Posted: Thu Aug 19, 2004 7:18 am |
| Quote: | I could actually change it to
| This is correct.
| Quote: | | Would I be correct in thinking that clear_interrupt is in newer versions of the compiler? |
Correct again. I don't know when it was introduced, but it definately is in v3.187. Check the readme file in your compiler directory for a description of all additions to the manual. |
Humberto
Posted: Thu Aug 19, 2004 7:54 am |
| Quote: |
3.184 A new built in function CLEAR_INTERRUPT has been added
Humberto |
homfray
| You guys ARE THE DON |
Posted: Thu Aug 19, 2004 7:58 am |
boys, due to all your help I have got some code that is absolutely flying along Want to say a massive thanks to all of you!!!!! I have only had a quick check on the code but it appears to be working a treat. CHEERS!!!!
Here is the code if anyone is interested. I am not sure if this is the most efficient way to write this as I am a one of those dreadful physicists that where never supposed to be programmers and just ended up doing it one day.
The code reads in portE and portF and compares it with the previous if it is different it stores it .
| Code: | #define Fosc 40000000 // I'm using a 40 MHz crystal
#include <18F8621.h>
// COMPILER DIRECTIVES and HARDWARE CONFIGURATION
#use delay(clock = Fosc)
#fuses EC_IO
#fuses NOOSCSEN // Oscillator System Clock Switch Disabled
#fuses NODEBUG // No Background Debugger
#fuses NOLVP // Low Voltage ICSP Disabled
#fuses NOPROTECT // No Code Protect
#fuses NOWDT // No onboard watchdog
#fuses PUT // Power Up Timer Enabled
#fuses BROWNOUT // Brown Out Reset enabled
#fuses WRT
#fuses STVREN
#bit TMR2IF=0x0F9E.1
// GLOBALS - GENERAL
static short state = 0; //State Switch for watchdog
int8 delay_in_us = 10;
int16 i, us;
int8 newE, oldE, newF, oldF, s;
int8 io1[700], io2[700], time2[700];
int16 time1[700];
// FUNCTION PROTOTYPES - GENERAL
void setupMain(void);
// MAIN
setupMain();
while (1)
//Wait for Timer_interrupt_flag
while (! TMR2IF);
TMR2IF=0;
newE=input_e();
newF=input_f()& 0b011111111;
if(newE != oldE || newF != oldF && i < 700 && s < 200)
io1[i]=newE;
io2[i]=newF;
time1[i]=us;
time2[i]=s;
i++;
newE = oldE;
newF = oldF;
us++;
if(us==10000)
us=0;
s++;
output_bit(PIN_H0,state);
state=~state;
// MAIN SETUP
setup_timer_2(T2_DIV_BY_1, delay_in_us, 10);
TMR2IF=0;
disable_interrupts(GLOBAL); // disable all interrupts
oldE = input_e();
oldF = input_f() & 0b011111111;
us=0;
s=0;
i=0;
_________________ Nice!!! |
Posted: Thu Aug 19, 2004 10:41 am |
Thanks for sharing your code! Always nice to hear someone is happy and willing to share the results of their efforts.
Just two more remarks.
Remark 1:
A bug. You never change the values for oldE and oldF.
| Code: | newE = oldE;
newF = oldF;
should be replaced by | Code: | oldE = newE;
oldF = newF;
Remark 2:
Looking at the compiled code I see 111 instructions in the while loop. As a rough estimation your loop will execute in 11us, this is longer than the current timer2 delay of 10us. I suggest you either increase the timer2 delay to 15us, or optimize the loop. |
