who have sorcecode of LCD in 8 bit mode. Please post me sour
PostPosted: Mon Aug 16, 2004 8:21 pm     Reply with quote
who have sorcecode of LCD in 8 bit mode. Please post me sourcecode. because my sourcecode is not stable. it have 1 line. sometime it have 2 line. i use 16f877 and lcd 16*2 char. thank you for your help
PostPosted: Tue Aug 17, 2004 10:11 am     Reply with quote
The address of the second line's first char is 64 regardless of the number of chars/line. Don't forget to clear display content before sending new text etc.
Re: who have sorcecode of LCD in 8 bit mode. Please post me
PostPosted: Tue Aug 17, 2004 10:48 am     Reply with quote
There is not really much to it!.
Using PortB for the 8biit data, and three bits defined as 'RW', 'RS', and 'EN' for the control, with portB set to 'fastio':
/* These are the values to send to the LCD for special control/setup */
#DEFINE   BS   0x08   /* code to backspace */
#DEFINE   EMD   0x1E   /* program to default entry mode */
#DEFINE   CLS   0x12   /* clear screen */
#DEFINE       FLINE   0x80   /* move to location */
#DEFINE       CON   0x1B   /* enable cursor */
#DEFINE       COFF   0x1A   /* disable cursor */
#DEFINE   FSET   0x1F   /* set to 2 lines etc. */
#DEFINE   DISON   0x1D   /* code to switch on display */
#DEFINE       DISOFF   0x1C   /* code to disable display */
#DEFINE       HOME   0x80   /* code to goto home */
#DEFINE       LASTTO   0x9F   /* Last 'goto' command */
#DEFINE       SLINE   0x90   /* code to goto start second line */
#DEFINE   CR   0x0C   /* carriage return */
#DEFINE LF   0x0A   /* line feed */
#DEFINE   CLEOL   0x19   /* clear to EOL */
#DEFINE       CGW   0x17   /* write to CG RAM */
#DEFINE       DW   0x18   /* write to normal RAM */
/* These are the LCD control lines */
#DEFINE   EN   PIN_C0
#DEFINE RS   PIN_C2
#DEFINE RW   PIN_C1
void dctl(unsigned int chr)
/* this is the code to put one char (chr) to the control port on the LCD */
/* to do this, I need to raise the 'strobe', but leave RS low */
   portb=chr;
   output_low(RW);
   delay_us(1);
   output_high(EN);
   delay_us(2);
   output_low(EN);
void ddat(unsigned int chr)
/* as above for the data port on the LCD */
   portb=chr;
   output_low(RW);
   output_high(RS);
   delay_us(1);
   output_high(EN);
   delay_us(2);
   output_low(EN);
   output_low(RS);
int checkflag(void) {
   int ipval;
   SET_TRIS_B(0xFF);
   OUTPUT_LOW(RS);
   OUTPUT_HIGH(RW);
   OUTPUT_HIGH(EN);
   delay_us(5);
   pval=portb;
   OUTPUT_LOW(EN);
   OUTPUT_LOW(RW);
   SET_TRIS_B(0);
   return(ipval & 0x80);
I have a 'parser', which uses:
static int DRAM=true;
static unsigned int dcon = 0x0f;
while (checkflag()) ;
if (chr<0x20)
/* here I have a control character */
/* This has the most complex layout, requiring character translation... */
   switch (chr) {
   case 0:
   case 1:
   case 2:
   case 3:
   case 4:
   case 5:
   case 6:
   case 7:
      ddat(chr);   /* send CGRAM display character */
   case BS:
      /* This is the 'bs' character */
      dctl(0x10);   /* This shifts left one character */
      /* Note that this does not provide the proper 'bs' function. The
      input code has to substitute 'bs, space, bs' to get the required
      display */
   case CLS:
      /* CLS */
      dctl(1);
   case COFF:
      /* cursor off */
      bit_clear(dcon,1);
      bit_clear(dcon,0);
      dctl(dcon);
   case CON:
      bit_set(dcon,1);
      bit_set(dcon,0);
      dctl(dcon);
   case DISOFF:
      /* display off */
      bit_clear(dcon,2);
      dctl(dcon);
    case DISON:
      bit_set(dcon,2);
      dctl(dcon);
    case EMD:
      /* EMD command (increment, no shift) */
      dctl(6);
    case FSET:
      /* function set */
      dctl(0x38);
    case CGW:
       /* This sets a flag, so that the _next_ address write switches to CGW */
      DRAM=FALSE;
    case DW:
       DRAM=true;
     default:
  else if (chr>=HOME && chr<=(LASTTO+1))
     /* Here I have a 'goto' character */
     /* Here the low five bits of the character are the required address */
     /* I also have to check whether CGRAM, or DDRAM is required */
     if (DRAM)
       if (chr>=0x90)
         dctl(chr+0x30);
          while (true) {
             dctl(chr);
              /* Here I check that address has updated */
              SET_TRIS_B(0xFF);
              OUTPUT_LOW(RS);
              OUTPUT_HIGH(RW);
              OUTPUT_HIGH(EN);
              delay_us(5);
              ipval=portb;
              OUTPUT_LOW(EN);
              if (ipval == (chr & 0x7F)) {
                 OUTPUT_LOW(RW);
                 SET_TRIS_B(0);
              OUTPUT_LOW(RW);
              SET_TRIS_B(0);
          /* Here I want to talk to CGRAM */
          dctl(chr-0x40);
        /* here a normal text character */
        ddat(chr);
You'll have to count the brackets, since it is cut out of a larger subroutine. The initialisation sequence, is then FSET,FSET,FSET,FSET, DISOFF,DISON,EMD,FLINE.
treitmey
PostPosted: Wed Aug 18, 2004 8:24 am     Reply with quote
As a reminder. Search for souce code in the source code library.
http://www.ccsinfo.com/forum/viewforum.php?f=2
