ADC with LCD
cxiong
ADC with LCD
PostPosted: Wed Aug 25, 2004 9:15 pm     Reply with quote
I write a routine to display the result of ADC channel 0 on the LCD.
I have the PIC Demo 2 Plus board, I have the LCD working fine with the
previous posted about the KEYPAD on port_b. But when I use it on the adc experiment,
the ADC part is working fine, but the display (result) is too fickering.
Is it the problem cause by some kind of timer delay of the adc?
Here is my code:
I welcome any suggestions.
Thanks.
#include <18f458.h>
#device ADC=10
#fuses XT,NOWDT,NOPROTECT,NOLVP
#include <lcdd.c>
   int16 value;
   int realValue;
   setup_port_a( RA0_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
      set_adc_channel( 0 );
         delay_us(25);
      value = read_adc();
         printf(lcd_putc,"\fADC Value: %ld",value);
LCD Flicker
PostPosted: Wed Aug 25, 2004 10:45 pm     Reply with quote
You are reinitializing the LCD display every time you execute the while loop. Move the lcd_init() up, outside of the loop, to right after the ADC setup line.
BTW. do you really want to update the LCD display 50-100 times a second?
You might want to put a delay_ms(250) or something similar after the printf() statement to slow things down in the while loop just a bit. Updating it at that rate could cause potential timing problems depending on the type of display you are using.
cxiong
PostPosted: Thu Aug 26, 2004 6:49 am     Reply with quote
That's it.
Thanx...
