Problem w/ 20MHz Crystal
iso9001
PostPosted: Fri Aug 27, 2004 12:15 pm     Reply with quote
I have a HC49U at 20Mhz and the problem is, it works only when no caps are hooked upto it !?
I have 2 22uF caps, but when I put them on the pic stops working... I tried messing with the polarity in every combonation etc, nothing worked...
What could I be doing wrong ?
newguy
PostPosted: Fri Aug 27, 2004 12:42 pm     Reply with quote
It could be that there's enough parasitic capacitance on the crystal lines to allow it to work without any capacitors.
Maybe try 15 pF, or even 10 pF instead and see what happens.
How is the layout of the pcb? If there are any groundplanes really close to the crystal lines, then that would account for some parasitic capacitance. If you are just prototyping this on one of those push-in boards, then they're horrible for parasitic capacitance.
PostPosted: Fri Aug 27, 2004 12:50 pm     Reply with quote
I have 2 22 uF caps
iso9001
PostPosted: Fri Aug 27, 2004 2:36 pm     Reply with quote
Ah, right. 22 pF caps.... oops.
Hmmm... So why does the clock work w/o caps and why do I still need them ?
PostPosted: Fri Aug 27, 2004 2:57 pm     Reply with quote
Download the Pic16 Reference manual on the Oscillator:
http://ww1.microchip.com/downloads/en/DeviceDoc/31002a.pdf
See the following section for reasons why the capacitors are needed:
2.3.3.1 Determining Best Values for Crystals, Clock Mode, C1, C2, and Rs
ik1wvq
PostPosted: Wed Sep 01, 2004 3:28 am     Reply with quote
hi,
try to place a 1.5M resistor across the crystal .. ( in parallel)
this problem was completely disappared in a my old project ..
this information from a application note of microchip !!
regards ..
arunb
RE:
PostPosted: Wed Sep 01, 2004 7:28 am     Reply with quote
I have a similar problem, in this case only some crystals ( 20 Mhz ones) work, others simply do not work at all, but if I remove the 33pF caps then they work....
I have noticed that 4MHz crystals work perfectly well. Is it possibel that the problem may be with the PIC ( Iam using PIC 16F877- 20/4 )
My PCB has a ground track that is quite close to the 20 MHz crystal, do you think this might be the problem ???
Mark
PostPosted: Wed Sep 01, 2004 10:40 am     Reply with quote
Are you using the HS fuse option instead of the XT???
iso9001
PostPosted: Wed Sep 01, 2004 12:01 pm     Reply with quote
Yea, I'm using HS.
Whats odd is that it seems to work fine with no caps. I am doing that pulse width code and get the same times with caps in as caps out.
Also, I noticed last night I was working just outside our office and NONE of my code was working... so I was like WTF... loaded some code I knew worked and nothing.... I pulled one of the caps and it ran right up (twice) but then it went back to not working...
Its was probably 60degrees last night... Is that enough to screw up a Xsytal like that ?
drh
PostPosted: Wed Sep 01, 2004 2:00 pm     Reply with quote
Application note AN849 at the microchip website might help. Also, are you using a parallel resonant crystal?
David
