Programming pic16f877A
Igna
PostPosted: Fri Mar 21, 2003 7:47 am     Reply with quote
I've read that 16f877A is programmed in a different way as the 16f877 does. I have several PIC programmers but they don't work with my 877a. I think that it's due to the icprog which doesn`t make any different between 877 and 877a. I've programmed my 877a in a picstar which let you choose 877a(This one isn't mine, of course). ¿Any program for my normal programmer? ¿Do I have to buy an especial programmer?
___________________________
Original Post ID: 12916
Re: Programming pic16f877A
PostPosted: Fri Mar 21, 2003 11:28 am     Reply with quote
:=I've read that 16f877A is programmed in a different way as the 16f877 does. I have several PIC programmers but they don't work with my 877a. I think that it's due to the icprog which doesn`t make any different between 877 and 877a. I've programmed my 877a in a picstar which let you choose 877a(This one isn't mine, of course). ¿Any program for my normal programmer? ¿Do I have to buy an especial programmer?
:= Thanks
Well, what's your normal programmer ?
I would check the manufacturer's web site for an update.
Or, ask them to add support for it.
Original Post ID: 12927
