Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
PIC18F452 doesn't start
Zwizzle
PostPosted: Fri Mar 21, 2003 1:01 pm     Reply with quote
Hi all,
I have recently migrated a project from the 16f877 to the 18f452, due to lack of space. I use MPLab 6.13, and the ICD2 programmer. Problem that occured is this: the PIC won't start. If I load it without debug mode, it doesn't do anything. If I use it *with* debug mode, it still doesn't do anything, although I can force it by 'stepping into' the code. If I do this, the ICD2 seems to reset several times before it takes the next step. In other words: it's useless. I've been fiddeling with the config bits, but no such luck so far. Does anyone recognize this?
Thanks!
___________________________
Original Post ID: 12930
Neutone
Re: PIC18F452 doesn't start
PostPosted: Fri Mar 21, 2003 2:54 pm     Reply with quote
:=Hi all,
:=I have recently migrated a project from the 16f877 to the 18f452, due to lack of space. I use MPLab 6.13, and the ICD2 programmer. Problem that occured is this: the PIC won't start. If I load it without debug mode, it doesn't do anything. If I use it *with* debug mode, it still doesn't do anything, although I can force it by 'stepping into' the code. If I do this, the ICD2 seems to reset several times before it takes the next step. In other words: it's useless. I've been fiddeling with the config bits, but no such luck so far. Does anyone recognize this?
:=Thanks!
Did you unplug the ICD2 from the circuit? While it is pluged into the circuit it will hold the circuit in reset.
Original Post ID: 12933
Zwizzle
PostPosted: Fri Mar 21, 2003 3:39 pm     Reply with quote
:=Did you unplug the ICD2 from the circuit? While it is pluged into the circuit it will hold the circuit in reset.
Yes I did. I also started a new project and pasted CCS's Watchdog18 example into it. It has the same problem: it compiles, but won't run, not in debug mode and not without it. HEX upload to the PIC18 is ok, ie. I can read it back without errors. I've installed the right crystal (HS), every internal 'device' (watchdog timer, powerup timer, etc) are disabled. And still the device doesn't start.
Original Post ID: 12935
