problem with const struct array
kloppy
PostPosted: Wed Sep 01, 2004 1:12 am     Reply with quote
is the constant struct array battery_dat[] too big for ccs??
my program works fine until i call the line:
{"data.........9","mAh",9,1,900,9},
char to_print[20];
typedef struct {
   char data_name[20];
   char unit[6];
   int address;
   short read_type;    //same as int1
   long _100_percent;
   int marker;
}bat_data;
//#org 0x1800,0x1fff
const bat_data battery_data[]=
{{"data.........1","mAh",1,1,100,1},
 {"data.........2","V  ",2,1,200,2},
 {"data.........3","mAh",3,1,300,3},
 {"data.........4","V  ",4,1,400,4},
 {"data.........5","mAh",5,1,500,5},
 {"data.........6","V  ",6,1,600,6},
 {"data.........7","mAh",7,1,700,7},
 {"data.........8","V  ",8,1,800,8},
 {"data........10","V  ",10,1,1000,10},
 {"data........11","mAh",11,1,1100,11},
 {"data........12","V  ",12,1,1200,12},
 {"data........13","mAh",13,1,1300,13},
 {"data........14","V  ",14,1,1400,14},
 {"data........15","mAh",15,1,1500,15},
 {"data........16","V  ",16,1,1600,16},
 {"data........17","mAh",17,1,1700,17},
 {"data........18","V  ",18,1,1800,18},
 {"data........19","mAh",19,1,19000,19},
 {"data........20","V  ",20,1,20000,20}};
lcd_write_instruction(line_1);
strcpy(to_print,battery_data[position-1].data_name);
printf(lcd_write_data,"%s",to_print);
printf("%4u%s\n\r",position,to_print);
lcd_write_instruction(line_2);
strcpy(to_print,battery_data[position-1].unit);
printf(lcd_write_data,"%4u%s",position,to_print);
the output on the lcd and the hyperterminal (rs232) is:
when position is 7:
7data.........7
7mAh
when position is 8:
8data.........8
8V
when position is 9:
9data....data.........
9.1
i tryed the
#org 0x1800,0x1fff
before the const struct but the problem is still the same....
PostPosted: Wed Sep 01, 2004 3:17 am     Reply with quote
1) What chip?.
2) What compiler version?.
3) Why is 'data_name' declared as 20 bytes long, when the longest strng only needs 15 locations?.
kloppy
PostPosted: Wed Sep 01, 2004 7:58 am     Reply with quote
1) 16f876
2) pcm 3.206
3) that's the max i'll ever use with this program (i took 15 just to be sure that data_name is not longer than 20 bytes)
