Userrr
| Point's in LCD |
Posted: Thu Aug 26, 2004 12:20 pm |
Using 2x20 LCD, I must printf to LCD value float , but how put to this
value after cents, thouthands, millions
example:
value = 9123567,5 in float
at LCD I must printf: 9.123.567.5 of ... |
| Re: Point's in LCD |
Posted: Thu Aug 26, 2004 2:39 pm |
| Userrr wrote: | Using 2x20 LCD, I must printf to LCD value float , but how put to this
example:
If this is being used for currency, forget floats, and use a 32bit integer instead. Otherwise you will have perpetual errors from the rounding inherent in floats. Have the integer count in 'cents', and it will be exact.
There are two different approaches to outputing the number. First, printf it, to a _fixed length_ output string, using sprintf. Use the option to display leading zeros, so the digits will allways be in the same place in the string. Then start at the left end of the string, use a counter to know where in the string you are, skip the zeros, and output the digits from the string when you get to them. When the counter corresponds to the positions you want the markers added, send these.
Alternatively, you can extract digits from a number using division, and subtraction, and use these the same way. However again the numeric accuracy of floats will give problems.
