Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
PIC18 & Interrupt
SBK
PIC18 & Interrupt
PostPosted: Fri Mar 21, 2003 8:36 am     Reply with quote
I am porting a 16F877 code to 18F452 but
it seems my program has problems with
interrupts.
Only RB0 EXT0 interrupt enabled. I send
"ISR" string for debugging from serial port
at the start of #INT_EXT.
Program sends ISR string continuously
even the RB0 is connected to GND and there is
no level change.
What's wrong?
___________________________
Original Post ID: 12919
Re: PIC18 & Interrupt
PostPosted: Fri Mar 21, 2003 11:50 am     Reply with quote
:=I am porting a 16F877 code to 18F452 but
:=it seems my program has problems with
:=interrupts.
:=Only RB0 EXT0 interrupt enabled. I send
:="ISR" string for debugging from serial port
:=at the start of #INT_EXT.
:=Program sends ISR string continuously
:=even the RB0 is connected to GND and there is
:=no level change.
I don't have PCH, so I can't help much.
What's your version of the compiler ?
In the versions list, CCS has this statement:
3.125 A problem with interrupts getting disabled is fixed
Original Post ID: 12928
SBK
PostPosted: Sun Mar 23, 2003 1:06 pm     Reply with quote
Do I have to use #INT_EXT or peripheral interrupt for
B0 interrupt on 18F452?
my version is PCW 3.148
:=I don't have PCH, so I can't help much.
:=What's your version of the compiler ?
:=In the versions list, CCS has this statement:
:=3.125 A problem with interrupts getting disabled is fixed
Original Post ID: 12975
