two rs232 at same time!!
dieter
PostPosted: Thu Aug 26, 2004 9:08 am     Reply with quote
Hi, is it possible to drive two rs232 ports on one chip AT THE SAME TIME? that means if one port has to send some data,the other port is already able to receive any other data. such as non-blocking ports? is that possible, and is ther any code for that=? thanx for ur answers...
SherpaDoug
PostPosted: Thu Aug 26, 2004 9:59 am     Reply with quote
If one port has a hardware UART it should work fine. If both are software UARTs the CCS functions won't do it. If you are clever it should be possible to write your own that would work.
treitmey
PostPosted: Thu Aug 26, 2004 10:20 am     Reply with quote
I would go a step further and say, try to find a PIC with 2 hardware USARTS. Then you get the advantage of two bytes of RX buffer space. 1byte per USART.
