
{ // second falling edge
disable_interrupts(INT_TIMER1);
counter = get_timer1();
Hope this help
Humberto
Original Post ID: 12989
Humberto
Acetoel
PostPosted: Mon Mar 24, 2003 3:50 am     Reply with quote
Hi Humberto,
Thanks very much for your help. My code starts with no interrupt enable, I need only to measure 1 (ONE) High to Low Transition. I have PB.0 connected to PC.7 (HUART RX)and a pull up resistor. So I need to measure 1 start bit pulse, and with that measurement I can determine the baud rate. Can I use PC.7 (In I/O Mode) directly?
Ezequiel
:=:=:=Hi Humberto,
:=:=:= The High to Low Transition, in which pins has to occur. I think in the CCP1 pin, but I cannot see a reference to CCP1 in your code.
:=:=:=Thanks
:=:=:=Ezequiel
:=:=Ezequiel:
:=Nop, I donīt use CCP1, instead I use external -edge selected- interrupt. I assume that to implement that you must use PIN_B0
:=to activate the interrupt hardware in 16F87x.This works fine.
:=#include <16F873.H>
:=#device *=16
:=#zero_ram
:=long int counter;
:=void main()
:= setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
:= while(TRUE)
:= delay_ms(500); // choose your update time interval
:= do
:= }while(enable_counter);
:=#int_EXT
:=edge_detect_isr()
:= if(!enable_counter) // first falling edge
:= enable_interrupts(INT_TIMER1);
:= set_timer1(0);
:= counter = 0;
:= else
:= { // second falling edge
:= disable_interrupts(INT_TIMER1);
:= counter = get_timer1();
:=Hope this help
:=Humberto
Original Post ID: 12994
Neutone
PostPosted: Mon Mar 24, 2003 9:21 am     Reply with quote
<font face="Courier New" size=-1>:=Hello,
:=Thanks
:=Ezequiel
This is almost the best accuracy you may achieve. Connect an extra pin to the input signal.
While (extra_pin);
set_timer0(0);
While (!extra_pin);
get_timer0();
If the timer overflows increment another variable. You can count all the time you wish to. It only cost you an extra pin.</font>
Original Post ID: 13000
Humberto
PostPosted: Mon Mar 24, 2003 8:55 pm     Reply with quote
:=Hi Humberto,
:= Thanks very much for your help. My code starts with no interrupt enable, I need only to measure 1 (ONE) High to Low Transition. I have PB.0 connected to PC.7 (HUART RX)and a pull up resistor. So I need to measure 1 start bit pulse, and with that measurement I can determine the baud rate. Can I use PC.7 (In I/O Mode) directly?
Yes, you can use it BUT you need to disable the INT_RDA and enable the INT_EXT interrupt until you get the count pulses you expect to discriminate what the baud rate is, then you need to disable INT_EXT and enable the INT_RDA to enable the hardware UART and get the next char, I think you will lost the first character, you need to work around. The only pin that can trigger the INT_EXT is PB0.
regards,
Humberto
:=Thanks
:=Ezequiel
:=:=:=:=Hi Humberto,
:=:=:=:= The High to Low Transition, in which pins has to occur. I think in the CCP1 pin, but I cannot see a reference to CCP1 in your code.
:=:=:=:=Thanks
:=:=:=:=Ezequiel
:=:=:=Ezequiel:
:=:=Nop, I donīt use CCP1, instead I use external -edge selected- interrupt. I assume that to implement that you must use PIN_B0
:=:=to activate the interrupt hardware in 16F87x.This works fine.
:=:=#include <16F873.H>
:=:=#device *=16
:=:=#zero_ram
:=:=void main()
:=:= setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_1 );
:=:= while(TRUE)
:=:= delay_ms(500); // choose your update time interval
:=:= do
:=:= }while(enable_counter);
:=:=#int_EXT
:=:= if(!enable_counter) // first falling edge
:=:= enable_interrupts(INT_TIMER1);
:=:= set_timer1(0);
:=:= counter = 0;
:=:= else
:=:= { // second falling edge
:=:= disable_interrupts(INT_TIMER1);
:=:= counter = get_timer1();
:=:=Hope this help
:=:=Humberto
Original Post ID: 13036
Humberto
Barry Gershenfeld
PostPosted: Wed Mar 26, 2003 2:18 pm     Reply with quote
: So I need to measure 1 start bit pulse, and with that measurement I can determine the baud rate.
Be aware that the start bit does not return high if the data bit that follows is also a zero. So you will need to watch those start bit readings for a few characters before deciding what is a usable reading. Or else instruct the host or user to always begin with certain characters.
Barry
Original Post ID: 13106
