Software RS232 Problem on 16F648A
jclauss
PostPosted: Fri Aug 13, 2004 5:29 am     Reply with quote
I'm using two software rs232 in my project.
Defined as following:
#use rs232(baud=28800,xmit=PIN_C6,rcv=PIN_C7,bits=8,STREAM=PORT_C)
#use rs232(baud=4800,xmit=PIN_B2,rcv=PIN_B1,bits=8,STREAM=PORT_B)
The software is not working with PIN B2 and B1 but with B5 and B4
PIN B2 and B1 are the hardware rs232!
Is there any help out there concerning my problem?
Humberto
PostPosted: Fri Aug 13, 2004 7:48 am     Reply with quote
PIC16F648A doesn´t have PORTC
Humberto
PostPosted: Fri Aug 13, 2004 9:00 am     Reply with quote
True, this was wrong in the post, but not the point
Here is the right one:
#use rs232(baud=9600,xmit=PIN_B2,rcv=PIN_B1,bits=8,STREAM=PORT_C)
#use rs232(baud=4800,xmit=PIN_A3,rcv=PIN_A4,bits=8,STREAM=PORT_B)
With B5 and B4 in the first Line it works otherwise not!
Anyone an idea?
Mark
PostPosted: Fri Aug 13, 2004 9:29 am     Reply with quote
I gots an idea. Post a working example of the problem otherwise ain't didly going to get fixed Wink
SherpaDoug
PostPosted: Fri Aug 13, 2004 12:55 pm     Reply with quote
So it works using a software UART on B5 & B4, but not on pins B2 & B1 which happen to be the hardware UART. If you call out the hardware UART pins it will try to use the hardware UART. Is there still a way to force a software UART even on hardware UART pins? I don't have my manual with me.
